Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Low impedance injectors
Old Apr 27, 2008 | 10:03 AM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
I have a set on Ford E4ZE A3A, 30 lb, low impedance injectors and would like to use them on my 89 IROC (165/MAF) The injectors on my car now measure 16 ohms and the Ford's measure 3.6 ohms. Will they damage my computer? Is there a "simple" way to make them work?
Old Apr 30, 2008 | 12:20 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Re: Low impedance injectors
Nope. You need the high impedance unl;ess your injector driver chip in the ECM is changed or you use a different type of ECM.
Old Apr 30, 2008 | 06:47 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Vern is correct. You cannot use them in your car. As stated the electronics is not set up for them.
jklein337
Sep 19, 2018 06:23 PM
italiano67
Dec 11, 2016 09:21 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Thornburg
Aug 27, 2015 08:33 PM
GouldyGTR
Aug 21, 2015 10:43 PM
