Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
HSR on carbed 327... worth it?
Old Nov 17, 2010 | 12:06 PM
veritas91's Avatar
Car: 1983 Firebird
Engine: 327
Transmission: 5 speed, stock
Right now I'm looking at using the HSR set up on my carbed sbc 327 in my83 bird. Its built, has the double hump heads and is cammed pretty heavy (almost too heavy). I found this in the classified section and was wondering if what I would have to gain from using this setup.
https://www.thirdgen.org/forums/engi...tealthram.html
Also what would I need beyond what is in the add to run the HSR.
Old Nov 17, 2010 | 06:02 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: HSR on carbed 327... worth it?
A computer / wiring harness , EFI fuel pump and a return line to tank for starters
Old Nov 22, 2010 | 07:16 AM
stealthroc89's Avatar
Car: 1989 IROC-Z
Engine: 355, 6.0 (LQ4) soon
Axle/Gears: Borg Warner 2.77 for now
If your going to salvage most of the efi parts of a tpi 3rd gen you need to decide which metering system you want, mass air or speed density. I'm not going to get into which is better, do a seach on that, theres plenty of info covered on that topic. Also, try to get the parts off a 350 tpi model, they use bigger injectors (22#) which should be enough to hold you over untill you can upgrade, if your in a rush that is.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
hotrod1988
Sep 11, 2015 04:39 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
