Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Pics of Remote T-Stat locations...
Old Mar 20, 2006 | 01:56 PM
CamaroCrazy23's Avatar
Car: 1991 Z-28
Engine: AFR ELIM 195s,280xfi,58mmLt1 Intake
Transmission: 2200stl,700r4 shift kit,vette servo
Axle/Gears: 28 spline, 3.42 gears, SLP Posi
I'd like to see how others have done the lt1 swap and how they placed their t-stat houseings.
Thanks a head of time
Old Mar 21, 2006 | 01:24 AM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
here is mine, i mounted it were the ac compressor used to be.
Attached Thumbnails Pics of Remote T-Stat locations...-thermostat-housing.jpg
Old Mar 21, 2006 | 12:10 PM
Car: 1991 Z-28
that looks great!
but unfortunatly thats where my alternator is but you gave me an idea. I bet i could make it work in the spot wher ethe ac is now deleted in my own car.
Old Apr 15, 2006 | 10:50 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Here's one I've done. Note, thats a CS144 alternator, not your standard CS130, and it has a different extension bracket and brace. I imagine a similar setup could be installed with a CS130 setup though.
Old Apr 16, 2006 | 02:37 PM
Car: 1991 Z-28
what did you use to protect the coolant lines from the heat from the headers?
Old Apr 16, 2006 | 04:13 PM
thirdgen88's Avatar
Car: 1995 Corvette
They don't affect them much if at all... No problems with overheating at all, we did end up wrapping the fuel lines in some protective covering, but the coolant lines also route far enough to the back before crossing over that they don't really get heat soaked much.
Old Apr 16, 2006 | 07:56 PM
@ZZKKER's Avatar
mine are also far enough away so not to melt. i ran the line for the pas side in between the valve cover and the alt, and the drivers goes back and around the valve cover and between the wiper motor and valve cover, then along the frame rail.
did one of yours melt?
Old Apr 16, 2006 | 08:51 PM
thirdgen88's Avatar
Car: 1995 Corvette
No, not at all..
Old Apr 18, 2006 | 09:58 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
here's a link to a thread that i started
https://www.thirdgen.org/forums/alte...-remote-t.html
Lanz06
Mar 13, 2019 06:07 PM
1992Z28!
Nov 19, 2015 07:33 AM
tglennon11
Sep 23, 2015 05:30 PM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
gt4373
Sep 9, 2015 10:29 AM
