Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
New Build Comments and suggestions.
Old Jan 4, 2015 | 09:24 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
I met with a local engine shop to go over a build and this is my list so far
Bore my 350 4 bolt block to a 355
new bearing and plugs
cast steel crank
forged pistons and rods CR to be around 9.6
AFR 1040 or competition port heads not sure of number on those
1.6 rockers
XFI 280 flat tappet cam
HSR intake port matched to heads.
Will be using 1 3/4 long tubes and 2600-2800 stall converter.
I am looking for 400-450 HP with ok street manners. I think this would make a great combo. Any suggestions on changes or improvements to get more out of it are welcome. But I am looking to keep this build under 4k and reusing some parts i already have.
reusing
stock 48 mm throttle body should be enough??
ford svo 24lb injectors may have to go to 30's ??
Old Jan 6, 2015 | 10:59 AM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: New Build Comments and suggestions.
you need a 58mmTB. You will need 30lbs injectors. Get the compression up to 10.5. Use 2 valve relief pistons and a .028 thickness head gaskets.
Old Mar 21, 2015 | 09:08 AM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
what will you be using to tune it?
Old Mar 21, 2015 | 01:39 PM
seiplentz's Avatar
Car: 85 Z28
I have a Holley commander 950 setup.
I also changed things up a little. I am buying a 383 crate motor from ATK and they will install the XFI 280 cam for me when they build it for only a little more $$
Old Mar 21, 2015 | 03:07 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Good idea to go 383.You will love the torque.With the rest of your parts you will have a very strong motor.Better beef up your brakes.
Old Mar 21, 2015 | 08:25 PM
VincentZ28's Avatar
Now you be in my power range.
Old Mar 22, 2015 | 08:56 AM
seiplentz's Avatar
Car: 85 Z28
Yeah I hope to be close to the 500HP mark with that engine!! They are doing all forged internals for me as well and its less then my local engine builder and I get to keep my existing engine.
Old Mar 22, 2015 | 10:04 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
Sounds like a runner
Jorlain
Oct 8, 2015 01:57 AM
RedLeader289
Sep 23, 2015 06:50 AM
BWilcox
Sep 20, 2015 12:19 PM
amcnellis
Sep 16, 2015 04:16 PM
