lt1 intake on 1gen sbc i want a miniram
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
I want a MINIRAM but ran short on money I an pay up to 800 shipped I don't need injectors or tb
I was looking at the lt1 intake to see what has to be done..... a lot a hole for the dizzy the bolt and lock for the dizzy and bolt pattern for older style heads. Is it worth it. I seen a new 1 for 120 complete what more needs to be done
Car: 85 IROC
Engine: 385AFR head, Mini Ram Intake
Transmission: 6 Sp.
Re: lt1 intake on 1gen sbc i want a miniram
I have LT1 heads and intake set up for gen 1 blocks. I went a different route so there just taking up space. I would sell for $400 for everything
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
i could see someone doing this on a 350 but a 305 no. but your car i guess
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
The LT1 intakes are nice, but the main downfall at least for me, it that you also have to run a remote stat because there is no provision for it. It adds cost and more clutter under the hood. I know they are out there already converted, just make sure it looks like they were done correct.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
What mods have you got to support a MR / LT1 style intake on a 305?
https://www.thirdgen.org/forums/post...428-post2.html
Going to want to pulls some big revs in a 305; given a MR will go well past 6K on a 350 or larger engine
and you will loose bottom end more on a 305 .
No throttle response and lack of power below 2500 =pig
Plan on a zz4 cam or close to that I have zz4 heads the intake is just to carry over to the 383. I don't want a lt1 or any other my money my build my car. Just looking for a 300 hp 305
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
i mean i was dumb about 305s too and i got good numbers out of it but then you look at or start building an engine with more cubes and you just realize what you did was stupid. why not build a 383 now instead of wasting money
I dnt have 6k to do it and I won't take no short cuts. Why do most ppl say the are modding they 305 cause they don't have the money or means to
As far as LT1 intakes go, might as well just go HSR. It's gonna cost the same anyway, plus there's quite a bit of work involved. I looked into that route when I was planning my 383 build. I ended up going single plane. They all cost the same, and the single plane will outperform the others (I guess that's an opinion, but I have great throttle response down low, and she keeps pulling to 6000rpm).
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I have the converted LT1 intake on my car right now.
It is great, but what would you be willing to spend to buy a LT1 intake that is ready for a sbc1?
Idk I will just stick with my new ported tpi set up if I don't run across a hsr or mini ram I will start to look in to used afrmrk runners to match. I can't wait till I get the money I want to do the 305 just to say to more ppl "its a 305" I know all the reasons to why a 305 is a bad idea to build up but who cares its my car if I wanted to do a iron duke with bolt ons so be it just enjoy the show. I just want a 300hp 305 for kicks like when honda ppl mod D15 honda has way better motors
LT1Formula
20
Nov 14, 2015 12:02 AM
