Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Stripped Threads... Need help!
Old Sep 20, 2009 | 01:45 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I have the Superram and its sucky design. I have 3 stripped threads in the plenum. How do I go about to fix these? It is Aluminum, and I heard that Helicoils don't work to well. I want to keep the same bolt size, because I don't want to have to drill out the runner holes as well.
Old Sep 24, 2009 | 03:24 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: Stripped Threads... Need help!
Basically, you are saying you dont what to fix it.
I believe that you are talking about the threaded holes in the bottom of the plenum --- the runner to plenum screws that go in from the bottom. You could put a bolt (screw) thru from the bottom and hold it in with a nut inside the plenum,,, make sure that you use red loctite and plenty of it. If the nut comes free, its going to go into a cylinder.
The best way is to go up in size to the next larger English or metric size thread, and put it in from the bottom; retap the hole in the plenum, and drill out the hole in the runner (which you said you dont want to do).
Old Sep 24, 2009 | 03:41 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
If I drill it out bigger, then I would have to drill out the runner, which I have no problem doing. It is the fact that if I go with a bigger bolt, then it wont fit, as the head of the bolt would hit the runner and not allow me to tighten it.
I think i am going to end up helicoiling it.
If I were going to use a bolt, I would weld them to the runner, and have the head of the bolt coming from the top, but it doesn't seem very reasonable and kinda risky at that.
Old Sep 24, 2009 | 03:56 PM
Twin_Turbo's Avatar
Get some timeserts. Much better than heli coils.
Old Sep 24, 2009 | 04:38 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Do you have a link, so I can check them out? I have never heard of them.
Old Sep 24, 2009 | 04:43 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Cool. Just looked them up. I think I am going to try them. Anyone else think they will work well?
Old Sep 24, 2009 | 04:44 PM
Twin_Turbo's Avatar
http://www.timesert.com
Once you have used those, you'll never want the heli coils ever again.
Old Sep 24, 2009 | 05:12 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
So once I thread them in, I don't have to worry about them coming back out when I install and remove bolts?
Old Sep 24, 2009 | 05:20 PM
Twin_Turbo's Avatar
No, the last few threads are cold rolled and as such actually too tight. When you use the install arbor to thread them in, once the insert bottoms out when the top mushroomed part hits the bottom of your countersunk section the insert won't thread down further, the install arbor will thread tightly into the inserts expanding the last couple of threads, anchoring the insert in place.You will feel this when the install tool becomes harder to turn and then loosens up again. It'll never come out again.
Old Sep 24, 2009 | 05:22 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Cool. Thanks
Old Dec 8, 2010 | 09:41 AM
AJ87CAMARO's Avatar
Car: 1987 Camaro
Engine: 5.7 TPI
Which size did you use I know in is the M8 correct? Is it 1.25 or 1.75? Thank you
Old Dec 8, 2010 | 04:19 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
wow i like that idea. might have to do this myself!
Old Dec 8, 2010 | 05:13 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I ended up finding a brandnew plenum for 100, so I went that route.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
Amillionoh7
Sep 5, 2015 11:44 PM
