Switching a 91 Firebird front end to an 85 front end...
Old Nov 25, 2002 | 08:48 PM
Fade00's Avatar
I posted this before, but it didn't seem to get any replies so....
Are there any problems I might run into, besides moving the blinkers and switching the headlight covers?
Old Nov 25, 2002 | 09:08 PM
NEEDforSPEED's Avatar
that's probaly because your subject sounds boring "Switching a 91 Firebird front end to an 85 front end..."
sure i would love to help you and get my post count up...but i don't no what problems you would run in to, but hell i got this back up top for you maybe someone will answer
Old Nov 25, 2002 | 09:10 PM
Brett Gutshall's Avatar
It can be done, no problem. My roomates friend just changed his.
Old Nov 25, 2002 | 09:11 PM
Actually now that I say that, I might take that back. I'm not sure if he changed just the front or the whole front end (hood, fenders, bumper cover, headlights). I'll check for ya.
Old Dec 6, 2002 | 03:50 AM
Fade00's Avatar
You ever check on this? =)
Old Dec 6, 2002 | 06:34 AM
Wow I completely forgot about this thread. My bad. But yeah he changed everything from the doors forward, so I guess that doesn't help ya too much. Sorry bout that.
Old Dec 6, 2002 | 04:25 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
I switched my 83 nose for a 91 nose and this is what I found:
1) The 91 bumper cover did not fit over the 83 inner structure. Well, it did after I butchered it, but I later bought the correct impact bar & impact absorber (the eggcrate stuff) because I don't want my car to be a hack job (yeah, I know... too late!)
2) After switching the bumper cover, the headlight doors hit the front edge of the 91 bumper cover. It seems the older headlight doors are a bit longer. So I bought some 91 headlights. Since you're going the other way with yours, you might be fine.
3) I had to extend the wiring for the turn signals down to the new locations. You might have to extend the wiring as well, but it's no big deal. I soldered everything and used shrink wrap and then covered it in that black flex loom so you can't even tell.
All you should need are the bumper cover, impact absorber, impact bar, and turn signals. The 85-90 front end is probably the easiest to find, so you should be able to score used parts pretty
cheap. You know what, grab the turn signal wiring harness too while you're at the junkyard. And grab me some 91 GTA taillights too. Have fun.
Old Dec 6, 2002 | 04:39 PM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
Why do you want to switch from 91 to 85 front?
Old Dec 6, 2002 | 04:44 PM
Fade00's Avatar
From the doors forward? Wow, I thought the fenders and hoods were exactly the same from 82-92. I'm starting to think it might be easier to just keep the 91 nose. =\
Old Dec 6, 2002 | 04:46 PM
Fade00's Avatar
I have a set of Vision GFX. They're like 85-90 Trans Am GFX, except 2-2.5" closer to the ground. Very sweet looking.
Old Dec 6, 2002 | 04:53 PM
92Transam's Avatar
Oh I see, said the blind man.
Old Dec 6, 2002 | 04:58 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
If I recall right, the fenders are the same 82-92, but the hood, front bumper and the headlights are not. You should just scrap this project and give me those ground effects. J/K It can be done and i think you should do it, if for no other reason than to get rid of the ugmo 91 style nose.
Old Dec 6, 2002 | 06:42 PM
Fade00's Avatar
Actually GTA-SPD, I might consider it for a Ram Air II Hood....
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
bellez77
Sep 5, 2015 08:39 PM
