What size tire with 15x6 rim to keep the OD at or close to 26?
Old Aug 26, 2002 | 06:33 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Transmission: TH700-R4
Does anyone know what size tire I can run on a 15x6 rim that will keep the OD around 26. I was thinking a 215/65/15?
Old Aug 26, 2002 | 06:52 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
215/65R15 is exactly 26 in, but a tire that looks very good, for a 15, is 235/60R15, it is 26.1 in, but those numbers vary slightly w/brand and tire wear, so I would recommend 235/60R15, semi wide and very nice profile
Old Aug 26, 2002 | 06:54 PM
Dave Y's Avatar
Engine: 4.3L V6
for a nice tire calculatier web site, go to http://www.miata.net/garage/tirecalc.html
Old Aug 26, 2002 | 07:01 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
I was trying to get the thinest tire on the 15x6 to run it on the front. I could run a thinner rim but don't want to on the street. But I do want it to look good too. I'm also gonna be running 16X8s on the back. They are the WELD Prostar XPs.
Old Aug 26, 2002 | 07:14 PM
Dave Y's Avatar
Engine: 4.3L V6
185/75R15 is 25.9 in, thin, but just under 26, probably look pretty good
Old Aug 26, 2002 | 07:16 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
You don't think it might be too thin for a 15x6 rim?
Old Aug 26, 2002 | 07:45 PM
Dave Y's Avatar
Engine: 4.3L V6
you may need to make sure when look at tires, but I know that 185 should be the tread width in mm, so when you divide 185 mm by 25.4(the number of mm in an inch), you get 7.2 inches, but not all tires are the same, so check the tread width before you buy
Old Aug 26, 2002 | 07:47 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Thanks for the info
Old Aug 26, 2002 | 09:48 PM
V6camaroman's Avatar
i have a 15x6 on the front of my bird and im runnin 205-65-15 tires. its around 26" and it looks good.
Old Aug 27, 2002 | 02:15 AM
jawzforlife1's Avatar
try this sight
http://www.eunos.com/tirecalc/
Old Sep 1, 2002 | 05:58 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Z28z... Why are you changing your wheels?
Old Sep 1, 2002 | 07:11 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
LOL, I'm tired of the factory ones. I think I'm gonna go with some Weld Prostar XPs. I might keep the front ones 16x8 instead of15x6 but haven't really decided yet. I know for sure the rears will be 16x8.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Street Lethal
Apr 30, 2019 12:14 PM
toronto formula
Nov 10, 2015 06:17 AM
BlackMagic1984
Wheels and Tires
Aug 24, 2015 06:35 AM
knight72
Aug 10, 2015 09:32 PM
