What can I use to take the clear coat off my rims!!!
Old May 27, 2002 | 11:46 PM
5SIZ's Avatar
Car: 1987 IROC-Z
I have gone to both of my local auto parts stores, " Autozone & Checkers" neither have Clear coat remover, they don't even know what I mean, I have to give an explanation. I haven't gone to pep boys yet.
What can I use to take the clear coat off my rims!! What is it called? where can I get it? and how much does it cost?
Can I use anything else to take the clear coat off?? please help guys, I want to do this A.S.A.P.
Old May 28, 2002 | 12:14 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
There's a stuff called Aircraft Remover, it's a type of paint stripper. I used it and it worked really well. But dont get the stuff in the aerosol can, use the stuff that you apply with a brush; for some reason it seems to work better. And when they say 'dont get it on your skin', they mean it, the stuff burns like crazy!
Old May 28, 2002 | 12:53 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
What ViciousZ said. You can get it at Wal-Mart for around $4.00.
Old May 28, 2002 | 05:58 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Cant find it in the wal marts in Texas, I have looked endlessly. Now is it wrong to use this stuff at a car wash? Has anybody done that? You need some kinda high pressue sparyer to get it off you rims right? Where did you people strip your rims?
>and yes....
Attached Thumbnails What can I use to take the clear coat off my rims!!!-burns.gif
Old May 28, 2002 | 06:34 AM
JACKO's Avatar
YEAH AIRCRAFT PAINT STRIPPER IS THE GO BUT ITS SOMETIMES HARD TO GET. "AS POSTED EARLIER" DON'T GET THE SPRAY IT JUST DOESN'T HAVE ANY *****.
I USED NORMAL PAINT STRIPPER & A KARCHER H/PRESSURE CLEANER, YOU WILL NEED TO HAVE SEVERAL GOES BEFORE YOU GET IT OFF. "WEAR GLOVES & SAFETY GLASSES COZ IT BURNS MORE THAN YOUR WINKY IN A TOASTER".
MAKE SURE YOU TOTALLY DRY RIMS BEFORE SECOND APLICATION OR IT WON'T WORK TO WELL.
GOOD LUCK
JACKO
Old May 28, 2002 | 06:54 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Be sure to check the automotive section at Wal-Mart. They can order it for you if you speak to the Department Manager. I got the spray can kind work real well.
Old May 28, 2002 | 09:09 AM
5SIZ's Avatar
Car: 1987 IROC-Z
hmmm aircraft remover, thats exactly what it's called?
So once I brush it on, I need a high pressure hose to wash it off? what about a normal garden hose with a spray handle?
How long should I wait beofre I take it off?
Old May 28, 2002 | 09:54 AM
Car: 99 Formula
Axle/Gears: 342
I just wiped it off using paper towels. And yes, that's what it's called Aircraft Stripper.
Old May 28, 2002 | 10:03 AM
Saywhut's Avatar
Western Auto here carries "Tal Strip" which works well for me, $20/gal, usually 1 coat does it, wash it off with high pressure water.
Old May 28, 2002 | 11:56 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Well I'm just up the road from you, and I found it at Wal-Mart. It wasnt in the automotive section, it was in the home paint/decor section. Try looking there.
Old May 28, 2002 | 03:24 PM
5SIZ's Avatar
Car: 1987 IROC-Z
Thanks guys, I'll check it out.
Old May 28, 2002 | 05:35 PM
nndestiny's Avatar
aircraft stripper
that is what i used to take the gold paint off of my gta rims.it did take a few applications of it and i did wash it off with the garden hose. i found a few different sizes and name brands at the autozone that were really not expensive. just be careful using it. the stuff can eat away the paint brush so just think of how it feels on your skin.OOOOUchhh!!
--Nikki--
Old May 28, 2002 | 05:55 PM
fattie92's Avatar
what ya do to the rim after its off? im guessing paint it duhh... but with sparypaint? what??
Old May 28, 2002 | 05:59 PM
nndestiny's Avatar
paint
I painted mine with metallic silver engine paint.There has been no problem with my rims yet.(and if my car ever starts on fire my rims with be the last thing to go since they can withstand 1200+degrees )j/k but they really did turn out nice.Everything that i needed to do my rims i got from autozone so it was so much less expensive then it would have been to take them in to get done.
--nikki--
Old May 28, 2002 | 06:17 PM
5SIZ's Avatar
Car: 1987 IROC-Z
After I finally get the clear coat off "some time next week." I will polish them a little with mothers, then the original silver painted parts of the rim will be sanded, primered, and painted gloss black, they will look awesome.
Old May 28, 2002 | 07:42 PM
fattie92's Avatar
ok, so iv got some unpainted aluminum rims....i think they are alluminum...or is is stainless steel....i dont know,, but its just the metal then clear coat. they have spots that look like dirt everywhere. i still havent had the time to sit there with the dremel buffer and go at it to see if that will take it out. you think just stripping the clear coat off will be a better idea then waxing it with mothers mag polish?
Old May 29, 2002 | 09:12 AM
bdog52's Avatar
taking off clear coat
just a little fyi...
i was gonna redo my iroc wheels, after much searching found a complete kit at paddockparts.com for aluminum wheel restoration, kit made by por-15, has clearcoat remover, cleaner polishing compound, adapters for your drill cost 139$. part number WPK. also they have several kinds of paint made for wheels, various colors and manufacturers, sounded better then sending them out, sufering while car was down, and paying upwards of 1000$ to have them redone professionally.saved myself big money, forgot about the iroc and bought a92 heritaeZ!
Old May 29, 2002 | 12:52 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Re: taking off clear coat
Damn, I polished my wheels for about $30, and a few hours of my time. Well about 20 hours.
Hotrodboba400
Dec 10, 2019 07:07 PM
kitt23
Exterior Parts for Sale
Nov 28, 2015 06:26 PM
redformula88
Oct 14, 2015 06:08 PM
Stryker412
Sep 7, 2015 09:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
