Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
More flow
Old Aug 26, 2011 | 09:14 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
More flow
Hi guys,
I did some searching on here but couldn't find anything. I'm thinking about upgrading my Dart Iron 180cc heads to an aluminum 190-200cc head (maybe Dart Platinums, AFR, etc). My question is, given my HSR and combo in sig, would going from a 180cc head to a larger 200cc head affect my low/mid range throttle response? Particularly torque?
Thanks!
Old Aug 26, 2011 | 04:05 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: More flow
Originally Posted by formula_novice
Hi guys,
Thanks!
Not enuff to get worried about it.. gears make up 4 that, I'd use 210s
Old Aug 26, 2011 | 06:19 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Re: More flow
When I was looking for heads and was looking at the dart heads I believe there own site stated that the 180's you have flowed as well as the platinums.
Old Aug 26, 2011 | 11:42 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: More flow
Which 180CC heads are we talking here, because that makes a huge difference..
Old Aug 29, 2011 | 10:36 AM
Re: More flow
Thanks for the replies, guys! My current Iron Eagle 180's seem ok but I was thinking I might get more out of my engine with a set of 195/200's. I'm just a little nervous about giving up any further low-end torque (since I gave up some low-end torque with my HSR).
Old Aug 29, 2011 | 07:40 PM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Re: More flow
IE are awesome heads. I went with the 200's. It's all in the application. People say "you'll lose all kinds of torque" but that's a load of crap. You won't lose anything if you just match your parts correctly.
Old Sep 1, 2011 | 10:13 AM
Re: More flow
Thanks guys! Sounds like the 200's might be a better way to go. Delta, did you go with regular IE heads or the newer platinum's?
Old Sep 1, 2011 | 01:44 PM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Re: More flow
I went with the regulars. Platinums are great, but the old(er) 200's are awesome also. Like I said - just match your whole combo and you'll be fine. I'm running a XE274 / 1.6 RR's with my IE 200's with an airgap RPM and Quickfuel 750 for reference.. so not terribly far off from your current combination.
Old Sep 5, 2011 | 07:27 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Re: More flow
I was told a long time ago by a man named John Lingenfelter to go for the cylinder head that has the best flow with the smallest intake runner (relative).
My opinion, AFR 180.
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
dusterbd
Sep 29, 2015 08:40 AM
84redta
Sep 19, 2015 09:58 AM
