Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
what is this HSR stuff i keep seeing all over the place all the time
Old Mar 16, 2007 | 08:43 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
ok i give
what is HSR and why does it seem like it is something that requires a billion modifications
is this a third gen f body thing only ?
or ?
what is the big deal about it ?
i see so many threads with something about HSR in them but i have no clue what it is
i assume its some kind of fuel injection or something
i am a carb and TBI guyand somewhat MPFI
but anything other than that i have no idea
wanted to learn something here i guess
heh
Old Mar 16, 2007 | 09:04 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
this is the HSR,
HSR stands for Holley Stealth Ram
Old Mar 16, 2007 | 09:33 AM
Stealth Ram
Old Mar 16, 2007 | 09:55 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Billion modifications? Adapt the fuel rails, install the HSR, tune. Sometimes you need to change the distributor, but on 86 and earlier. No big deal.
Old Mar 16, 2007 | 12:14 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
hum interesting, so its TPI or MPFI
now i know what this HSR thing is all about i guess
thats cool
Old Mar 16, 2007 | 12:26 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
It just replaces the tpi intake base/runner/plenum. It uses all the same sensors (except egr) and raises the rpm range some as tpi cuts off at 4000-4500.
Old Mar 16, 2007 | 12:32 PM
It IS a MPFI system.
It is NOT TPI ("Tuned Port Injection"), which is a specific system produced by GM, which attempts to produce acoustic reinforcement of cylinder fill events over a narrow range of RPMs, with as little effect as possible on RPMs lower than that range and at the total sacrifice of cyl fill above that RPM range, by using "tuned" (like a wind musical instrument) runners.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
ASE doc
Aug 25, 2015 09:14 AM
