are t-tops interchangeable?
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
If I am right Its 82-84 then 85-88 then 89-92 I could be wrong I know the set that came off of my husbands 87 Iroc will not work for the 82 camaro we have.
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
You gotta make sure they are stock.
I have C&C t-tops. They were put in by an aftermarket company through a dealer. They're nothing like the stockers.
AJ
AJ
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Gag. Alot of BS in this post already.
82-84 (all f-bodies) used a hook type system
85-92 (all f-bodies) used a pin type system
years 91/92 used the lexan ttops, which are interchangable with the glass ones from 85' on. There are NO differences between firebird or camaro ttops. This is all information on the factory ttops, there were aftermarket setups done by C&C and a few others. Hope this helps!
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
I know this because I used a set of Glass T-Tops from a 1984 S/C on my 1992 RS which has the lexan t-tops....the only difference was that the ones from the 84 didn't have locks.
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
ditto to what zer0321 said. my 84 s/c has pins for holding the t-tops in place.
i'd rather have the glass tops instead of the plastic ones. the glass holds up better, doesn't scratch as easily.
i would imagine that anything between the two cars from 84 to 92 would work. however, aftermarket tops are different from the factory tops, and as a result, won't work.
Car: 2000 astro
Engine: 4.3
Transmission: A4
Originally posted by NEEDforSPEED
what the hell im i talking about
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Doh!
I could have sworn it was 85' that the pin setup started. Supreme Member
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Originally posted by easySPEEDcamaro
sorry dude you are incorrect, different years had different lengths and sizes for the pins.
If that were the case, you would not be able to interchange the tops from '84-on. Originally posted by robertg
exactly.. if you don't know what you're talking about, shut it already.
:lala:
and by the way!! 84 had pin latches...
every ones happy!! :lala: lala lala la la lala
Car: 2000 astro
Engine: 4.3
Transmission: A4
ok, I'll go ahead and post my experience. I've got a '92 RS that had the lexan t-tops. One day before school I was pissed off and threw my back-pack up on top of my car. Damn near broke the t-top in half, split it atleast half-way across. The pins on the '90 and up (I'm guessing on the years) have a plastic sheath over the actual pin that slides about an inch either direction on the pin, this is used to center the pin in the mounting bracket on the body.
I found a set of glass t-tops in houston for $50, so I went up and picked those up. After looking at them, the glass ones, from I think it was an '86, had just the metal pin, no plastic sheath on the outside of it. No problem, they just were a little harder to lock since you had to force the pin into alignment. To fix the problem we just transfered the mechnisms from the lexan to the glass tops, kept my locks, problem solved. It would have worked just fine without transfering anything, I just wanted to keep my locks and have them easier to lock down.
Re: are t-tops interchangeable?
Car: 1989 Trans Am GTA
Transmission: M28 T56
Cause those of us with C&C have a whole different ball of wax, and honestly if I lost a C&C T-top I might as well scrap the car for the price I'd have to pay a replacement for.
Axle/Gears: 10 Bolt 2.73 Open
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Car: 1984 Z28 HO
First: an '84 should have latch style as well. But to answer your question, yes you can convert them. On my old '83 Firebird, I could not find nice latch style T-Tops but I found a nice set of pin style so I bought them and removed the brackets from the body of the car that the pins fit into. They swapped right out with the latch-style brackets. It's been a while but I believe I had to change out the plastic trim pieces too.
Maybe the above posted years are incorrect. I know my '83 had latch style and I've seen 82's with latch style. The point is that yes, you can switch a latch style T-Top to pin style.
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
This whole thread is nuts. Misinformation out the wazoo! "Everyone keeps flip-flopping around. I can't keep it straight."
REVIVE...
So i've got an '89 RS with T-tops.. they have NO C&C markings at all.. they are "Hook" type. I am trying to put the jigsaw puzzle back together and cannot find anywhere that states which bracket is the front one and which is the back.. Any help would be appreciated.
Thanks,
TC
Thanks,
TC
