PCV Routing on an HSR swap? Help please.
Car: 1985 Chevy Camaro Z28
Engine: 5.0 LG4
Hi!
I currently do not have ANY PCV valve setup on my HSR swap...just two breathers. I want to get the PCV working again.
* Any suggestions on routing, connections, etc? Your input would be greatly appreciated. THANKS!
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: PCV Routing on an HSR swap? Help please.
the one on my passengers side goes to my TB
and the drivers side goes to the back of the plenum
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
can use the back of the HSR plenum or use the underneath plenum port thats in the middle. I used the back ports for brakes and vacuum ports for the FPR and cruise/misc ports. I ran pcv like factory TPI setup to the middle plenum port, but had a breather on the passenger valve cover.
