How to align rear hatch
Old Jan 26, 2003 | 08:50 AM
gmanuel's Avatar
My rear hatch is higher on one side then the other. How can I adjust the glass for it to be even on both sides?
Old Jan 26, 2003 | 09:37 AM
MdFormula350's Avatar
this might help
https://www.thirdgen.org/newdesign/t...tchalign.shtml
Old Jan 26, 2003 | 09:44 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
If you have a power pull down hatch you can do it from the pull down mechanism. I know all about it as I just did it the other day. You can set your height, and side to side alignment with that setup. Just take off that back plastic get out your socket set. There are three large bolts that hold the thing together. Up will raise the back glass and you can get the idea from there.
Old Jan 26, 2003 | 10:51 AM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
ok...did u both move the hatch pull down and the little u bar thing on the hatch?
Old Jan 26, 2003 | 11:09 AM
gmanuel's Avatar
Originally posted by MdFormula350
this might help
I looked at this but it appears to be adjustment for the end of the hatch. What I need is for height.
Thanks Gary
Old Jan 26, 2003 | 11:11 AM
gmanuel's Avatar
Originally posted by 87WS6
If you have a power pull down hatch you can do it from the pull down mechanism. .
My latch is the good old manual slam the hatch down method.
Thanks Gary
Old Jan 26, 2003 | 01:28 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Loosen the 3 bolts for the manual release. The release can be moved up and down some for adjustment. I did that to my SC for a tighter seal all the way around.
Old Jan 26, 2003 | 06:26 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
I have a question about the instructions in that link up above... That seems like a good idea for camaros and regular spoilers on the birds, but what about the aerowing?? If you move the deck lid around, wont that throw off the wing? It wont look nice and semetrical will it? My whole hatch is too far towards the rear of the car. There is no more movent in my hinges that I can see. Side to side is good, and height is good. But it sticks out... Let me know what you all think.
Justin
Old Jan 26, 2003 | 07:09 PM
Car: 85 Camaro SC
Engine: V6
It shouldnt mess with the symetry of the spoiler. Once you get the deck lid back to where it came from factory everything should look normal and correct. How far does your hatch stick out? No more than 3/8 of an inch?
Old Jan 27, 2003 | 11:00 AM
Car: 86 Trans AM
Honestly, im not sure how far. Ide say 3/8 is a good guess. A conservative one tho. It might be a bit more. The contacts for the third brake light dont match up good either. I still say that the entire glass needs to go back, but I just cant seem to get anymore play in the hinges. I might think about dismantling the hatch all together, and cleaning up the hinges, maybe elongating the holes alittle more. Then still mess with the deck lid. Ide like to get it as close as possible without changing the deck lid. Im getting water in my rear hatch (big surprise). I dont want to get a new hatch seal, which i need, without having the hatch in the right place. I dont want it to mash the seal, then when i get the hatch aligned, it wont seal good. Let me know how you think I should go about this. Thanks.
Justin
Old Jan 27, 2003 | 01:14 PM
Car: 85 Camaro SC
Engine: V6
Theres only one way to fix the decklid. You'll have to do what the tech article says https://www.thirdgen.org/newdesign/t...tchalign.shtml to get the decklid part back to where it belongs. The glass isnt your problem nor are the hinges. Over time of shuting the hatch the deck lid will slide back and go outta alignment. Thus you need open your hatch all the way remove the gas shocks, unbolt your decklid, replace your decklid to glass seal and put tons of silicone around it. Move the decklid back to where it lines up properly and bolt it back toghether.
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
