Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Modified and new injectors
Old Sep 15, 2010 | 05:29 PM
InjectorsPlus's Avatar
Former Sponsor
Originally Posted by Kawtipping
Some more injector info....LS1 injectors will work with TPI....of course a little modification needs to be done first. LSx injectors are longer (and don't have retention clips on the tops). For my car, we milled down the fuel rail enough to get the rail to bolt to the intake. Not the safest way to do it, and if I were to do it again I would take material off the intake (where the rail mounts). No worries on the lack of clips either. They don't move anymore than the original injectors! Best part is LSx injectors are less money, and have a better spray pattern!!! I will try to get the different flow values for everyone, but I know the dark gray ones are good for mid 30 lb/hr flow rates.
That's a lot of trouble. We just make injectors that fit with no modification and I'd sell them to you for $40 each.
Anyway that aside, ford does rate theirs at 39 lbs....you buy a 19 lb "Ford" injector it's a 22LB "GM" injector. Same injector rated at different sizes.
And finally.....
There's no such thing as a FORD injector.
There's only a few manufacturers of injectors...
Bosch, Seimans, Lucas, Delphi, Denso...one or two others.
A "Ford" injector is simply a Bosch. There is no difference. Don't pay for a name.
I sell a lot of 160 lb injectors and there was a great debate on the "white" vs "blue" top ones.....bunch of garbage. One was made for Chrysler, one for Ford. No difference between them
All that being said, I hope I helped...... I'll be around a bit.
Thanks.
Old Sep 16, 2010 | 12:11 AM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Re: Injector Sizes
$40 a piece ? thats $320 for 8 injectors, thats a rip off.
Thank god for FIC and there awesome customer support and good prices
Old Sep 16, 2010 | 09:33 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Injector Sizes
I usually just buy FMS injectors. I don't trust most modified injectors. Spoke with too many pros like Rich at cruzin performance and it's just not a good idea. The guy at FIC melted down on me more than once. I've purchased used injectors from southbay and got a pretty good deal and they worked fine.
-- Joe
Old Sep 16, 2010 | 10:20 AM
Former Sponsor
Re: Injector Sizes
that's a brand new flow matched set. No so sure how it's a rip off.
I can do rebuilts for 1/2 that price......
Old Sep 16, 2010 | 10:24 AM
Former Sponsor
Re: Injector Sizes
-- Joe
It all depends on who is modifying them and how much experience they have.
Anyone who knows how to do it, it's not a problem
now, I will concede the point that if there's an off the shelf product, then yeah, don't modify. That's not always the case.
Additionally, there's physical modification and flow modification. Well known super chargers by reputable come with injectors, where do you think they come from, they are modified.
Bottom line is if the person doing it is experienced and knowledgable it's not a problem. There's not always an off the shelf solution.
If somebody told you that it's probably because the injectors they got were poorly done, OR they don't know how to tune a car. We put modified injectors on the bench all day long and they run just as accurately as robot made new ones.
Old Sep 16, 2010 | 11:08 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Injector Sizes
I hear you. Just a lot of room for error.
Can you modify TBI injectors? If you could get those suckers to flow 100+ lbs per hour you'd have a market.
This is pretty funny. I make the comment "The guy at FIC melted down on me more than once." I go to lunch, and in my inbox is an email from the owner. Melting down again!
-- Joe
Old Sep 16, 2010 | 11:19 AM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: Injector Sizes
We use a lot of 60lb ls2 injectors for the vettes here in Jersey. I have installed over 50 head, cam mods this year alone. There is no good drop in for the ls2 at 60 rated at 43.5.. The Siemens don't fit[ and they have the wrong plug. I put in the mods from FIC, send him my cores, reset my IFR and the cars run perfect and pass emmisions. I know many shops that use these mods.. We love them, plus it costs a lot less than buying a new set
Old Sep 16, 2010 | 11:37 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Injector Sizes
You can't escape the fact that the guy sells thousands of injectors..
I think I just rub him the wrong way.
Which vettes ? c4? c5?
-- Joe
Old Sep 16, 2010 | 11:58 AM
Former Sponsor
Re: Injector Sizes
-- Joe
Hey Joe, btw, do you have any idea who this is????
I am skunk working TBI injectors this week as we speak. Getting them to 100 lbs is one thing, doing it on 20 lbs of pressure is another.
I'll know by the end of the week. We wasted about 6 injectors trying to do it, we're confident it was more about us being tired than lack of ability.
Give me a week, we'll know.
John
Old Sep 16, 2010 | 12:15 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Re: Injector Sizes
all c6 stuff, there were no ls2 c5's
Old Sep 16, 2010 | 12:31 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Injector Sizes
John
Yeah, why do you wanna buy some AFR heads from me ?
-- Joe
Old Sep 16, 2010 | 12:33 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Injector Sizes
Didn't know if you were retrofitting cars or whatnot. I don't do vettes anymore.
Bought horses and my money went c-ya..
-- Joe
Old Sep 16, 2010 | 12:35 PM
Former Sponsor
Re: Injector Sizes
-- Joe
Absolutely. I'll pick up that imaginary 50 HP...
BTW, you still have that calpack laying around? I'll buy it from you. Sent you an emial didn't hear back. They are getting IMPOSSIBLE to find.
Old Sep 16, 2010 | 12:49 PM
Theking's Avatar
Car: 1989 IROC-Z
Re: Injector Sizes
Didnt see any info about brand new thats why I posted the comment, now we all know they are brand new.
Old Sep 16, 2010 | 03:36 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Injector Sizes
I used it on a '90 corvette a year or two ago.. long gone sorry.
Let me know on the TBI injectors. I have a project in mind.
-- Joe
Old Sep 16, 2010 | 04:42 PM
Former Sponsor
Re: Injector Sizes
I'm looking for a guinea pig... I'll give you a set but you have to report back.
We'll see if it works.
Old Sep 16, 2010 | 05:29 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Injector Sizes
I'd be game for that but it might be a while before I try them..
-- Joe
Old Sep 17, 2010 | 11:15 AM
Former Sponsor
Re: Injector Sizes
-- Joe
HEY! WE DID I!!!
We have tested and verified our new TBI injectors.
These are CUSTOM MADE and gauranteed to work in your TBI applicaitons.
Our injectors come in sizes of 85lbs, 95lbs, 100lbs, 110lbs..
all at 20 lbs of fuel pressure!!!!
Call us for details.
You can not get these anywhere else in the world except IP!
$125 each..
Old Sep 17, 2010 | 11:43 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Injector Sizes
HEY! WE DID I!!!
$125 each..
So the 110s support a little over 400hp.
How much fuel pressure can you run before they become unreliable?
You should post in the TBI forum. A twin 52mm TBI and these should hit around 400hp no problem.
-- Joe
Old Sep 17, 2010 | 02:42 PM
Former Sponsor
Re: Injector Sizes
-- Joe
Great question Joe. We tested them to 30 pounds, ran them 1/2 hour straight no problem
We can get as much as 140Lbs/HR at 30 lbs. We feel confident they will be reliable there. They will become erratic if you go higher.
Doesn't sound like much, but that's a 50% gain in pressure....
Old Sep 17, 2010 | 03:59 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Injector Sizes
As long as the spray is not bouncing off the throttle blades and saturating the air filter, it should be just fine.. 140lbs/hr should handle over 550hp.
-- Joe
Old Sep 17, 2010 | 04:03 PM
Former Sponsor
Re: Injector Sizes
-- Joe
They spray perfectly at that pressure.
Yep, and it's far less expensive than changing everything over to an MPI setup.
Old Sep 17, 2010 | 04:07 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Injector Sizes
My intention is to provide a bolt on solution with guys that have a working carb setup.. Say you have a performer RPM or a victor or something, and want to control your fuel with a laptop but not retrofit EVERYTHING.
-- Joe
Old Sep 17, 2010 | 04:14 PM
Former Sponsor
Re: Injector Sizes
-- Joe
I have one of those. 100% made in America. Bolts right up. We have a tune DONE for the 7747, we provide the chip and everything. All you have to do is add the ECU, they go for about $50.
Is this what you were thinking?
Old Sep 17, 2010 | 07:03 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Injector Sizes
Not exactly, as that is 4 port injectors. How are you driving those with the '747?
I had an idea similar to that a while back, but for a number of reasons it just won't work.
Merged these posts into a new thread as they were not really related to the previous topic.
-- Joe
Old Sep 17, 2010 | 07:07 PM
Former Sponsor
Re: Injector Sizes
I had an idea similar to that a while back, but for a number of reasons it just won't work. I can link you the thread in PM if you wanna talk about it.. Kind of out of the scope of this thread.
-- Joe
Since the 7747 is batch fire, doesn't matter if it's 4 or 8 injectors.
Sure, link me to a place more appropriate.
Old Sep 17, 2010 | 07:13 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Injector Sizes
https://www.thirdgen.org/forums/dfi-...drive-4-a.html
'747 is usually tbi, which fires bank to bank. You guys modifying them to run batch port injectors?
-- Joe
Old Sep 17, 2010 | 07:20 PM
Former Sponsor
Re: Injector Sizes
-- Joe
yep. I don't do it personally. If you want I can get you details on Monday. It works, it's in a lot of cars running around out there.
Old Oct 3, 2010 | 06:58 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Injector Sizes
You get any more info on this for me?
I'm looking for a 4150 solution for a carb motor that I can't dial in.
-- Joe
Old Oct 3, 2010 | 07:13 PM
Former Sponsor
Re: Injector Sizes
-- Joe
I'll have it tomorrow.
Old Oct 4, 2010 | 10:39 AM
Former Sponsor
Re: Modified and new injectors
Joe,
The guys that do this for me have a custom harness. Simple, just plugs right in.
John
Old Oct 4, 2010 | 02:03 PM
Former Sponsor
I didn't mention it because I didn't think it applied, but I also have a 6 injector version if you just can't get enough power out of four injectors...
Old Oct 5, 2010 | 08:16 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'm trying to figure out how you guys are "making it work"..
I'm decent at tuning. but Rbob is the electronics and ECM guru. If you or him can explain to me how it 'works', I'm interested.
Based on a previous discussion with him, I abandoned my idea of running injectors like that because of the reasons listed in the thread I linked you.
-- Joe
Old Oct 6, 2010 | 02:29 PM
Former Sponsor
-- Joe
I called and spoke to them, they "splice in" four caps so you get a 2X2 batch fire solution.
Old Oct 6, 2010 | 05:25 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Using the big TBI injectors like that how are you going to get around the fact that TBI squirt is per DRP and the big injectors will have too small PWs at low RPM cruise and idle? Can these things go sub-500us PWs?
Old Oct 6, 2010 | 05:55 PM
Former Sponsor
That is why RBOB is trying them. We don't know. We will find out. If they work, he gets to keep them, if they don't, he sends them back for a refund. We don't have the R&D resources of GM. We're on a budget... That's about $1000 and it's almost reached...
Idle is always the problem with big injectors.
We can do a lot "in theory" but when it comes to implementation, that's where the rubber hits the road. And remember bigger engines need more fuel to idle, so may not be too much of a problem Bottom line is we just have to see.
Old Oct 7, 2010 | 10:27 AM
junkcltr's Avatar
Engine: 3xx ci tubo
I hope it works out. One of the problems that has plaqued TBI is the available injectors.
Yes, fueling modes need to be more advanced with larger injectors (e.g. bank, SEFI)
Not true. Keep in mind the engines with air compressors feeding the intake. We can run a small ci V8 with a tiny cam and still require enough injector for 800+ bhp. Lots of people with TBI want to try turbo/supercharge, but it is the fuel system that always hold them back from making power. I think a lot of these people would be interested in these injectors.
Old Oct 7, 2010 | 10:44 AM
Former Sponsor
Thanks. I appreciate the input. Just saying that sometimes what looks right in the lab, translates differently in practice. I hope people would be interested. I try to build to niche's...
Old Dec 7, 2010 | 10:21 PM
pmkls1's Avatar
Car: '89 Firebird Formula
I just happen to be in the market for a high flow TBI injector now. I have an '89 formula with the stock l03 305 currently that is converted to run on E85 so I run 30psi pase fuel pressure which is about 22 at idle ( for a better idle) since the regulator is plumbed to intake vacuum. I have 2 vortec 350's sitting in the shop now both slated to be installed in the car. The first I am going to overhaul and drop in bone stock as I need to replace my tired 305 soon, and the second will be built to run 450-500hp and swapped in later. The first and possibly the second I plan to run TBI until I can afford a nice MPI manifold setup. I feel that the stock engine will need more flow than the stock injectors can deliver since I am running E85. I could simply go to 454 injectors for the stock vortec, but the modified engine will need bigger than that for sure and 454 injectors are scarce and cost nearly what you are charging for your units. I will be running a 4bbl style intake on the stock vortec with a TBI adaptor since those intakes are cheaper than a TBI intake made for vortec heads and they also appear to have more plenum volume and better runners as well. Also, does anyone think that with the right injector size and a 54mm tbi unit the tbi unit can handle up to 500hp ? If so then I can focus my money on the engine internals and keep the TBI and convert to MPI later.
Phil
Hotrodboba400
Dec 10, 2019 07:07 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
webeeZ28
Sep 14, 2015 12:00 PM
92rsvortec350
Sep 10, 2015 10:54 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
