TV cable misalignment with HSR
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1986 z28
Engine: 350 hsr
Transmission: probuilt 700r4/edge 2800
Axle/Gears: stock 4th gen 3.23
I was wondering if anyone else has experienced a misalignment in the tv cable when running a HSR intake and 48mm throttle body as mine seems binder when adjusting it. As I rotate the throttle to WOT it comes to a stiff spot until you push harder then makes one rough click. Cable is new an routed as straight as space will allow.
Re: TV cable misalignment with HSR
There should only be an issue if the spacing between the throttle body and the bracket has changed and cannot be accounted for by the cable.
Did you come from TPI, or from TBI?
TPI the cable should work directly. TBI might require a TPI style cable. Do NOT go aftermarket with this, I remember trying 3 or 4 cables before just getting a GM cable from a dealer. The TV valve is something that must be set perfectly, and not "close enough".
Car: 1986 z28
Engine: 350 hsr
I'm swapping from tpi and I'm using a gm style cable bought from a dealership.....it would seem as if the throttle body is too far towards the passenger side. Length wise is fine but where the throttle body is pulls the cable more towards the passenger side. Maybe holley solved this with their throttle body?
![](https://farm9.staticflickr.com/8070/8186512236_c93bcf97c5_o.jpg)
If it isn't, then either the transmission is going, or the cable is incorrect.
Car: 1986 z28
Engine: 350 hsr
This is the method I use to set mine as well.... When I do the ratcheting mechanism gives two pops instead of clicks as if it just broke free from something. This is my second new tv cable and the transmission was just rebuilt using a pro built street strip kit.
Z28/ZR1
10-23-2015 01:04 PM
TMZIrocZ350
10-07-2015 12:09 PM
