Water spots on windows
Old Jul 10, 2002 | 08:17 AM
J's86ROC's Avatar
Car: 1986 IROC-Z
Engine: peanut cam LB9
I took the louvers off the back window of my IROC on sunday. My dad put them on there in late 86 or early 87. They are the three piece kind so where the two side pieces were there are horrible water spots. What can I use to get them off? Someone please help, it looks like there's a ghost of the louvers still on the car.
Thanks in advance for any help,
Jason
Old Jul 10, 2002 | 09:24 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
You can use Paint Thinner. Put in on a rag and rub in small areas, this way you won't get it on the paint. You could also try rubbing lightly with SteelWool and your favorite window cleaner. There are more ways to do it but these are the only ones I know of.
Hope that helps.
Old Jul 10, 2002 | 09:26 AM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
hey buddie I detail prof. the best thing to use is fine steelwool. its works great to remove water spots and general junk stuck or stained to your windows.
oops posted at the same time srry paint thinnerer wont hurt your pain though. just take the wax off.
Old Jul 12, 2002 | 01:09 PM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
I just bought some Meguires Chrome Polish and it says on the back something about using it on glass. I tried it and it worked GREAT!
Mark
Old Jul 12, 2002 | 01:18 PM
castrolSi's Avatar
000 Steel wool works wonders.
~castrol
Old Jul 12, 2002 | 01:26 PM
1982chevycamaroz28's Avatar
use wd40 and fine steel wool. it will do wounders to ur windows and wont leave a mark.
Old Jul 12, 2002 | 07:49 PM
JACKO's Avatar
Just did mine a few weeks back & they came up like new. I used a wet foam buff pad on a machine buff @ 1500 rpm using a fine 2pack cutter/denipping compound (Farecla). I used to work in a glass factory & sometimes we used steel wool but if you over rubbed it would leave fine scratches. Before you do any method make sure your glass is totally clean as any dirt will scratch.
good luck
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Veaceonee
Sep 29, 2016 08:15 PM
Fronzizzle
Sep 8, 2015 12:10 PM
