Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Big Block tunnel ram conversion (was: initial foam mockup)
Old Oct 3, 2010 | 04:11 AM
The_Punisher454's Avatar
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
I'm starting a tunnel ram PFI conversion sometime in the next couple of weeks and thought I'd share a couple of pics here.
The engine is a mostly stock oval port 454, with a mild Voodoo cam (60202).
The intake is an Offenhauser oval port tunnel-ram with a single carb top.
I'm about to cut the top off the plenum and start fabricating a new top. The throttle-body is an 85 or 90mm from a Q45. The TB has a nice progressive cam and roller setup similar in function to some progressive secondary Holley double pumpers.
This was just a quickie foam-board/hot glue mock-up. I already know its really crooked and off center. I think I'll probably do the final aluminum version straight and symmetrical
I'll post some progress pics here soon.
Attached Thumbnails Big Block tunnel ram conversion (was: initial foam mockup)-100_2290.jpg   Big Block tunnel ram conversion (was: initial foam mockup)-100_2292.jpg   Big Block tunnel ram conversion (was: initial foam mockup)-100_2293.jpg
Old Oct 5, 2010 | 07:26 PM
Cg-OneSic89's Avatar
Car: 1984 Z28 L69
Engine: Cammed 350
Transmission: Tremec Tr-3550
Re: initial foam mockup of tunnel ram conversion
I probably would point that throttle body down some to help with hood clearance and lining it up with an intake tube. Just a thought
Old Oct 6, 2010 | 12:03 AM
I don't have to worry about that. This is going in my dads 53 chevy pickup, I'm actually thinking about making it an inch taller. I was going to do double downdraft throttlebodys, but he wants to turbocharge it later and will have a front mounted intercooler(someday).
Anyhow there's probably going to be about a foot of hood clearance.
I am planning to start cutting this coming weekend, I'll post pics of the conversion.
BTW, one cool thing about these oval port tunnel rams like this is that the outer wall of the runners near the ports is REALLY thick. They apparently use the same outer mold as the rectangle port version. I can probably drill the injector ports without adding any material to the manifold.
Pics to follow next week.
Old Dec 11, 2010 | 03:19 PM
ok, its a little past "next week" but I had a brief chance to work on the manifold a few days ago. I cut the top off the plenum and strted to cut an opening on the front. I have the aluminum cut out for the new top, and hopefully I'll get some time to weld it up before christmas.
Anyhow, I wanted to show what the inside of an Offy tunnelram plenum looks like. Please ignore the really messy garage in the background.
Attached Thumbnails Big Block tunnel ram conversion (was: initial foam mockup)-100_2312.jpg   Big Block tunnel ram conversion (was: initial foam mockup)-100_2313.jpg   Big Block tunnel ram conversion (was: initial foam mockup)-100_2314.jpg
Old Dec 11, 2010 | 03:20 PM
and three more.
Attached Thumbnails Big Block tunnel ram conversion (was: initial foam mockup)-100_2315.jpg   Big Block tunnel ram conversion (was: initial foam mockup)-100_2316.jpg   Big Block tunnel ram conversion (was: initial foam mockup)-100_2317.jpg
Old Sep 30, 2011 | 05:13 PM
Its been quite a while, but I was able to get some time to work on the manifold recently.
I changed the design a bit.
Instead of using an 80mm Q45 throttlebody I'll be machining a custom 2bbl throttlebody. I now have occasional access to a few Brideport mills and Clausing lathes so a custom throttlebody seems rather practical now.
Attached are some images which include the current test mockup in the truck, which has changed to a 54 cab on an S-10 frame, and its my project now rather than my dads, since we are build him a Corvair with a 3800sc and transaxle.
I'm going to cut off about an inch from the front of the plenum and make the backside flush. The welds around the sides and bottom will be built up a little then ground flush and polished smooth, while the weld in the top seam will be left as-is.
Injectors are next.
Attached Thumbnails Big Block tunnel ram conversion (was: initial foam mockup)-000_0001s.jpg   Big Block tunnel ram conversion (was: initial foam mockup)-000_0002s.jpg   Big Block tunnel ram conversion (was: initial foam mockup)-000_0003s.jpg
Old Sep 30, 2011 | 05:28 PM
3 more images.
Not too proud of the weld quality on the sides, especially the pass side weld. I started with the top weld then did the drivers side and the the pass side. My Mig was having feed issues that progressively got worse as I went. I decided to stop and finish later with better equipment.
Attached Thumbnails Big Block tunnel ram conversion (was: initial foam mockup)-000_0004s.jpg   Big Block tunnel ram conversion (was: initial foam mockup)-000_0005.jpg   Big Block tunnel ram conversion (was: initial foam mockup)-000_0006s.jpg
Old Sep 30, 2011 | 05:36 PM
Project-RS's Avatar
nice fab work, i was going to say, having the tb downwards still wouldnt clear a factory camaro hood. im running a dual carb tunnel ram in my 89 rs and its just shy under 13" above the factory hood......lol
Old Sep 30, 2011 | 05:44 PM
Big Block tunnel ram conversion (was: initialfoam mockup)
Just about any other vehicle from what I'm using would be a waste of time to worry about hood clearance. It actually fits under the hood on this with room to spare, but I'll still have 2 openings anyhow for the twin turbo's
Old Sep 30, 2011 | 08:46 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Big Block tunnel ram conversion (was: initial foam mockup)
Coming out real nice, subscribed....
Old Oct 17, 2011 | 10:54 PM
huskybruiserjr's Avatar
Car: 1989 RS
Engine: 2.8
Transmission: auto
i have a weird idea for a small block intake lol kinda like this but not lol
wanna make it for me? lol
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Stangski09
Nov 14, 2015 01:27 PM
Nick McCardle
Sep 10, 2015 08:36 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
