1970 Firebird
Old Apr 27, 2002 | 05:53 PM
70Firebird's Avatar
1970 Firebird
My daily driver is a 87 Red IROC....but my weekend rid is my restored 70 Firebird .
http://www.sells.freeserve.co.uk/
Old Apr 27, 2002 | 09:57 PM
1992_25t_1letpi's Avatar
wow THATS SWEET, early second gen firebirds were my fav of all the 70-81 f-bodies, i want one and i will keep looking.
Old Apr 28, 2002 | 12:49 AM
70Firebird's Avatar
70 Bird
Sorry for the confusion. on the link you have to scroll down where it says "Firebird Pictures"...my car is the last on on the 1970-the gold with black vinyl top. Since these pics were taken I have replaced the steering wheel with a 73 Formula wheel, repainted my rally 2s, and replaced the lame retangular air cleaner with a chrome 14". The car has dual 2 1/2 inch pipes running through resonators...no muffler. I sounds pist.
Old Apr 29, 2002 | 10:29 AM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
sweet, what size engine? 400?
Old Apr 29, 2002 | 04:29 PM
89Formula305's Avatar
awsome, I also love the early 2nd gen firebirds
Old Apr 29, 2002 | 05:44 PM
70Firebird's Avatar
70 Firebird
My future plans (way in the future) is to upgrade to a 455 CID...which will fit right in the engine compartment. The current engine is a 350 that is putting out performance times comparable to a 70 LT-1. What it lacks in HP...it makes up in torque (380lbs) --thanks to Pontiac's 3.75 inch stroke. Since the block is overbore 30 over at 3.92 inches (compared to 4.0 in bore in a Chevy)... I am not giving up much to the Chevy.
I am currently running a 6.9 sec 0-60---and that's with a stock open 2:73 rear end. With a 3:23 or 3:73 ratio and traction improvment...I would probably be able to shave a full second off my 1/4.
Old May 1, 2002 | 08:26 AM
Camrs89's Avatar
A little tip, you don't want to gear pontiac motors too deep because of the low end torque you want to take advantage of. I would say a perfect gear would be from 3.23 to 3.55. Those are great gears for pontiac motors.
But I know how you feel with the open rear on the car. I have the same in my LeMans. But hey those one-tire bonfires are the best for smoke shows.
Old May 1, 2002 | 11:28 AM
Black85TransAm's Avatar
Pontiac motors are awesome thats all there is to it......
Old May 1, 2002 | 12:24 PM
Camrs89's Avatar
black85transam-I'm telling you that would be sweet if you had a "real" pontiac motor in your car. Torque like you wouldnt believe.
Old May 1, 2002 | 01:12 PM
70Firebird's Avatar
Thanks Camaro for the advice
The 70 Firebird 350 motor runs as smooth a caddy @ 100 mph thanks to the balance job. I am really happy with the torque/performance. The shift kit on the TH350 actually shifts cleaner than the 700R4 on my IROC. The traction off the line is a bit of a problem..thus I get better times when I get into it 2/3 throttle...then hammer once the car gets rolling 10mph.
Delimma: Believe it or not...my Power Steering pump pulley wore out the other over 3 weeks ago (down time)...and I learn that the 1970 Firebird PS Pulley AND Pump isn't interchangable with other years 67-69 nor the 71-74 models. I have been working with a professional parts supplier in Michigan to find the EXACT Pulley using the # that is stamped on the pulley itself...wouldn't you know it...THEY SENT ME THE WRONG PULLEY! : ( Now I am back to square 1---this time I am going to INSIST on verifying that the Part # matches my part number. THE MORAL OF THE STORY IS THAT YOU HAVE TO "HOLD THEIR HAND" AND HELP THEM DO THE JOB---that they should be doing in the first place. Going on 1 month down for this darn pulley...I am going through "withdrawal" symptoms.
Old May 2, 2002 | 10:33 AM
Camrs89's Avatar
Yeah, the pontiac torque can be a problem when racing, but most of the guys I know just use it to show off. Can you say smoke show?
Old May 2, 2002 | 11:40 AM
How good was the one-wheel -wonder i did over at Dave's ......
Old May 2, 2002 | 12:33 PM
70Firebird's Avatar
Bird
Yeah
It's really surprising the speed that the Firebird can get up and move...and that's without Posi. It's a different feel than today's computer controlled-EFI controled cars. With those resonators howling down the road--sans a muffler...I feel like I am flying a P-51 Mustang into combat.
Old May 3, 2002 | 08:19 AM
Camrs89's Avatar
Yeah, nothing compares to the good ol pontiacs. The first muscle cars
jtwoods4
Sep 3, 2015 05:39 PM
jtwoods4
Sep 3, 2015 10:19 AM
90formulaVortec
Sep 3, 2015 09:26 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
