HELP! ASAP having trouble getting clear coat of 91 rims
Old Aug 19, 2002 | 02:55 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
my rims are off my car and I started to sand, but I'll have to go back to stripping because the clear coat didn't all come off
what i did: tapped tire up, put on aircraft stuff, let sit 10 minutes, put on another coat and pressure washed off, I've already polished a wheel cap and turned out fine
the "5-star" is fine, but the 'ring' is chunks off clear coat yet
Old Aug 19, 2002 | 02:58 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
i almost forgot, I tried sanding the chunks with 320, and no luck, I do have a small sand blaster, but I'd have to go pay $ 10 for a bag or 90 grit
Old Aug 19, 2002 | 03:23 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Spray the aircraft stuff on again and scrape it off with something.. thats what I did and it worked fine on my IROC rims. Good luck.
Old Aug 19, 2002 | 05:01 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Let the stripper sit for one hour. Then, add one more layer of stripper on top of that, and let that sit 10 minutes. Hose off, wipe dry, and your clearcoat will be gone.
Old Aug 19, 2002 | 08:05 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
thanks guys, I got it in the mean time, I just put more on, let sit for like 5 seconds, and wiped off with a towel, worked great
Old Aug 19, 2002 | 09:01 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
do you guys find that the aerosol stripper not work as well as the brush on? that's what i've heard
Old Aug 19, 2002 | 09:16 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I started sanding with 80 grit, that will get that clear off.
Old Aug 19, 2002 | 09:26 PM
Car: 1989 IROC-Z
Engine: 383 stroker
I used the spray on stuff, it worked fine.
Old Aug 19, 2002 | 10:17 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
i used the quart and a brush, better control, and that stuff burns your arms pretty bad
Old Aug 19, 2002 | 10:29 PM
Car: 99 Formula
Axle/Gears: 342
And I strongly recommend you not put it in private areas as hair remover.
Sorry, but it's funny how they have to put all kinds of warnings on cans, like Don't Put In Microwave or something. I'm waitin for someone to sue due to my 1st comment.
Old Aug 19, 2002 | 11:31 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
i used air after flakes started to build up, and they landed on me.....but no rashes :hail:
Old Aug 20, 2002 | 01:12 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
I used a razor blade scrapper to take that off. Much easier...
Old Aug 30, 2002 | 10:39 PM
Black Blurrrr's Avatar
I'm going to start on mine soon. Someone told me that oven cleaner would take the clearcoat off. Anyone tried this???
Hotrodboba400
Dec 10, 2019 07:07 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
Stryker412
Sep 7, 2015 09:11 AM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
