How can I get my pinstripes off?
Old Nov 24, 2002 | 08:10 PM
1989camarorsrs's Avatar
I dont realy like them too much. Their painted on, is there a way to take them off
Old Nov 24, 2002 | 08:13 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Easy Off oven cleaner works good sometimes. Try it on a small spot first to make sure it doesn't harm the cars paint itself. Or are they clear coated over??? If so that is alot of work to get rid of.
Old Nov 24, 2002 | 08:16 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
You need an "eraser"...they fit on the end of a drill....you should be able to pick one up for about $15.00 from an automotive paint store....they work FANTASTIC....will not hurt your paint and isn't messy at all. Good luck!
Old Nov 24, 2002 | 08:18 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Those do work great on vinyl pinstripe but not to good on painted pinstripes, you'll just burn the paint right off the car.
Old Nov 24, 2002 | 08:20 PM
Engine: 5.7
Oh....sorry...didn't see that...haha...painted pin stripes huh? Well.....hope you lik'em.....cause.....there not coming off without a complete repaint...lol....sorry man..
Old Nov 24, 2002 | 08:31 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Like I said. Try some Easy Off oven clearner. Be careful though. FIrst check if the stripes are clear coated over top of them, if they are don't bother. If they are not covered in clear coat then find a spot that you will not see easily, like the edge of a door or somewhere like that. Just let it sit on the stripe for a little bit. You should see it start to bubble up a little then wipe it off. As long as it doesn't hurt you cars actual paint then go nuts. You will need to wash and wax the car up, maybe even need to buff the area where the stripes were because of the fade issue. Just be careful. I will not be accountable for anything here, so be careful.
Old Nov 24, 2002 | 08:33 PM
Engine: 5.7
"I will not be accountable for anything here, so be careful."
Good thing you added that! hehehe
Old Nov 24, 2002 | 08:36 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
LOL! Actually I have used this method many of times. I haven't ever had a porblem yet, but it is good to be cautious, that's all. It does work very well. But I still like to be careful, exspecialy paint wise.
diana227vegas
Jul 8, 2016 12:27 AM
Lbibb
May 5, 2016 12:00 AM
Jsapp38
Nov 13, 2015 07:38 PM
rscamaro305
Sep 22, 2003 09:35 PM
