Another modded Super Ram
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
This is a work in progress.
https://www.thirdgen.org/forums/sout...mare-home.html
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Another modded Super Ram
Looking good. Should run pretty strong. I'm anxious to see your results with the 280 XFI cam and also the results of other members of the california society. You guys have done some impressive things with TPI based systems and keeping it smog legal to boot. I'm impressed.
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
What tools did you use to do the port work? do you have anymore pics of the port work? I just picked up a SR and im lookin to do somthin like this to it! About how many hours did it take to do this?
Check out the video. http://www.youtube.com/watch?v=GglubFHkDFAIt s now up and running.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
How are the bolts threaded? Tap out the runners? What if a bolt comes out and get sucked down? Anything preventative?
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Hmmm... Just went back and looked at the pictures. I am assuming the Lt1 superram plenum? So you are using a bolt and a lock nut? Did you drill out the threads in the plenum?
Nope! Just screwed it in from the top then locking nut at the bottom. This super ram is for the corvette.
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Car: 89 Iroc-z
Transmission: TH400
Car: 89 Formula 350
I think he just used a bin that was in his computer/dyno with the Fast EFI setup. I saw him just looking at bins that matched my cubic inch and injector size.I'm going to have the car dyno chassie tuned again when its in the car with the Tunerpro/prominator. I'll prob just give the tuner guy a ARAP bin to work from and then see what he'll get to the wheels
Car: 89 Iroc-z
Transmission: TH400
Thought you may have started with mine again, just curious
VincentZ28, that car sounds great. That thing will pass smog?
Yes it will pass smog. Here's another video with the idle at 800rpms. http://www.youtube.com/watch?v=HuQNKNyVH9I
Car: 89 Iroc-z
Transmission: TH400
awesome. Next time get a outside the car rev back by the pipes. Sounds pretty deep inside the car, and that responsiveness in the throttle is insane.
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
Holy snappy throttle Batman!!! It does sound a bit choppier in that video than the first.
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Looks and sounds like a very healthy car top to bottom.Good job,post vids of that thing making a pass or a burnout here and there...would love to see how it reacts on the road.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Just another one of my 355 builds that will be impressive at the track.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
So Don, what you are saying is that you control the horsepower output of that motor.
no green
Jan 9, 2016 09:22 PM
Dragonsys
Sep 25, 2015 03:51 PM
