removing dents
Old Jul 1, 2002 | 07:57 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
removing dents
how can it be done paintlessly
will one of them el cheapo dent poppers actually work?
i took a good hard look at my car today
the paint job looks great, but it has some dents that arent very deep......they kinda detract from the paintjob.........
i also need to paint my Z28 grille............is it supposed to be gloss black or flat black?
Old Jul 1, 2002 | 08:12 PM
MG86TA's Avatar
if its a wide dent you can stick the suction cup in the middle.. then pull it out.. THAT works.. but if they are door dings, u might have to pound them out from behind
Old Jul 1, 2002 | 11:04 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
NO NO NO NO NO.
You can't use the dent puller to remove a dent! It doesn't work. If the dents you are referring to are just regular door dings and such, a good Paintless Dent Removal place will remove them and make it look good. Learning to remove a dent takes at least 1 year to get good. Joe Homeowner will not be able to remove a dent with a $39 gimmick. I am a PDR guy and can tell you from experience. Get a referral for a shop or person that does great work. There are specialty tools required that only a pro knows how to use. Remember that a dent is stretched metal. It doesn't just pop back out. It needs to be massaged and smoothed out again. If I was in your area, I'd offer to help, but I don't live in Jersey anymore! By the way, here's my card. Thanks to OKFOZ for the logo permissions.
Old Jul 2, 2002 | 04:07 AM
hmmmmmm the dents i have are weird though................their not deep, their VERY shallow, but they are wide
Old Jul 2, 2002 | 08:40 AM
scottmoyer's Avatar
They"ll come out. A good shop or technician will make them disappear. I know the dents you're talking about. I had a few of them also in one of my cars. PDR costs about 1/3 the cost of a body shop. With that in mind, don't be shocked if you get a quote for a lot of money. Just remember that a body shop will use filler and have to paint it when they are done and this will be done without any of that.
Old Jul 2, 2002 | 08:58 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Dent it, pull it, bondo it, prep it, paint it. If that doesnt work replace it!
Theres your pro work
Old Jul 2, 2002 | 03:53 PM
whats the average price of a PDRing a dent??
i have no clue, so all i need is a ballpark range
Old Jul 2, 2002 | 06:41 PM
scottmoyer's Avatar
Some companies like Dent Wizard might charge $65/panel. If you have 3 dents on the door, it's $65. If you have 5 dents on the fender, it $65. I don't know if all offices work that way, but some do. Others will charge $50/per panel +$10 each additional dent. So if you have 3 dents in the door($70) and 3 in the rear 1/4 ($70), you're looking at a total of $140. Those would be based on door dings and small dents. If the car got smacked with a softball at close range and left a deep, large dent, it could cost close to $100 just to fix the one dent. The prices vary depending on the severity of the dent, but the ones you mentioned sound small. I would guess that you are gonna be close to either the $65/panel method or the $50-$60/panel + each dent method. You should be able to get an idea from this. One more thing, if the dent is in an area that's not easily accessible, they charge more. Right in the middle of the doors should be fine.
Old Jul 2, 2002 | 08:31 PM
thanx scott
prices actually seem reasonable
i think i mite get them taken out in the near future
you cant see these dents looking head on.......its when you look at the car from an angle...........hard to explain but their really shallow, but wide
Old Jul 2, 2002 | 09:40 PM
scottmoyer's Avatar
I know exactly what you're explaining. When looking normally at the car, you don't see em, but at the right angle and with the right lighting, you can see 'em. I just removed a few of these from my car.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Stroopwafel
Sep 11, 2015 06:38 AM
hydrolic144
Sep 8, 2015 06:59 PM
