Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Best system for 383 stroker???
Old Sep 21, 2008 | 04:44 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Ok, so I'm building a 383 for my 85 T/A.. I have read that the factory TPI setup cannot be made to work with the demands of a 383. I need to keep the egr valve for emissions purposes. I havent bought heads for this motor yet, or an intake or fuel inj. system. I would also like to keep my factory 4 vent hood. I am not opposed to any aftermarket system, so any suggestions would be appreciated. I will be backing this motor up with a t-56 and it will be a street driven car. I want something high-revving that makes good power throughout the entire rev-range. I also havent selected a cam yet. As I said, any help would be appreciated!
Thanks, guys!!
Old Sep 24, 2008 | 11:09 AM
Re: Best system for 383 stroker???
Anyone? I would think someone would have the answer for this...........
Old Sep 24, 2008 | 11:31 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I have a post for modifying the Accel SuperRam. I believe one cleaned up a little would be more than enough for your motor. The one I modified went on a 406 motor. Even in the stock configuration it is probably your best bet and still keep emissions.
Old Sep 24, 2008 | 12:03 PM
Thank you 89gtatransam!! I was looking at the possibility of using a single plane. I assume that setup is using accel dfi for its electronics/tuning? I was kind of thinking of going with a maf system with an elbow for intake maybe. I just dont know enough about this stuff. I'm still trying to get used to LS-1 edit.
Old Sep 24, 2008 | 03:31 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I would port an Accel Super Ram if you can find one. However, I understand that they are out-of-production. Check with Summit Racing and Jegs. The main restriction here is the intake base (intake manifold). This must be ported. Also port the runners. The Accel SR has provisions for the EGR,,, the Holley SealthRam does not. If not for the EGR, the HSR is the best choice today.
Whats this about LS1Edit? When tuning our OBDI 3rd gen cars, we "burn" Eprom chips. There are several ways to do this. Check with the DIY Eprom board here.
Old Sep 27, 2008 | 12:14 AM
Thank you doc!! I have an ls1 in my 90 RS. The software is easy to use (For the most part.) I would like to have the same sort of tuning abilities with the new system in my T/A. Burning chips does not sound like a whole lot of fun. (I have a few friends who do it... ) I would like to be able to tune my T/A the same way. my RS has a F.A.S.T. setup in it and I would like to use that system or something similar to it, if I could...
Old Sep 27, 2008 | 12:31 AM
BTW aesthes is running something currently, that I might be interested in....
Old Sep 27, 2008 | 12:41 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Thanks, guys!!
High-revving plus street car does not equal fun. A 383 TPI plus a SuperRam is going to give you a limit of about 5500 rpms. The extra cubes are going to give you more than enough torque for the street.
Old Sep 27, 2008 | 03:42 PM
I drive my company truck to work, most days. If need be, I always have my jeep or my 86 IROC. The T/A is going to be my fun car. I already have a track car (90 RS). I just want something "Streetable" That will not be too aggravating to drive on the street. It needs to be able to pass emissions.
Thanks!!
Old Sep 27, 2008 | 04:27 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Super ram is a good bet...actually probly your only choice unless you cut up a TPI manifold and use cut up welded SLP runners to get your revs
Keep the 383 to 6000 rpms or under and it will be a blast. My HSR goes to 6300 and its a BLAST on the street but its not emissions legal
FIRST TPI is a big TPI setup that should peak in the 5000-5500 range on that motor yet still make some power since it flows well.
Old Sep 27, 2008 | 04:38 PM
comp's Avatar
love Torque
Old Sep 27, 2008 | 05:33 PM
We all love torque!! Whatever setup I use, I want it to be tunable on the fly... Is the superram going to fit under the 4-vent hood? I want to get something that can be used for future upgrades... (STS twin-turbo system in the future) How about a superram with F.A.S.T. XFI ?
Old Sep 27, 2008 | 06:35 PM
90c350's Avatar
Dynamic EFI flash ebl with the port mod done.Will be cheaper than F.A.S.T stuff and will handle up grades along with Power adders later. Tuned with a laptop on the fly. Just my 2c's
Old Sep 27, 2008 | 08:31 PM
LMSkyliner's Avatar
Car: 1989 Iroc-Z
Engine: 383 FFI
Transmission: TKO600
Orr, I thought that we had decided it was probably closer to 5500-6000 RPM for the FIRST? That's why my FIRST motor should be about able to keep pace with your HSR?
anyways, i suggest FIRST.
/goes off to check the facts
edit: well in the engine they have online, it peaks at 5000 and falls off after like 5400. But i remembered where my thoughts came from, I was going to heavily port my FIRST runners so i could shift at like 6100 . Plus they don't tell what cam it is, my AFR heads should flow better than their heads, and my compression will be up a bit. Who knows. It says it "supports up to 600 HP" so your guess is as good as mine.
Old Sep 27, 2008 | 10:55 PM
Dynamic efi flash ebl? Port mod? 2c's? I'm more confused than before... It sounds interesting, but I'd like to know more. The accel superram sounds good, but is it the best?
Old Sep 28, 2008 | 02:30 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
well for a torquey first streetable emission legal setup i'd try to keep the cam down where it will peak in the 5000-5500 range. First should beable to do 5500 rpm peak and support abit of power past that but its runners are abit too long for higher rpm hp. it just flows so much that you can make big hp at lower rpms if you setup the rest of the combo right
Old Sep 28, 2008 | 03:59 AM
What is "first"?
Old Sep 28, 2008 | 09:59 AM
LMSkyliner's Avatar
Car: 1989 Iroc-Z
Engine: 383 FFI
What is "first"?
www.Firstfuelinjection.com. It's a little known system for our cars. It's basically a larger TPI, so it supports alittle more high end power, but it also seems to retain the TPI's torquey nature throughout the RPM band. It's the system I plan on running on my 383.
Old Sep 28, 2008 | 11:05 AM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
TPIS Miniram!
Old Sep 28, 2008 | 01:53 PM
Thank you for the link LMSkyliner!! I will check it out.
Justin89formy; The miniram does not have an egr valve does it? It will never pass the visual in az if it does not have one.
Old Sep 28, 2008 | 02:42 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
nope the only emissions legal stuff is superam, TPI stuff, and FIRST but i dont think first has EO or CARB number for those that require those numbers to be legal. TPI/superram stuff does
Old Sep 28, 2008 | 03:05 PM
Az does not have strict requirements that they comply with a set of parameters. They only require that they pass an exhaust/dyno test and a visual inspection.
Old Sep 28, 2008 | 03:17 PM
I'm not sure what to think of the first system. It looks like a tpi setup. Maybe bigger. Still thinking superram. maybe...
Old Sep 28, 2008 | 04:17 PM
LMSkyliner's Avatar
Car: 1989 Iroc-Z
Engine: 383 FFI
That's exactly what it is. See this picture to see just how much bigger it is:
Obviously, the one on the right is the stock TPI. the one on the left is the FIRST system. You can also see the first system can be ported alot.
Old Sep 28, 2008 | 04:30 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i do believe the FIRST runners are just abit shorter in length than the stock style TPI stuff. So there you will make abit more power in a higher rpm range but not too much more tho. i can see 5500 peak which is great for a streetable car
Old Sep 28, 2008 | 08:34 PM
LMSkyliner's Avatar
Car: 1989 Iroc-Z
Engine: 383 FFI
Ah! that's the other thing i forgot. He is correct. The FIRST runners are the second longest of any intake, but the TPI's runners are indeed as much as a few inches longer over all. Moves the RPM band up.
Old Oct 1, 2008 | 11:14 PM
Pretty sure I'm going superram. Not too sure yet. Are those first runners available seperately? Would they fit the stock plenum?
Old Oct 2, 2008 | 01:12 AM
Kevin91Z's Avatar
No, the first setup only fits their own stuff as a complete unit. Its not interchangeable with any other TPI stuff.
Allan (1989GTATransAm) was able to modify a first lower intake to fit his SLP runners, but it was a lot of work.
Old Oct 2, 2008 | 07:35 PM
Z51L9889's Avatar
Car: 89 Corvette
Transmission: ZF 6 speed
I have measured the total lengths (runner + base), diameters, and plenum volumes of an ACCEL base + AS&M runners versus the FIRST. I'm planning on using the FIRST (with significant porting) on the 383 I am currently building for my 89 Corvette.
ACCEL base/ AS&M runners:
Runner/Base diameter -- 1.66"/1.70"
Overall length -- 16.688"
Plenum Volume -- 2220 cc (135 cu. in.) -- significant porting
FIRST intake:
Runner/Base diameter -- 1.75"/1.875"
Overall length -- 15.875"
Plenum Volume -- 2935 cc (179 cu. in.)
There is enough meat in the runners to port them out to 1.9" without needing to worry about busting through.
Old Oct 2, 2008 | 08:03 PM
Car: 1989 GTA
Engine: 369 TPI
Thank you for posting. Interesting information.
Old Oct 2, 2008 | 08:10 PM
Bummer, I was kinda hoping they would work on my 86 IROC. Oh well, anybody got any leads on a nice accel superram?
Old Oct 2, 2008 | 08:33 PM
91z28 98ta's Avatar
Car: 89 iroc 98 T/A
Engine: LSX
i bought a 383 vortech stroker from jegs and put the spdc intake with slp runners 58mm bbk throttle body, underdrive pulleys, full exhaust , bigger injectors, chip tuned by fast chip.............. all sounds good but car is running way to rich i have adjustable fuel psi regulator and at the lowest setting the gas fumes will make your eyes water, im sort of fed up with tpi and its limitations my problem is probably to big of a fuel injector, but when i get the cash i swapping to carb and selling the tpi goodies.
Old Oct 4, 2008 | 02:19 AM
91z28 89ta; From what I hear, your problem is more likely intake restriction. This is what i am trying to avoid.
Old Oct 4, 2008 | 10:04 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
I have a similar setup, but found on a dyno that the mail-order tune is far too rich, the Scoggin base is very restrictive right at the injectors bosses, and the stock intake system is just not letting in enough air. Also the stock fuel pump wasn't supplying enough fuel volume, so it would be very rich at low RPMs and go lean at peak.
TA
Old Oct 6, 2008 | 04:13 PM
Everything Im reading has got something going wrong with; Superram/miniram/stelthram, etc... After looking at anesthes's numbers, I'm seriously thinking of going the same way... It looks good and performs good (It's got some issues, but I'm sure these are fuel pump and tuning issues, as he said.) I'm liking the fact that it didnt cost all that much, and seems to perform well, compared to some of the other systems on the market. I also like the fact its not something you see everyday.
Old Oct 7, 2008 | 01:12 AM
Kevin91Z's Avatar
Unfortunately yes, these TPI parts were created before people knew much about TPI's. They all have issues that require some custom porting to fix.
TPI's strength is torque, not horsepower, so these long-runner intakes are designed to improve torque at the cost of higher rpm horsepower. You need to shorten the runners a lot if you want horsepower.
Old Oct 7, 2008 | 06:44 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Stealth ram is probly the easiest to do between all of the setups. single planes are nice and should beable to piece together a kit but there isnt much of a plenum area for your vacuum lines. I'm not sure how all those will hook up but pricewise it may be same cost as a stealth ram. stealth ram supports 500hp so its not a bad choice.
Old Oct 7, 2008 | 10:26 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
If we're talking naturally aspirated, I would most certainly agree. However, if you will consider running a turbo charger, than the factory TPI setup (albeit ported of course) will do just fine with your particular goals....
Old Oct 7, 2008 | 10:27 AM
I like the looks of the stealth ram, but no egr valve means I can't get past emissions!! LOL, I already have one car that wont pass emissions!! I am hoping that vacuum wont be a problem. Kinda need my brakes...
Old Oct 7, 2008 | 10:38 AM
You can always consider the route that I almost went (and still might), although you'll need to be a little creative though. Was going to run a distributorless LT1 intake (keeping the EGR intact), w/the oil pump drive bolted with a bracket underneath the intake manifold, while running an EDIS-8 ignition system....
Old Oct 7, 2008 | 09:12 PM
If the stock tpi unit cannot be made to work with a naturally aspirated motor then how will it work with 10-15#'s of boost? It dosent make sense...
Old Oct 7, 2008 | 09:17 PM
  #42
Sure it does, it's the velocity of the incoming air that matters, Click Here.
^ That's Tim's car by the way, Click Here....
Old Oct 8, 2008 | 12:02 AM
  #43
So, easier to blow through a straw than suck through it... I get it. I just dont want to buy another tpi setup. ( I just sold the one off my T/A.)
Old Oct 8, 2008 | 09:00 AM
  #44
^ In case your interested though, I recently purchased a complete TPI setup for one of my projects, but I had a change of heart, and stood with the carburetor. I'm getting ready to put the TPI setup for sale. I also have an LT1 intake swap that will be finished soon for sale as well. I'm only asking what I myself paid for the TPI setup....
-Rob
Old Oct 8, 2008 | 09:51 AM
  #45
Thank you, Street Lethal. I just want something different for this car, as I already have a tpi car(86 IROC). I want something that is new and fresh.
Old Oct 8, 2008 | 09:59 AM
  #46
The LT1 setup will be finished soon, if interested, I just didn't drill the hole for the distributor. It'll come with the oil pump driver in the picture, it just needs to be internally bracketed. Either that, or just have someone drill the hole for the dizzy. Comes w/rail and injectors...
Anyways, good luck....
Old Oct 8, 2008 | 09:12 PM
  #47
Thank you, Street Lethal! I'm pretty sure I'm going to go with a single plane.
Anybody got Ideas for a heads/cam setup? Im going to go for a roller setup....
Old Oct 8, 2008 | 09:25 PM
  #48
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Any 190-200 cc head will do. Any of the big name aluminum head makers are pretty good. I like my AFR's they are supporting big power and have room for more with better intake/cam
Old Oct 8, 2008 | 09:44 PM
  #49
Thank you, Orr89rocz! I was thinking AFR or TFS, but wasnt too sure.... What about a cam? I want something aggressive but not to the point it stalls very easily on the street!
Old Oct 9, 2008 | 06:34 PM
  #50
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
keep it around 230 on the intake duration and whatever you want on the exhaust depending on the setup and it should be good to go. I'm running 230 on the intake, .603 lift for my AFR heads and it revs out to 6500 rpm but is tame on the street.
depending on the grind you could go 236-238 without problems
