I know nothing about tires: Question
Old Nov 21, 2002 | 04:29 PM
85_ZED28's Avatar
Car: '85 Z28
Sorry if it's a stupid question
Like I said; don't know much about tires.
Are there different width tires for the same size rim? I need new rear tires for my car, and was wondering if there are wider tires than the stock ones, and if so, how wide could i go. I don't really want to get taller tires because of the gear ratio crap, I don't wan't my car to be any slower than it is
I have 15 X 7 Z28 rims.
Thanks for any info!
Old Nov 21, 2002 | 04:32 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
ya you can put bigger tires on them. I am not sure about what will fit on a 7" width, call you local tire place and ask them for exact numbers.
Brian
Old Nov 21, 2002 | 04:33 PM
Nazzz28's Avatar
Car: 91 z28
Transmission: 700 R4
What size tires do you have on it now (235/60/15, 215/65/15, ...)?
I had 235/60/15's on my 15x7's when I had them, but these may
be taller than what you are currently running.
Old Nov 21, 2002 | 08:05 PM
Brett Gutshall's Avatar
I also had 235/60/15's when i had the crappy wheels on my car. Someone here had 295s on a 15" rim, so you can definitely go wider but then they bulge and in your case won't really help from a performace standpoint.
Old Nov 21, 2002 | 08:16 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
But what was the width on those 15" rims??
Brian
Old Nov 21, 2002 | 08:21 PM
Brian
15x7
These wheels (which are for sale by the way if anyones interested)
Attached Thumbnails I know nothing about tires:  Question-forsale2.jpg
Old Nov 21, 2002 | 08:22 PM
devianb's Avatar
235/60s are probably the maximum tire width I would use with a 15 X 7 inch wheel.
Old Nov 21, 2002 | 09:50 PM
85_ZED28's Avatar
Car: '85 Z28
thanks for the replies guys
Old Nov 21, 2002 | 09:54 PM
FLYNLOW92rs's Avatar
60 series tires are a kinda big sidewall..........you know me, i would prefer something a little smaller, like 50 series sidewalls......
Old Nov 22, 2002 | 07:06 AM
Nazzz28's Avatar
Car: 91 z28
FLYNLOW92rs - I also like the shorter sidewall look. However,
if 85_ZED28 is keeping the 15 inch rims and wants the same
overall diameter the side wall height can't be changed.
235/60/15's will have an overall diameter of 26.1 inches
215/65/15's --------------------------------------- 26.0 inches
225/60/15's --------------------------------------- 25.62 inches
These are all the tire sizes that I have seen on 15x7 inch camaro
rims. If you have an overall diameter of ~26 inches I would go
with the 235/60/15's. If you want to push it than you can go
with a 255/55/15, but make sure the tire is approved for a 7" wide
rim. Also, you may get some rubbing if they are on the front.
255/55/15's ---------------------------------------- 26.04 inches
However, if you have a standard diameter
of ~25.6 inches I think that you can fit a 245/55/15 on without
changing anything.
245/55/15's ---------------------------------------- 25.61 inches
The reason I said that a 25.6 inch diameter is the standard
is that 245/50/16's, 245/45/17's, and 275/40/17's are all that
height. I hope this helps
Old Nov 22, 2002 | 07:12 AM
bigals87z28's Avatar
Car: Check The Sig
you cant go wider then 235 on a 7in rim... thats about as big as she will take... u want bigger! get bigger rims... i say if u gunna pop for a big tire like that, get iroc rims, and then get some nice tires....
Old Nov 22, 2002 | 08:06 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
15x7
I might still be interested in those if I can get something to drive this time.
Old Nov 22, 2002 | 08:30 AM
Hey man I'm sorry about that, I've been meaning to pm you but i keep forgetting.
Just let me know. If you're not interested anymore thats cool.
colton_carlson
Mar 8, 2019 12:21 PM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
