Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
new engine, super ram build Need input.
Old Apr 3, 2012 | 08:58 PM
resop27's Avatar
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
Well sadly I got my car running for the first time in a year, And it had a terrible vibration. Well after alot of headaches It turned out to be a bent rod.
So I'm going to go bigger.
the plan is a 383
around 9:5, 10:0 compression Have to be able to run on 93 octane.
the cam is being reused its a comp cams 08-501
heads are undecided... 180cc, 195cc? 64cc combution chambers with 2.02, 1.60 valves
I'm not going for anything crazy just something I can drive has a good amount of power(when needed)
itll be an eagle rotating assembly.
I'm really just trying to figure out what would work well and what wont.
Old Apr 4, 2012 | 08:13 AM
efiguy's Avatar
Re: new engine, super ram build Need input.
the plan is a 383
What are you controlling it with?
Old Apr 4, 2012 | 08:46 AM
resop27's Avatar
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
I'm thinking ebl but looking at other possibilities
Old Apr 4, 2012 | 11:32 AM
efiguy's Avatar
The better/more capable the system will allow you to cam it with the right cam for the combo, not because of the fact you have an EFI'd application.
Old Apr 4, 2012 | 07:15 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
What's your budget for the heads? Aluminum or cast iron?
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
L98GTA87
Aug 11, 2015 06:55 PM
bryan623
Aug 10, 2015 11:33 AM
