View Poll Results: what manifold for Vortec 383?
SLP runners and Vortec base
0%
Multiple Choice Poll. Voters: 16. You may not vote on this poll
383 with 170cc E-Tec vortecs thats carbed wanting injection opinions wanted
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
1987 Trans am, was 305 4 barrel when I bought in 91, when 305 died I went 350 now a 383 with E tecs and its still CC Q-jet! mileage went down the larger the engine became and now the carb is giving me issues, I always wanted to go injected that said now I'm thinking what way, Ramjet intake is simple but boring looking can do TPI with SLP runners and Vortec base or Super ram - I always like the way both look SLP+SR
I build the engine for torque and had to pass emissions and it passed when it was first built. Now the car is older than 25 so goodbye emissions! I do have a hot cam I could run but that's a later option.
Looking for Y'alls thoughts on what intake and why for my application and also engine harness/computer options used OEM? A/M? I have to say I am nit a computer guy like what chip and all that
vehicle also has SLP 1 3/4" headers dual cats and 2 OTL exhaust
Re: 383 with 170cc E-Tec vortecs thats carbed wanting to injection opinions wanted
The 170's may be a tad small for a 383. It'll be fun for sure. ....problem with TPI or Superram is that they would require the vortec base, and it flows bad out of the box, and you're limited on how extensive you can port. I think it barely outflows the stock base. I'd do it on a 350, but not a 383. I'd either go with a carb style throttle body and manifold, or a stealthram.
As for the computer side of things, I've been very impressed with how the Holley HP EFI has performed on my 383. Ain't cheap, but for someone who didn't know EFI tuning like myself, it was great. Self tune did a great job, and the tech and community support out there for taking the tune further is awesome. Definitely other options, but I couldn't ask for more, and have been totally happy with the Holley. -buy the software and harness kit with the Stealthram manifold and save a few bucks.
As for cam....I'm running a Voodoo cam that's just a tick hotter than that Hotcam you've got. I'd definitely at least run that hotcam. It'd be a good match for those heads, but I don't know that you'd be fully taking advantage of the extra cubic inches.
Car: 90 Formula 350
Abubaca thanks for taking your time hind-site being 20/20 I should of got the 200's Etecs cam in engine now is ZZ4. I woulda thunk the Vortec TPI base was like Accel and other "big" port lower intakes? another option is I have a set of fastburn heads I can swap BUT they are angle plug and I doubt they will work with the SLP headers- hell, the straight plugs barely work with these headers
I don't think Stealthram will fit on Firebird?
I'm running 180cc heads on my 383. I chose 'em on a smaller side because I was going to be running a TPI. I'm kinda sentimental like that, but it's defintely not the ideal intake. Still....wanted to choose heads and cam to match, so didn't go huge. I really liked the zz4 cam on my L98 350, but it's a little small for a 383 I'd think. I'm sure the 170's would be fine, but they'll add torque and limit upper RPM horsepower. I have more torque than I could ever want, but only rev to 5000. It's a trade off. It's fun, but won't win a drag race, lol.
Yes, you would think the vortec TPI base woulda been better. It's not. I believe it had to do with the slightly raised ports and the way Edelbrock did the casting. I think it IS physically bigger than stock, but the flow definitely did not improve much due to the shape of the runner. There's flow numbers on TGO somewhere, but it's been awhile since I've looked. Keep in mind even the regular aftermarket bases weren't great, although they were a good bit better than stock. The magic in these bases is the potential for porting. I'm running a stock base, but it's been extensively ported. I have some side by side pics with the Edelbrock base, and mine was noticeably bigger, even without measuring.
I have SLP headers with angled plugs. It sucks. I have to loosen the header to remove the #8 Plug. ...and it's so close, I have to change the boot and insulator cover once a year because it burns up. The other plugs aren't bad though. Eventually I plan on changing to Dyno Don's headers, but now....they work.
As for intakes and your hood.....maybe the Edelbrock pro-flo xt? Mini-ram? Carb style EFI throttle body on a single plane???
Car: 90 Formula 350
Re: 383 with 170cc E-Tec vortecs thats carbed wanting injection opinions wanted
I've been doing more looking since your first post, I see what you mean about the Vortec lower I may pass on one I found locally. I also have a lead on an Accel lower that I'm interested in. The Pro-flo I found is too tall to fit
and the HSR vortec is only available as complete kits and the Weiand version isnt available either - Damned if I do and don't! starting to think about having carb done by Sean Murphy induction may be the ticket and alot less work and $$$
Well I'm an EFI fan, but I get what you're saying. Definitely easier to keep it carb, lol. All depends what you want. I always hated how back in the day no one knew how to work on EFI, so you'd have all these beater thirdgens with EFI engines that guys pulled the intake off of and installed a carb. ...and mine was also an original EFI car that I learned to work on, so I really wanted to keep the EFI. -and once you know how to use it, it really is better. However.....had mine been carb to start, and I knew how to work on it, heck yeah, probably woulda kept it that way!
What are your reasons for going EFI?
Car: 90 Formula 350
So i went to SDPC and they still list manifold stating:
"In house testing has proved a gain of 40 horsepower over a stock
L98 engine. The larger runners of the TPI Vortec Baseplate combined
with the excellent flow characteristics of the GM Vortec heads
produced 300 hp on an otherwise stock L98 engine"
I'm buying the manifold I found anyway but think best think may be the vortec HSR but IMO they're fugly. I haven't seen much on the Ramjet either looks like another better option than any sort of modified TPI -base, runners
anyone know if Ramjet will fit under Firebird hood
It'll fit....and it'll run well....and it'll be fun, so depending on your goals, it may not be a bad option. .....but you're definitely gonna hold the back the potential of that engine.
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Go Miniram. It will fit under you old with no problems and it’s one piece assembly. They make them for Vortec Heads. If you want to stay Vortec style, go with the E-TECH 200 with a larger cam than the LT4 Hot Cam.
Carb style EFI throttle body on a single plane.
How about vortec carb base and TBI like holley sniper or fast EFI?
Car: 90 Formula 350
So what they do is tweak the test to favor their product the most, and hurt the stock engine the most. Very common tactic. Now don't quote me on this, but if I'm not mistaken, they also used long tubes in that test. ...and with the vortec heads they got great numbers. ....and since they have to test back to back, they run the old crappy 083 TPI heads the same way, which don't flow enough to make HP, and the longtubes kill any torque it woulda made. Know what I mean? Not a fair fight, but the frame it as such. Kinda like when TPIS said the Miniram made 90 more HP over stock. What they do NOT tell you is that it was at 6000 RPM. Well no sh**.....the stock TPI won't rev that high. At 4800 is was probably a LOT less...and at 3000 the stock TPI was probably HIGHER. Regardless.....sure, 300 is good for a TPI, but did that vortec base hold it back? I GUARANTEE it did. Man, not trying to come off too strong, but you can never go buy manufacturer literature. ...and the guys here who have flow tested, and by those who have used them, I can tell you they are good....not great. On a 383 you're gonna suffocate that engine with that base.
Vincent, where would one find a vortec miniram? they still sold new?
after more looking evidently the ramjet has hood clearance issues on Firebird
wonder if anyone has milled the top of base on stealth ram to get it to fit Firebird? that seems simple enough (seems and really are 2 different things)
Oh I found a chinese Vortec stealth ram base on Epay but no top? where would that have to come from?
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
The only company that appears to make one is Fast and it costs more than the whole Sniper system does.
-- Joe
Car: 90 Formula 350
OK so we know the Super ram will fit under hood, what about a Ramjet or Edelbrock pro flo - on a firebird without cutting under hood brace?
or am I doomed to swap heads to go with a good non vortec base?
Car: 90 Formula 350
I found a nice Vortec base and bought because was cheap I'm leaning towards the Edelbrock Pro-Flo but havent seen any proof of fitting Firebird w/o cutting the bracing on hood or any pics of what had to be cutout
Car: 90 Formula 350
OK my options are getting bigger, I now have a Vortec TPI base and and ACCEL base in house and I have to admit I'm thinking more along lines of a Super Ram for this for couple reasons 1) the power capabilities I know they are a PITA to work on but this is a 3rd gen ain't much easy on them under hood anyway right? and 2) the looks great compared to other options IMO. Miniram would be OK but they're scarce so not much to contemplate if you cant get one. I also like the SLP runner look not sure how power would be compared to S/ram but would be cheaper than the pizza box and I have most of what I need to complete with just the runners (dammit I had a set about a year and half ago and I sold them cheap oh well live and learn) I recently acquired other items for my car- a SLP dual air intake and a dana 44 so stay with SLP theme (already have their full exhaust) and find a set of runners or go big with SR ....
Car: 90 Formula 350
figured would never mess with TPI again so now I've regressed so I'm just looking around to see whats out there Its a shame no one made these runners
I’ve worked on a lot of folks cars building engine, adding performance parts, and worked on a lot of computer controlled carbs back in the mid 80s and early 90s. A couple were even running mid 12s. In fact, I’d rather run a tricked out computer controlled carb over any of the aftermarket vacuum carbs. The only real carb “upgrade” in my opinion is an annular discharge double pumper. Those can give fuel injection throttle response with the right combination and aren’t nearly as bad on mileage than those that have never run one set up right will have you believe.
That said, unless you go with a longer runner intake system for enhanced midrange performance, there’s no real performance advantage going with fuel injection. This is especially so with the units that don’t incorporate computer controlled ignition tuning. Where most of the added drivability comes into play for EFI systems is center around the computer controlled ignition. Now, cold start and in areas where there are big temperature swings there are advantages to EFI, but the computer controlled carb takes care of the varying temp swings for the most part and if the choke is set right, cold start and drivability isn’t that bad for that long either.
If you’ve never had your carb worked by a pro, my vote is for you to get Sean Murphy Induction to work the carb for you and if not already, buy “Rochester Carburetors” by Doug Roe also. There’s a really good section in there about the computer controlled carbs. I never saw a single computer carb that the linkage allowed full throttle blade opening. Setting the linkage, filing the tang on the butterfly flaps and setting the spring tension, and getting the right range on the MC solenoid and rich stop for the primary metering rods on a modified engine are just a few things that you can adjust to dial in and get one of these computer controlled carbs properly functioning.
As other have said the Vortec TPI base has greater flow issues than the standard aftermarket TPI bases. Even then, the regular bases take a good bit of work to get right and can run up a major bill if you can’t do the porting yourself. If you’re going to stick with Vortec style heads and must go EFI, I’d suggest the FIRST TPI system for vortec heads. It can flow more than a fully ported (non-welded) aftermarket base right out of the box – about all it would need done for your combo is a gasket matching. It’s a completely redesigned long runner system and none of the stock type TPI stuff works with it. No fitment problems (just a little taller than a stock TPI) and has a ton of meat in the casting for major porting if you want to go with a bigger set of heads and large cam later. Plus it looks close enough to pass as a “stock” TPI for those not that familiar with them.
Car: 90 Formula 350
BadSS I appreciate your time to explain this, the carb on my 87 started having needle and seat flooding issues so my son rebuilt another CC Quadrajet I had found years ago and was a virgin carb and he's still having issues with this - fact is he owns the car and is tired with it and I'm going to buy it back - hasn't happened yet but will soon I called and spoke to Sean himself as keeping a carb is the easiest thing to do and cheapest, maybe I'm overthinking it its not impressive when you open the hood and see the H/O air cleaner -yawn LOL
I recently bought a 90 formula 350 TPI (just bought it for the air intake ) and no title I'm working on it but I may end up parting car or selling for someone to make race car out of. but it has all the fuel lines and tank ECM and harness - and that's another concern about the tunability of the old ECM/proms I haven't a clue where to start on that I've gotten accustom to the LS ECMs and what they can do/ one thing I haven't looked at is something like a Holley Sniper or similar.
Part of the reason I was thinking F/I was economy- when I bought the car in 91 it was 305 4 bbl with 2.73s and it was at about 20 mpg and as I added more power economy was down like 12-14 mpg
Anyway, I did a lot of research back then and ended up going with the EBL P4 Flash System (linked below). Flash ability, getting a wiring harness and "core" ECM for more or less free, extended 6400 rpm timing table, and control ability for the TH400's electronic kick-down were just a few factors that lead me to go that route. I haven't used it yet, so I can't really recommend it, but it might be worth you looking into.
https://www.dynamicefi.com/EBL_P4_Flash.php
Car: 90 Formula 350
Bad SS wow that looks infinetly adaptable, so much so its over my head. I'm more of a wrench guy and old school give me a Holley 4 bbl and points any day. That said I do entertain this old dog learning a new thing or 2
FI Tech or Atomic EFI Holley fast etc throttle body fit better under the hood and lot less hassles. Plus you can run a 4 barrel intake.
If you haven’t checked out the “Ten Times the Torque” article showing different EFI intake manifolds, I suggest that you do. It’ll show you the varying power curves and general characteristics of the different intakes available. Here’s a link to a copy of the magazine.
http://www.corvetteitalia.it/public/...2201093121.pdf
This is a link to the sticky on the TPI forum where the article and characteristics of the intakes were thoroughly discussed.
https://www.thirdgen.org/forums/tpi/...feb-super.html
The single plane EFI intake isn’t all that good when compared to other single plane intakes available. The better single planes would fall about in the middle of the single plane’s and StealthRam’s power curves. However, the power and general curve produced is a pretty fair representation of what a carbed single plane intake or throttle body EFI on a single plane intake would make.
As a carb guy, if you decide to stick with a carb, definely look into a 9380 Holley 850 annular discharge carb with a progressive linkage kit. I don’t know anyone that’s ever run one that’s not thoroughly impressed with it. Just for informational purposes, here’s a dyno article comparing an annular discharge booster carb to the more common “double pumper” on a “500HP” engine – 94lb/ft difference at 1800 rpm!!
https://www.hotrod.com/articles/carburetor-showdown/
Car: 90 Formula 350
MMadden55 I'm somewhat familiar with these but I'm not down with them on this
BadSS I have seen that and read it a couple of times I am leaning towards a Super Ram or SLP runners or possibly a ProFloXT although I haven't seen anyone say it'd fit under my Firebird hood and I have looked although seems like it fits the corvettes I my end up changing to bigger non Vortec heads and a bigger cam but this wont get worked on for a year or two I have a LS swapped 69 Firebird that I have to get going first
Car: 90 Formula 350
thought I'd update I have found and bought a set of SLP runners and also have a Accel std and Vortec TPI bases but I know that this will be a restriction on a air hungry 383 so I'm thinking of porting and or swapping heads and avoiding the vortec TPI base issues. I'm also watching for a SR and at the moment I know 3 available and theyre not in my affordability heck all this stuff is higher than it was 2-3 years ago. If I can find one thats right I will probably grab it and let go of this other stuff I'm not wanting to be a Hoarder like TTop350
not trying to have the fastest 3rd gen but something that will stand its own ground. I feel like the SLP setup would limit it and the SR wouldn't so much and a bolt on instead of needing massive port work
You HAVE an Accell and Vortec base already? You can easily get $400 for the Accell, and probably $300 for the Vortec. That should put you well on your way to the SR, which typically come with a base. ...maybe buy the SR first, before you sell, LOL. -make sure it come with that base!
Car: 90 Formula 350
I did read about the Accel 7 series was very tunable and I see a few on the auction site but I really don't know what I need suggestions or recommendations appreciated
Vacuum secondary carb, Air Gap intake, wide band O2 sensor/AFR gauge.
Done.
Done.
yeah unless a SR is snagged and who knows with the SLP Accel combo and SR s/b an easy upgrade and would be a good comparison of long runner / large plenum power and torque effect makes it more streetable - well sounds like fun anyway. One thing I'm thinking about is upgrading to a better/tunable ECM but I honestly don't know jack about whats involved. I have to think the tune ability the dang LS can drive so well when highly modified .
Car: 90 Formula 350
I hear you, do you have any numbers on HP/TRQ? where can I find out about Holley HP EFI at?
I love the stealth ram and pro flo / ram jet types. Great balance of power torque and cost. But it likely will hit stock hood. Tough to say, i havent seen the pro flo or ram jet used but stealth ram hit
superram is your best bet if sticking with etec heads. Just do what you can to open up the vortec base. It will still make decent power. Hot cam will run fine
stock oem tpi harness and computer would do well but you’ll need to learn to tune it. Not difficult but there is a learning curve to get over.
I don't have dyno numbers on my set up yet, but an almost identical build, albeit with a stealthram, put down about 395 at the wheels. With my intake, and based on other higher RPM/ builds like Vincents, I'd bet mine puts down 350 to 375. I built it for torque, smaller heads and cam etc. etc., since a long tube intake was a requirement.
Stock ECM is certainly capable. I wanted something with some self tuning abilities to help me out of the gate, since I'm a novice tuner. I also wanted customer service, community support, and professional tuning support, should I need it. The Holley delivered in spades. Ain't cheap though. I wasn't willing to put time into learning old, unsupported software/hardware, although I readily admit that for those that know it, it's certainly capable. I understand why guys like the old stuff, as that's typically ME! ...in this case though, I'm the new blood, and I wanted to learn on modern software. ...if you're interested in the Holley, google it, check out the Holley forums, call them....and feel free to PM me with questions. I PM with different members quite frequently regarding the Holley gear.
I had targeted 500 HP from a 383 topped with a aftermarket version of the Vortecs pocket ported and somewhere between 170-180 cc and found that it would be tough nut to crack. The result however would have no difference whether injected or carbed and the additional expense of the FI route has kept me in the carbureted camp even though the fuel delivery system is (or could be ) up to the task of supplying FI.
Good luck. I'll be interested in what develops with your E-Tecs and the cubic inches you're working with. On a good day with the right cam, those heads and cubic inches could make 450 HP. Probably a little more.
Car: 90 Formula 350
my combo has been a mild 383 with the E-tec 170s ZZ4 cam and factory Q-jet with some different rods and hanger what was recommended for a ZZ4 engine SLP 1 3/4" headers dual cats free flow exhaust and it ran fine I ran it against my stock 99 Trans Am and it inched away from 99 I thought not bad for carbed engine it surprised more than a few cars I'm sure. It passed emissions fine and would pass as stock 305. so maybe its time for non Vortec heads and bigger cam and injection, man I got a lot of work to do
#42
Car: 90 Formula 350
So it looks like its going to be SR for my car with std Accel base. What are you doing for gaskets? I'm guessing they're no longer made so will have to make own, does anyone have a template they can share? so now starting to think about heads and cam for this car, its an auto and has 3.42's in it now but will also get an upgraded diff to a 3.54 ratio its street driven and want good drivability. that said what are Y'alls recomendations? I have a 90 speed density harness and ECM but I think prom is still with VATs so I'll need a chip too?
keep in mind I'm a cheap bastard
#43
If you are going with SR the gaskets are still available for $55 see link below. I ordered these for my recent build.
https://www.lingenfelter.com/product...l#.W6kQw_ZlCUk
#44
Car: 90 Formula 350
I do have a 90 SD harness and ecm that I can use but who do you turn to for a custom chip? burning my own is out of my abilities
#45
Its a good idea to grab two of them in case they become obsolete. Not sure on the set-up for cam and head, im sure others will point you in the right direction.
as for chip, I was in the same situation and I contacted Brian (tunedperformance) and still working with him. Contact him, hes fast, very knowledgeable and he will guide you though the process.
#46
Car: '70 Chevelle, '63 Corvette
Engine: 383, 327
Transmission: B&M 700r4, Muncie M-21
I have a friend that has an E-Tec 170 headed 383 and it runs fantastic. Custom roller cam, 226/232 @ .050, 10:1 compression. Best of 11.99 @ 111 in a full weight '69 Chevelle with a TH350/ 3.36 rear end. Typically low 12s @ 110. He runs a well setup Holley 770 Street Avenger on a Performer RPM air gap. Engine was put together by Parsons Racing Engines in Dayton, OH.
I have a ZZ383 in my '70 Chevelle, topped with a Vortec HSR, run by Megasquirt. It runs really good, drivability is fantastic, and it pulls well to 6000. Mid-Low 12s @ 106-108. I have a Ramjet intake in my basement, but haven't convinced myself it's worth the effort to swap.
I also have a 350 in my S10 Blazer with Summit Vortec heads, Voodoo 219/227 cam, Performer RPM Air Gap, fed by a Holley Sniper. The Sniper is a piece of cake and really works well. I think my port EFI on my Chevelle is slightly better, but this way you can keep your existing intake. The Holley software (free download) allows for plenty of custom tuning, if desired.
I've never had a Superram, but I've read a lot of complaints about what a PITA they are to work on. I'll say the HSR is dead simple, uses a stock TPI throttle bracket (makes TV cable easy). Obviously, Sniper's are as easy as a carb to remove/replace
For god's sake, don't run one of those vintage ECMs. Why? Spend the extra bucks and get a Holley Avenger or Megasquirt controller. You won't regret it. Actually the best ECU to run is the one YOU can get the best support for. Maybe call a local dyno shop see what they have experience with.
-Dave
-Dave
#47
Car: 90 Formula 350
-Dave
-Dave
as far as PCM stock is doable with what I'm planning and since I don't have alot of tuning know how... It'd be nice to have a plug and play setup that can tune itself or pretty much given the basic parameters.
john8169
12-12-2011 03:37 PM
9c1Caprice
Aftermarket Product Review
20
02-05-2004 10:18 PM
