I started wet sanding my paint yesterday, wich wax do you recomend?
Old Apr 29, 2002 | 11:03 PM
socal85tam's Avatar
Car: 1988 IROC-Z
Engine: 383 HSR
Transmission: 4 speed Automatic
Axle/Gears: 4:10
Polishing pics of my car, wich wax do you recomend?
This is how she used to look, after the new paint.
Old Apr 29, 2002 | 11:06 PM
socal85tam's Avatar
Car: 1988 IROC-Z
Engine: 383 HSR
Axle/Gears: 4:10
This is when I started the wet sanding.
Ok girl, this isn't gonna hurt.
Old Apr 29, 2002 | 11:10 PM
socal85tam's Avatar
Car: 1988 IROC-Z
Engine: 383 HSR
Axle/Gears: 4:10
Wet sanding finished... what a workout!
Old Apr 29, 2002 | 11:13 PM
socal85tam's Avatar
Car: 1988 IROC-Z
Engine: 383 HSR
Axle/Gears: 4:10
This is half of her hood polished already.... I'm serious
Old Apr 29, 2002 | 11:16 PM
socal85tam's Avatar
Car: 1988 IROC-Z
Engine: 383 HSR
Axle/Gears: 4:10
See
I'm hoping to be done tomorow.
What is a good wax to put on her?
Old Apr 30, 2002 | 01:51 AM
d_rtis's Avatar
wow thats sweet.
Old Apr 30, 2002 | 03:45 AM
EvilCartman's Avatar
Car: '82 Z28
Wait about 6 to 8 weeks before putting wax on from the time it came out of the paint booth. You have to let the paint vent for it to cure properly.
Old Apr 30, 2002 | 05:49 AM
ImportsRsloths's Avatar
Looks AWESOME!!! what grade of sand paper did you use, and did you just soak it in water or what???
Old Apr 30, 2002 | 06:26 AM
Chuck Everly's Avatar
I have always used the Zaino products ( www.zainobros.com ) on my cars. I was told by the owner of Zaino to wait 7 days before polishing. I have done this with two new paint jobs with no problems.
I now use a product called Duragloss ( www.duragloss.com ). It applies feels and looks like Zaino. It gives the same results as Zaino but it is a lot cheaper and can be found at many local part stores. I have found it at CarQuest, Advance Auto and some NAPA stores.
Either product will do an AWESOME job on you car.
Old Apr 30, 2002 | 06:30 AM
SC82TA's Avatar
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
It might be different for the duragloss though since they contain different stuff in them. Since Zaino has no silicones, abrasives, or caranuba wax it might be fine to polish after 7 days. However duragloss does have silicones, abrasives and waxes that might not agree with the new paint job if polished in just 7 days...
Old Apr 30, 2002 | 06:35 AM
You might want to read about the 111 Duragloss product not the 104 product. The 111 does not contain silicone oil, abrasives or waxes either.
Old Apr 30, 2002 | 10:49 AM
socal85tam's Avatar
Car: 1988 IROC-Z
Engine: 383 HSR
Axle/Gears: 4:10
First I used 1000, then I went to 1500, it all depends in how bad is the orange peel on your paint is. You have to soak the sand paper for a few minutes and keep the paint always wet, using clean water. The 3M perfect it III high cut compound will do it for the 1500 sand marks but you can always go 2000 or like my friend 3000
Old Apr 30, 2002 | 11:03 AM
capn_crash84's Avatar
Looks awsome.
This may sound like a dumb question, but why is it all foggy? Did you put something on it or is that just how it looks before you wetsand?
-crash
Old Apr 30, 2002 | 11:09 AM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
The reason why it looks so foggy is from wet sanding, it takes the shine away until you polish it out. Gab, I did the same as you 1000grit 1500 and then 2000 grit and polished it out with my dewalt buffer.I still have a half a bottle of my 3m rubbing compound and polishing compound. I love how good my car looks now it makes me feel even better when I can say I did all my body work and painting myslef.
Old Apr 30, 2002 | 11:27 AM
socal85tam's Avatar
Car: 1988 IROC-Z
Engine: 383 HSR
Axle/Gears: 4:10
Looking great Mike, I wish I could have done the paint and body work myself, I would of saved big $$, but, I dont know anything about bodywork. Keep up the good work
Old Apr 30, 2002 | 12:53 PM
86BIRD-MY FIRST CAR's Avatar
What is wet sanding and how does it work
Old Apr 30, 2002 | 01:00 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Wetsanding creates a mirror type finish.
I like Meguiars Products, step 1-3 works well for a cheap price. Also the easiest stuff to take off I've ever tried.
Attached Thumbnails I started wet sanding my paint yesterday, wich wax do you recomend?-megwax5.jpg
Old Jun 2, 2002 | 02:17 AM
oldblueZ's Avatar
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
MARK,
So to polish after wetsanding, you just used the meguires 3 step. What about the whole using a buffer process. Can you just apply the polishing compounds and buff them out by hand, or do you need to use a buffer?
I've heard, and seen horror stories of burnt paint from using a buffer incorrectly. I CAN'T buff yet.
Can you polish it effectively by hand?
Thanks,
Jesse
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
project89
Sep 24, 2015 06:38 AM
92camaroJoe
Aug 13, 2015 06:07 AM
NBrehm
Aug 5, 2015 07:57 PM
