throttle and kickdown brackets?
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
what are you guys using to hook up your throttle and kickdown cables to your throttle body intakes? like the 4bbl throttle bodies.
Car: '02 Z06
Engine: L33 5.7
Re: throttle and kickdown brackets?
to the top. I Bought the edelbrock Super victor "E" efi manifold and their 1000cfm throttle body. Similiar to any other fuel injection 4bbl throttle body. Any known linkage that works to support my throttle and 700r4 cables? I see some by edelbrock that bolt to the manifold but would'nt the fuel rails be in the way? others I see bolt to the same bolts for the throttle body, but all the pictures look like they would interfere with one thing or another.
TCI has a great one that bolts to the back bolts of the throttle body but it looks like it runs right into my two vacuum nipples that come off the throttle body. but I may still give that one A try
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Traviz
I was facing a similar dilemma when I did my conversion a while back. Lucky for you Elderock (38783) throttle body uses a standard square-bore carburetor mount flange. Look into Lokar TCB-40EDK Edelbrock Pro-Flo Injection Spacer/Throttle/Kickdown Bracket Kit
http://www.lokar.com/product-descrip...-edelbrock.htm
There are possibly other alternatives, but I have not seen anything else that gets around fuel rail interference. Another possibility is Holley 20-112 with 20-119 transmission bracket. This is not a cheap solution either nor is it clear to me if there will be interference between bracket and fuel rail.
I hope this helps.
//RF
I hope this helps.
//RF
On one I worked with some time ago, we took a stock TBI, and cut the whole "plate" thing, with the snail-shell and all that, off of it; drilled a couple of holes in it; and bolted it to that stupid thing those 4-bbl TBs all come with.
We used a stock TBI bracket for the fixed part. We just cut off the parts that held the cable housings and mounted it up on some fabbed-up brackets we made out of pieces of aluminum and steel strip stock.
Car: '02 Z06
Engine: L33 5.7
well its been a month, i went with a holley carb bracket. part# 20-95
too bad it did not fit directly, but with some modification, it will work I believe. Here is some pics of what I am going to cut off, (circled in red) and drill a new hole (circle with X through it)
opinions?
opinions?
Yeah the bracket is the EASY part. That'a a total no-brainer. You didn't even need the Holley one; a stock carb or TBI one would have worked just as well. On the car I referred to, that's what we used.
Now you have to deal with the actual WORK, the part I was talking about; which is, the linkage on the TB. I thought that's what you were asking about, since the bracket part, as your pictures show, is so trivial and a non-problem.
Car: 86 Z-28
Engine: 355 small block XR276HR roller cam
Transmission: TCI built 700r4 2000 lockup stall
Axle/Gears: moser axels auburn posi 3:73 gears
the part you are looking for is sold by bto or bowtie overdrives i tried many other set ups but for proper setting an tuning this is a good piece an worth every bit of the money considering the parts that are at risk. you might want to talk to them before cutting on that piece because my expience taught me that was only a small part of it. the address is bowtieoverdrives.com
Car: 75 Beast
opinions?
opinions?
Since you have a 4bbl TB OEM 4BBL Q-Jet bracket probably would need just a simple shaping - bending for a proper fit. These brackets commonly found on early to mid 80's trucks and vans equipped with Q-Jets and 700R4 and was sourced from JY trip.
//RF
Car: '02 Z06
Engine: L33 5.7
the problem i see with that last picture, is keep in mind, i have fuel rails, and that bracket would definitely contact them.
Hello, Michael
Sep 11, 2015 01:10 PM
