wetsand new paint???
Old Jun 9, 2002 | 11:12 PM
junkie's Avatar
Car: 84 camaro berlinetta
hi all i just got the car painted white and i have seen a few POSTS OF PEOPLE THAT WETSANDED THEN POLISHED TO GIVE THE PAINT A MIRROR FINISH...HOW DO I DO THIS?????
and yes the car needs lowered and a set of rims in a bad kinda way thanks for the help
Old Jun 10, 2002 | 12:09 AM
sheet outta luck's Avatar
i might get flamed for this
but i kinda like the berlinetta rims
i think itll look good after its lowered with those rims.....of course even better with bigger ones
oh yeah i know nothing about wetsanding
Old Jun 10, 2002 | 02:39 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
JUST DO A SEARCH ON WETSANDING. YOUR QUESTION HAS BEEN ANSWERED SEVERAL TIMES AND THERE ARE STEP BY STEP INSTUCTIONS ON HOW TO WET SAND SO NO NEED FOR ME TO GUIDE YOU. IF YOU WANT YOUR CAR TO STAND OUT - WETSAND IT. AND WITH PATIENCE AND TIME YOU CAN DO THIS YOURSELF.
Old Jun 10, 2002 | 03:18 AM
JACKO's Avatar
I'll asume you just got a 2pak paint job.
wetsand with 1200 OR finer using a colouring block(firm but flexes), add a little soap to your water which will aid slip, be very gentle of edges and corners. Use a machine buff with a foam pad @ about 1500rpm using a fine suitable cutter for your paint, I use Farecla G3. Then use a coloring/Glaze compound on a dimple pad (damp),I use 3M pads & "foam polishing pad glaze", there are 2 types 1 for dark paint & 1 for light colors. Make sure you wash well between every application as it splatters into cracks & crevises & the longer you leave it the harder it is to get off.
Its hard to tell you how far to block it (wetsand) without seeing your paint first hand & knowing how much paint they used.
polish by hand after you are done. After you are finished the most important thing to do is crack a can of beer & enjoy!!!
GOOD LUCK
Old Jun 10, 2002 | 10:07 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Carefull now dont dull down your paint by taking sand paper to it.
Old Jun 10, 2002 | 03:16 PM
junkie's Avatar
thanks for the help ..im gona try it somewhere low to see if itll work for me or not
does anyone know how to change your user name?
:hail: :hail:
Old Jun 10, 2002 | 03:39 PM
:hail: :hail:
Change your user name? What did you quit junkie? lol. Tell you what try it on someone else's car first. Hehe....... Just ing
Old Jun 13, 2002 | 04:25 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Jacko is spot on,I've seen the difference before and after on a coloursanded paint job and the difference is unreal.It can take a paint job from being very good to being stunning.When I do mine (painting still in progress) I will probably use 1500 or 2000 wet and dry (me being paranoid perhaps).Takes a fair while to do but well worth it.
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Sep 21, 2015 08:54 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
