Underhood plastic piece??????
Old Jan 5, 2003 | 10:41 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
Ok....im sry to use this persons pic without there permision but it was the only one i could find at all. Does anyone know where i can find a plastic peice like this one for a firebird????? Ive circled the piece to help you all out. Thanks
Old Jan 5, 2003 | 10:58 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
i don't think firebirds came with that plastic piece. at least my 1992 doesn't have it
Old Jan 6, 2003 | 07:31 AM
TorchRay's Avatar
Car: 89 WS6 Formula
I dont believe its a stock peice that came from the factory...at least ive never seen one. Let me know though if anyone knows where i can one from a parts store or something.
Old Jan 6, 2003 | 08:34 AM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
someone might correct if me i'm wrong but i believe that piece was standard on all camaros.
you could probably pick one up from a junkyard or something, try going to GM even.
i also believe that only the carb'd and throttle body motors got them. because TPIs have dual snorkel set-up.
Old Jan 6, 2003 | 09:53 AM
TorchRay's Avatar
Car: 89 WS6 Formula
Is there any way of getting one from a camaro??....would it fit a firebird? Its just me but i just think it looks a litte neater.
Old Jan 6, 2003 | 10:04 AM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
My firebirds have all (3 of them an 82, 88 and 91) been solid metal there. I seriously doubt you would want to replace the metal forward of the radiator support with plastic, as to my knowledge it is integral in supporting the nose cone..
http://members.***.net/cgoblirs/left.JPG <--- bad example
Old Jan 6, 2003 | 10:39 AM
TorchRay's Avatar
Car: 89 WS6 Formula
Its not a support device...its just a piece of plastic that sits on top of the metal piece. I think the one thats on the camaro is on there to block the air filter holes cause the in the pic the car has a carb on it. I was just looking to see if you could use this piece on a firebird. My front metal piece isnt bad....but the paint on it is starting to show its age...and i really dont want to start masking everything off just to paint it. I sapose if i have to though i will.
Old Jan 6, 2003 | 11:57 AM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
Yep I think my 87 Iroc (carb) used to have one (it looks like that anyhow),,,but its gone, I want to get on too. Its not a support piece at all, just a cover!!
Old Jan 6, 2003 | 12:56 PM
the thing you guys need to realize is the fact that you cannot use this plastic piece if you have a tpi motor, unless you have re-arranged your intake. that's why you find them only on the carb'd motors.
Old Jan 6, 2003 | 03:04 PM
ohyeahjay's Avatar
classic industries sells it for 15.52 part number G7160.
Old Jan 6, 2003 | 06:04 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Ok...well now that i know where i can buy one.......Does anyone know if it will fit a firebird? I have a tpi motor......but everyone knows that the air ducking doesnt go anywhere near there at all its mounted to the radiator shroud. At least the ones with a MAF is.
Old Jan 7, 2003 | 01:21 PM
uk89camaro's Avatar
And TBi's
Old Jan 7, 2003 | 06:42 PM
TorchRay's Avatar
Car: 89 WS6 Formula
I know that you cant use this peice on a tpi camaro cause the air inlets take its place. My question is can you use this on a firebird??? The firebirds intake doesnt go down that far like the camaro's does. It sits in front of the radiator shroud and the MAF bolts on to that if you have a 3rdgen firebird that is a 89 or below when they used the MAF system.
Twin_Turbo
Mar 14, 2016 10:10 PM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
gta892000
Sep 16, 2015 12:37 AM
Saxondale
Sep 15, 2015 06:42 PM
gteatr6
Interior Parts Wanted
Sep 10, 2015 09:55 PM
