Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
305 and HSR question
Old May 17, 2009 | 03:03 PM
tpibird's Avatar
Car: 89 trans am
Engine: 305 tpi
Axle/Gears: 2:73
i have an 89 tpi 305 that im working on for my senior project im porting the stock heads and puting in a new cam and lifters and i want to no if i should stick with the stock tpi unit or get a HSR or some other aftermarket intake btw i drag race the car and i would like to hit mid 13 's any feedback would be great
Old May 18, 2009 | 06:53 PM
tpibird's Avatar
Car: 89 trans am
Engine: 305 tpi
Axle/Gears: 2:73
Re: 305 and HSR question
anyone have any suggestions??? i would really appreciate some help
Old May 18, 2009 | 08:28 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Many more will chime in but I think you should keep the original TPI because of the torque on your 305 and spray (Nitrous) it at the track. There are some that have gone 11's and 12's with sprayed 305's (Search it)
I put a HSR on my 357" with a LPE cam and I'm always wishing for more torque..... Don't get me wrong the HSR starts to cover alot of ground once your into some serious RPM, but how often is that???
I'm was thinking about makin a bigger displacement engine (maybe 388) just to get some of that TQ back in the lower RPMs and still scream on top
I'm not sure what kinda cam you were thinkin about putting in your 5.0L but where do you want your powerband???
Lots of variables here.....
Old May 19, 2009 | 05:51 PM
tpibird's Avatar
Car: 89 trans am
Engine: 305 tpi
Axle/Gears: 2:73
thanks for the reply....im thinking about using comp cams 268 xfi cam
Old May 19, 2009 | 08:22 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
XFi 268
Operating Range: 1800-5800 RPM
Duration Advertised: 268° Intake / 276° Exhaust
Duration @ .050'' Lift: 218° Intake / 224° Exhaust
Valve Lift w/1.6 Rockers: .570'' Intake / .565'' Exhaust
Lobe Separation Angle: 113°
I think that it's a large cam for a 305.... Not only is the duration a little high (read below...) But those valve lifts are BIG and you'll have to make sure your "worked over stock heads" can handle that kind of lift #'s...
My Lingenfelter 211/219* duration with .536"/.560" lift is sluggish in the lower RPMs (below 3000) like I have mentioned.... nothing a higher stall couldn't handle though I guess
Read
https://www.thirdgen.org/mods3
https://www.thirdgen.org/mods2
Old May 19, 2009 | 08:44 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
Thats entirely to much lift for those heads...most likely they will max out on flow in the
.500 -.510 range even with the porting. The valve guides would have to be cut down and alot better spring used...i just read you info says you have 2.73's in your car also....you'd need 3.42's or lower to really get into the correct rpm range for this cam. Sorry...but its better to find thing like this out now...
Old May 19, 2009 | 09:36 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
A big duration cam and a big breathing intake on a smaller motor just doesn't add up..... make as much torque as you can especially with those tall gears.... I think that you'll have more fun with it myself....
and when it comes to racing it.... the torque will get you out of the hole and the nitrous will help pull those gears though to the finish line.
Having those 2.73 gears is like starting your Mountain bike in 21st gear. But with enough power down low to get you started.... you can fly like the wind on the top end right....?
Have you looked at......
08-408-8 - Comp Cams 'Xtreme Energy' Hydraulic Roller Camshafts Details
Chevy 305-350ci Small Block 1987-98
For engines originally equipped with a hydraulic roller camshaft, except LT1 and LT4.
Strong torque, good mileage, stock to mildly modified combinations.
Operating Range: 1000-5000 RPM
Duration Advertised: 258° Intake / 264° Exhaust
Duration @ .050'' Lift: 206° Intake / 212° Exhaust
Valve Lift w/1.5 Rockers: .480'' Intake / .487'' Exhaust
Lobe Separation Angle: 110°
OR
08-412-8 - Comp Cams 'Xtreme Energy' Hydraulic Roller Camshafts Details
Mild performance applications, very good mid-range, 3.23-3.73 gears.
Operating Range: 1200-5200 RPM
Duration Advertised: 264° Intake / 270° Exhaust
Duration @ .050'' Lift: 212° Intake / 218° Exhaust
Valve Lift w/1.5 Rockers: .487'' Intake / .495'' Exhaust
Old May 20, 2009 | 07:28 AM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
Something else i just thought of...for as much changeing as your gonna be doing im hopeing your into burning your own chips or know someone that is...cause your stock tune wont work
Old May 20, 2009 | 07:13 PM
tpibird's Avatar
Car: 89 trans am
Engine: 305 tpi
Axle/Gears: 2:73
thanks for the info guys.....i planned on swapping the 2.73 's for 3.73's sorry i should have mentioned that before and GTA Sammy im thinking about using the 8-412-8 Xtreme energy cam you suggested it seems like it will work in my engine better then the 268xfi
Old May 20, 2009 | 10:29 PM
BANDITSBC's Avatar
Car: 90 gta
Engine: 5.slow turbo
Transmission: tremec tko
i just installed the STEALTHRAM on my 90 305 gta. I LOVE IT!!!! I have the peanut cam and it used to stop breathing around 3800rpm with my 2.73's that's still fast. now it revs to 5k and just keeps pulling. i of course am scared of R's since it used to max out below 4k. but it just KEEPS PULLING now. i always thought it was the cam holding it back but it's all that track the air has to go down.
not as cheap as it looks!!! i was disapointed at how much more it cost than i thought it would i think i had about $800 into it by the time i was done with fuel lines fittings, fluids, plugs, ect. but WORTH EVERY PENNY..
I HAVE THE CENTER BOLT WASHERS!!!! i had to buy 50 of them to get a bag, drop me a line and i'll send them to you for like $10 instead of the $70 that wiend wants.
nicest thing is if you ever need to take it off it will take about 1hr instead of 5hrs!
later
Old May 21, 2009 | 10:22 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Originally Posted by GTA Sammy
XFi 268
Read
I had 211/219 cam in my 355 with a stealthram to boot. It wasn't sluggish at all. Idled like stock, didn't feel sluggish at all. I had the standard 3.27's using a S10/Corvette stall. Which wasn't much higher than the F-body stall, only about 2000rpm or so.
Old May 21, 2009 | 10:30 AM
later
Not trying to rain on your parade here, but McMaster car sells a pack of 5 of these for about $6.20. They are aluminum beveled washers. Your $10 is a good deal, as thats about what it will cost to have them shipped if they can't be picked up locally. They worked perfect for me. no leaks at all. I just wanted to make sure this information is out there, as many people end up paying for those super expensive kits to take care of the intake bolt angle issue.
Part# 92810A130
Old May 21, 2009 | 12:37 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Maybe sluggish was the wrong word..... Maybe just not as "responsive" as the TPI set-up.
I have to add that My 357" was running that super small peanut cam 179/194* .350/.394" lift. with the TPI and small "swirl port" 193 heads, which would've made it feel stronger and more responsive on the low-end side than even a stock 350 with stock 89 GTA heads and cam.
Now I'm running the HSR with LPE 211/219 cam on AFR 180 Eliminator heads which aren't quite as responsive in the low RPMs like the last set-up was, but man does she scream on top!!!!
So maybe it was just a larger leap for me..... I just love TQ!!!!
Old May 21, 2009 | 06:21 PM
tpibird's Avatar
Car: 89 trans am
Engine: 305 tpi
Axle/Gears: 2:73
thanks for the reply....did you lose alot of low end after you did your swap...do you have some track times to compare
Old May 21, 2009 | 06:36 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Where in PA are you?
My car was loads faster with HSR than stock TPI on my full bolt on L98 350. Still made 315wtq on a stock motor with exhaust and HSR on a lean tune. Thats not too far off a stock TPI setup. HSR wont make as much peak tq but it will make more torque everywhere else that counts.
If you do throw in a cam, something with around .500 lift is all you want and need, and keep duration fairly low with stock ported heads... 218/224 is a nice big grind for a 305 but the XFI version is too much lift. Try the cc502, same durations with less lift.
That cam and HSR would help that top end alot. Add a good converter and thats all you need to run good times. The converter and gear will make up for any loss of low end. Theres a guy at the track with a carbed 305 with a decent sized cam that gets off the line in a hurry with his auto with higher stall converter. I dont know what he has in that car but it does mid high 12's easily
Old May 21, 2009 | 07:43 PM
tpibird's Avatar
Car: 89 trans am
Engine: 305 tpi
Axle/Gears: 2:73
i live in McClure
Old May 21, 2009 | 07:56 PM
BANDITSBC's Avatar
Car: 90 gta
I think it still feels good down low but being able to rev makes for a great driving experience. i don't have any track times sorry, but i know it's much more fun to drive.
Old May 21, 2009 | 08:27 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
i have my stealth ram on a dart headed 355...im useing the 200cc intake and i dont have any complaints...im running the gm hot cam 218/228 .525/.525...id say im in the low 12's...just need to get to a track to be sure
Old May 21, 2009 | 09:39 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Aww, your way east of me, probly 3 hours. If you were closer i'd be glad to help with any tuning
Old May 22, 2009 | 12:50 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
What you smoking brother....?
.... I could have my TPI setup off in fifteen minutes. The only real benefit of the HSR is the location of the fuel injectors when replacing them, but then again, a gasket set for the upper TPI plenum is only about $15.00 anyway, so it's just a minor delay.
Old May 22, 2009 | 02:27 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
I don't know about the HSR on a 305, but on my 350 there is more than enough torque to blow the tires away in first and a lot of second gear. I'm going to the dyno this afternoon, so I'll report back on "loss" of torque.
Bill
Old May 22, 2009 | 07:33 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
tpi's are like a big bottle neck for a 350....the stealth ram lets them breath!
Old May 22, 2009 | 10:28 PM
BANDITSBC's Avatar
Car: 90 gta
i'd like to see you get the distributor out in 15 minutes! jk
Old May 23, 2009 | 10:14 AM
I'm actually leaning toward a Stealth Ram myself, getting really tired of looking at the TPI....
Old May 24, 2009 | 02:39 PM
BANDITSBC's Avatar
Car: 90 gta
look so much nicer, will look real nice when i get the turbo on.that will definetly be next year, i just HIT A DEER friday and have the HOT ROD POWER TOUR next week... have an extra rt headlamp and fender laying around???? got into my car after work and the door handle broke off... ahhhhhhh went from show quality to parts car in 1 day!!! guess i should have done those door bushings last week like i was gonna.
Old May 25, 2009 | 06:55 PM
tpibird's Avatar
Car: 89 trans am
Engine: 305 tpi
Axle/Gears: 2:73
thanks for the replys im still new to this so it helps out alot.....well i think im gonna stick with the tpi and buy a nos kit
Old Jun 6, 2009 | 04:19 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Seem to be getting some decent info among the banter. In my 305 bird, I didn't really notice the lose in torque (although it was significant) because I did a t56 swap and 2.73>3.23 swap all at the same time. Skewed the results a little. With an LT1 cam, stock exhaust manifolds and completely stock tune I put down 226 to the wheels. Long tube headers and decent exhaust put me about 240 rwhp. I'm sure with a matched cam, you'd do fairly well. My torque was way low though I think 270 IIRC?
Of course the only reason I spent any money at all on the 305 is because all that stuff was CHEAP; $10 cam, $25 headers and a couple hundred on the intake. I love swap meets.
Old Jun 11, 2009 | 04:33 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I have a Stealthram on my stock 305 with headers and a borla muffler and it runs great.
195 RWHP and 273 RWTQ on a 165K mile motor.
http://www.youtube.com/watch?v=rza_uG-ClX0
http://www.youtube.com/watch?v=WpzfLPtvJIk
84z96L31vortec
Aug 20, 2017 12:16 AM
dutch930
Sep 11, 2015 06:58 AM
ASE doc
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
