Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
stealth ram build
Old Jan 11, 2021 | 03:33 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
stealth ram build
Ive been on the forums along time. I have a 91 rs that was converted to tpi many years ago and now im upgrading again. I picked up a 92 5.7 from a z28 tpi and also have a stelth ram on the way. ive read quite a few threads here and as usual very helpful. My car is a street car a weekend play toy. Ihave a t56 in it and 4th gen posi rear with all the suspension goodies. The 305 runs great but of course i want more engine. Im looking to get an lt1 or lt4 hot cam. Ive seen both are popular choices. Im looking for a fuel regulator that will work and curious to what is the most simplistic or best quality?
everything else I think is good including headers and tb. I was running a vbelt but might go back to the serp drive. i dont run smog or ac. please keep pposting up builds or suggestions. As i build mine ill post here as well
Old Jan 11, 2021 | 04:38 PM
ULTM8Z's Avatar
Re: stealth ram build
So you're planning to put in the 5.7 in place of the 5.0.
HSR plus the LT4 hot cam would be a terrific combo with your 3.73 axle ratio. Just be prepared to tune... a 90-92 speed density ECM will not be forgiving of modifications without tuning.
The stock fuel pressure regulator is fine. Just get bigger injectors (probably would go for 30 lb/hr) and then tune for them. Can leave the fuel pressure alone.
Old Mar 20, 2021 | 06:49 PM
NotsosleepyZ's Avatar
Car: 89 Firebird
Engine: 5.7
Axle/Gears: unkown
sunscribed! im in the middle of ordering everything for the HSR i watched the klown1969 video on youtube and i know hes a member here, its been a great help in gathering the parts, but i cant find the adapter for the hard line he refers to as Saginaw type to AN line anywhere, tips? also do i have to get new injectors? and what would you guys recommend? so far i have the intake and the fuel rail kit, i have a lt1 throttle body or could modify stock one. on s side not i have a whole lt1 manifold with injectors couldi just use those?
Old Mar 20, 2021 | 08:13 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/tpi/...uel-lines.html
SSprayd
Oct 21, 2005 12:16 AM
jdaniel
May 9, 2003 08:06 PM
StylnCamaro
Dec 22, 2002 10:04 PM
JuicedBird
Dec 13, 2002 10:21 AM
esams
Apr 22, 2002 01:41 PM
