Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Forward facing elbow with single plane possible?
Old 04-08-2021, 08:30 PM
Supporter/Moderator
askulte's Avatar
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
After 8 years of sitting, I’ve got the Z28tt back on the road and starting lots of upgrades. Got my Emtron this week, and now looking at fabbing something so I could run a drive by wire throttle body. My plan was to get an Edelbrock elbow for the LS2 90mm tb and Accel Pro Ram intake manifold. Seemed easier than trying to add a DBW motor and twin tps to my 4150 throttle body. Clearance is tight vertically to the hood and also the water neck filler. I might fab up a sheet metal elbow, if I have to.
Is there such a thing as a low profile water filler neck? Maybe I could cut and weld a fitting to angle it forward instead of up? Or weld on a -16 bung facing forward?
Has anyone been down this road before?
Scope creep strikes yet again. I also am trying to fit on a 60-2 crank trigger wheel, probably will go with the Holley wheel and fab a bracket for a VR sensor. All because I’m rich at idle and wanted sequential injection.
I’ve got a huge list of things to fix and un-hack, but it’s fun to have it running again. This was my first car when I was 17!
Old 04-09-2021, 10:49 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Re: Forward facing elbow with single plane possible?
In an attempt to fit a HSR under an uncut firebird hood I reduced the overall height of the intake by approx. 1/2", a little here, a little there. I ran into the issue of the thermostat housing coming into contact with the bottom of my TB. I bought one of
these these
, figured out how I need to clock it then I JB welded the two pieces together and milled off the appropriate amount of the water mounting flange, I will say this is still untested as the car isn't running yet but there still seems a good amount of material left of the base thickness to resist warping, we'll see
Old 04-09-2021, 11:53 AM
Supporter/Moderator
askulte's Avatar
Car: '89 Z28tt
Thanks, 91banditt2. Good luck!
I could do something similar to my water neck if I needed to. Or just machine a flatter billet one and offset the tstat to the side. I’ll wait until I the LS2 throttle body to test with. Might have to end up welding a sheet metal throttle elbow.
91banditt2 (04-09-2021)
Old 04-09-2021, 01:40 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Could always run a remote housing and just block off the stock one, run fittings off the manifold corners, if threaded else drill/tap them.
Old 04-13-2021, 10:06 AM
Supporter/Moderator
askulte's Avatar
Car: '89 Z28tt
Orr - Good idea. Thanks! The manifold is already drilled and tapped for it. Heck, I could bring the rear passages forward too.
I'll wait for the LS3 throttlebody and start mocking things up. Right now am machining a 60-2 crank trigger pattern into my serpentine bely pulley...
anesthes
01-07-2021 11:20 AM
antman89iroc
27
07-25-2018 08:32 AM
simpson36
05-01-2015 09:48 PM
ericjon262
12-03-2009 09:56 PM
89VertRS
03-28-2008 01:21 PM
Quick Reply: Forward facing elbow with single plane possible?
