Any good tips on cleaning your windshield
Old Aug 9, 2002 | 07:51 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Even after several go overs with glass cleaner my windshield still never looks clean. Is there a good product out there for maybe buffing out the glass? Or anybody got an ancient chinese secret?
Old Aug 9, 2002 | 08:29 PM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
get some real fine steel wool(#0000 i think) from wal-mart i use it all the time it wont scratch your window just make sure its very fine not no brillo pad or anythink hope that helps
Old Aug 9, 2002 | 08:38 PM
devianb's Avatar
I heard that paint thinner can remove waterspots. Is this true? I would like to know before I try it.
Old Aug 9, 2002 | 08:52 PM
steel wool (very fine) (#0000) will remove water spots and its very cheap i dont know about paint thinner but if u get over spray on your window its still better to use steel wool
Old Aug 9, 2002 | 10:15 PM
Makai's Avatar
try using newspaper, it cuts right thru smoke without smearing
Old Aug 9, 2002 | 10:52 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
As much as I love that car, your sig pic is a little on the big side. Would you mind sizing it down please?
Old Aug 9, 2002 | 11:05 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Assuming you're fighting the outside. The best luck I've had was using laquer thinner (it's glass.. you can't hurt it..) to clean most any debris off then going over it with Meguires (I'm almost sure that's spelled wrong) body scrub then some RainX. That how I cured the spots on my 'bird back glass when I got it.
If you don't like that solution, eastwood ( well, that link didn't work) here.. http://www.eastwoodcompany.com/ ... use "glass polish" for search keywords to find all the goodies they have to 'fix' glass.
Old Aug 10, 2002 | 07:27 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I've used keroscene since reading about it in Jason Scott's book, "How to Turn & Modify Your Camaro: 1982-1998." A lot of elbow grease is required, but the windshield appears new afterward. Highly recommended.
JamesC
Old Aug 11, 2002 | 12:29 PM
92blackbird's Avatar
Car: 1992 pontiac firebird
Engine: 305 tbi
May sound dumb but my son is a professional detailer and they use Bar Keeper's Friend. It's non abrasive but cleans EVERYTHING off the windows.
Old Aug 11, 2002 | 02:57 PM
Knight350's Avatar
The fine steel wool sounds good if you feel little
roughness when you pass your hand over the glass.... I used a little soapy water with 2000 grit wet sand paper, then after drying using glass cleaner,(the foam in the spray can works good) then use newspaper to wipe.... I hope that helps..
Have fun..
Fredel
Old Aug 11, 2002 | 08:16 PM
90 Formula's Avatar
Car: 90 Formula, blue/silver
Engine: 305 TBI
Mother's Glass and Chrome Cleaner works great. It goes on like a wax & buffs off with very little elbow grease.
Old Aug 12, 2002 | 01:38 AM
Garett92Z's Avatar
Zainobrother's show-car Glass Polish... you can visit www.zainobros.com if you need info on it... should be a distributor somewhere in your area.
It's the best stuff, you only need about a 1" dab on a foam pad buffer to have a CLEAN, smooth windshield.
garett
Old Aug 13, 2002 | 07:18 PM
SBlackfoot's Avatar
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
Ahh, but what's the best way to clean the inside...? There's some stuff on the inside of my windsheild that's very stubborn to get off. It's tough to get in there along the dash and the A-pillars. Similar problem with the rear hatch actually, it's at a bad angle for cleaning. The residue must be from when the heater core puked, or maybe my brother used to smoke in it (unlikely, but there was a nasty film on the t-tops that took a lot of elbowgrease to remove.)
Old Aug 13, 2002 | 10:10 PM
Frank 84 Bird's Avatar
Car: 87 Trans Am
Transmission: TKO 600
That's what I used on my car takes a little work but the water spots came off and it looks great.
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
kyleb24
Aug 15, 2015 08:24 AM
