Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
My first engine project
Old Jul 7, 2006 | 02:12 PM
Phatfiddler's Avatar
This will be my first project where I actually work on the engine. I have spent the last 3 years researching and preparing, and I am almost ready to start. During these past 3 years I have also been collecting parts in order to accomplish the swap. Here is a list of all I have currently:
Cutler/Holley Single-plane EFI
Turbonetics Carb Hat
Cold air intake (The one from Anesthes after he removed supercharger)
TBI to TPI repinning parts
730' ECM for swap
Holley High-Flo fuel pump for swap
LT1 cam from a 96'
Subframe connectors from UMI
Adjustable controls arms, panhard bar from UMI, spherical ends
Spohn front rebuild kit
Edelbrcok strut tower brace
Spohn Wonderbar
Ostrich from Moates, already have a laptop
Custom made ALDL cable using MAX232 circuits
Full aluminum radiator from Be-cool
140 amp alternator
The items in bold are already in the car. The camaro currently has the original 305 TBI, bone stock except for open-air element. Im going to go ahead and put everything on the car with the 305 in order to prepare for the new engine. I had a 355 lined up, but decided to sell the engine along with the 74 Blazer. It had been rebuilt 2000 miles ago, but had been sitting for about 3 years, and the condition of it was unknown. So I will be starting fresh with a short-block ZZ4.
This is a daily-driven vehicle, so reliability is a must. Obviously other items will be along in the future like a 9" posi-rear, aluminum driveshaft, 4-wheel discs etc. Items I still need for the swap are headers and y-pipe.
I will dyno the 305 in stock form before the swap, and then dyno afterwards using the stock heads. I will not be getting new heads for the 305 since I will be swapping in a 350. But I do need suggestions on heads for the 350. I want to achieve around 380 HP at the flywheel with the 350. Since it is daily driven, running on stock 700R4 with 10-bolt rear, i dont need anything too wild just yet. Until the new rear and 6-speed come around, I'll obviously have to take it easy. The car will also never see a track. Thanks in advance for your opinions and suggestions !
Old Jul 13, 2006 | 09:11 PM
2 more weeks!
Well after getting everything I need for the swap, I realized I was missing a few piece here and there, nickel dime stuff really. Got my Ostrich, but laughed at myself when I realized I forgot the G1 and the ZIF. Also forgot the plugs that go into the 730' ecm, and the bracket for the 700-R4 kickdown. Everything is now ordered and on the way..even an extra 730' ecm (which will include the plugs) just in case I have issues. I'll try to keep everyone informed as I go. I'll have pictures of the swap after classes end for the summer in about 2 weeks.
Frozer!!!
Jan 19, 2024 04:55 PM
Cleotiz
Jan 6, 2018 08:56 PM
Fast355
Dec 2, 2016 06:33 PM
E Rod
Aug 28, 2015 05:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
