Cant get leaking to stop
Car: 1991 Camaro Z28
Engine: Carb 5.3
Transmission: Th350
Axle/Gears: Moser 12 bolt, 4.11 gears
hey guys im using a set of professional products fuel rails and i cant get them to stop leaking at the ends where you thread in the fittings. i used the white paste type thread sealer and it sat for 2 days before i put fuel to int. what gives? what do you guys use?
Re: Cant get leaking to stop
I have the same product and had the same problem. Turns out I over tightened the connector between the fuel rail and the regulator to the price of a new regulator. I just used teflon tape and snugged not really tightened everything down and its been a few months with no leaks.
Car: 86 Corvette 383
Engine: 383 LPE build
Transmission: 4+3... T56 soon enough
Axle/Gears: 3.07
Run a 3/8 NPT tap and make sure you have clean threads. I had an issue with that once. Then I used teflon tape (wrapped directionally so tightening it doesn't peel it off) and then tightened them down pretty tight. (NPT threads are worthless...I wish my rails were 6AN.)
Good luck!
Good luck!
bubbaz28
Sep 18, 2015 02:09 PM
