Bolting Coil Bracket onto Intake Bolts (stealthram)????
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i have a 1991 z28 that had the TPI and now has a stealthram. i would like to mount my coil using the two center intake bolts on the passenger side...
can i remove those two center bolts (intake has already been bolted on), bolt on the coil bracket, and have everything hold up and seal correctly?]
TIA
TIA
Transmission: A4
what I did with mine was I turned the mounting holes into grooves and all I have to do is loosen the two rear intake bolts and then just slip the bracket under the bolts. Yes this breaks the seal on the bolt but I havent gotten around to getting some custom studs with a nut on it
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
coil bracket
You can grind the coil bracket out in between the bolt holes so it will clear the hump in the stealth ram and then it will fit in the stock location and be out of the way. Thats what I did.
Car: 1991 Z28
Engine: 383
well i ended up mounting it onto the firewall above the heater box...i wanted to put in on the intake but it just looked too cluttered so i put it elsewhere.
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
