Considering carb to EFI swap.
Car: 86' Trans-Am (wrecked)
Engine: none currently
Transmission: Borg-Warner T-5
Axle/Gears: 2.86:1 w/ one broken axle
I am fairly new to EFI, but I have been reading up on it lately and I am starting to like it now that I understand more about how it works. I am just curious what are some ways to convert a 1981 350ci sbc to fuel injection. I would want to go with some type of MPFI or TPI if I did a swap, because I have seen TBI in action and have never liked it. My car came factory with a CCC, so I definitely don't want to go back that way either. I know holley and some other companies have full blown systems that include ECM and all, but they are extremely expensive and way out of my price range. I have access to a local junk yard that I can get very reasonable prices at, so is there some sort of EFI system I could pull out of a junk car and use as a starting point and then buy another manifold instead. If this is a common or stupid question to be asking then I am sorry, but I just don't know where to begin if I do decide to swap.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Considering carb to EFI swap.
The harness can come out of any fuel injected fbody, even a 3.1 car. You just need to repin a few wires, but since your application is custom that shouldn't be a problem.
So lets look at the list:
1) ECM + harness, about $150 total
2) Stock TPI setup, about $250 complete OR HSR/lt1/miniram $600-1200
3) MAP, knock, iat, cts, and so on about $75
4) Fuel pump + fbody sender $50 at junkyard, or about $120 for a good walbro
You'll need to modify the fuel lines a little. Not a big deal.
-- Joe
If you would enlighten me, is the TPI in the stock fbodys sequential fuel injection or MPFI?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
MPFI is just what it is, multi-port = 1 injector per cyl.
Sequential means the injector firing is timed with valve movement.
All thirdgens are batch fire.
-- Joe
Yeah, that is what I meant.. batch fire or sequential. Thanks for clearing that up for me.
How about the forthgens.. are they batch fire or sequential?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
what HEI thing are you talking about? I don't know much about SBCs from after about 85, so I have no idea what ignition setup they have. Could I use the entire EFI and HEI setup off of a fourthgen?
