Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Superram Installed!!!! Picks.
Old Nov 11, 2006 | 06:13 PM
PROCHARGED's Avatar
Car: 1992 TRANSAM 1989 FORMULA 350
Engine: L-98 350
Transmission: FIRM SHIFTING 700-R4
Well,I finally got it all done today.Was not to bad-but I think installing the upper intake was the bi1ch!! I tapped only the middle inner bolt holes-but now after the install I wish I would of tapped all the inner bolt holes well when I put the 427 stroker in the formula thats when I will do it.Thanks for all the great info and tips they really helped.Now about performance! This intake is great from 3500 RPM to 5500 RPM it pulled alot better than the stocker with a throttle body on it.I was scared to take it passed 5500 RPM because the engine is stock with bolt on's. Next bolt on is 1.6 roller rocker arms.Thanks again!! Here are the picks.
Attached Thumbnails Superram Installed!!!! Picks.-super2.jpg   Superram Installed!!!! Picks.-super4.jpg   Superram Installed!!!! Picks.-super6.jpg
Old Nov 11, 2006 | 07:00 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Looks nice
Old Nov 11, 2006 | 08:39 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Damn that thing is big!
Old Nov 12, 2006 | 09:37 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Nice I cant wait till I get mine installed.
Old Nov 13, 2006 | 04:06 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Looks great - nice job!
Old Nov 13, 2006 | 04:27 PM
1BADROC's Avatar
Car: 1989 IROC-Z
Axle/Gears: 9bolt 3.27
looks great i went with hsr and i know it helped a lot with the higher rpm's. If you got higher miles on that car id say you could run it up to 6,000rpms and be ok. I i run mine to 6,200 sometimes and im completely stock other than exhuast and intake mods.
Old Nov 18, 2006 | 11:08 AM
shawn87gta's Avatar
Looks like it's been ported too.
Old Nov 22, 2006 | 07:03 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Yep, the SuperRam looks BOSS.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
