New looking Reservoirs
Car: '90 Camaro RS T-Top
Engine: 5.0 TBI
Transmission: TH700R4
Does anyone know, how can you whiten up the plastic coolant and windshield washer reservoirs? Is there another solution than just getting new ones, so the engine bay will look like nice? the ones on my '90 RS are looking yellowish and tarnished.
Thanks,
Thunderboy
Thanks,
Thunderboy
Engine: 5.0 TBI
Thanks, but I was thinking more along the lines of light sanding, vinegar, etc. to help their looks a bit. Come to think of it, I could also adapt some smaller parts from an import, to make more room.
Thunderboy
Thunderboy
Yeah but look how much CLR costs, that and all the extra time needed. Plus older cars one's are most likelyon the verge of cracking from the heat and age by now anyway. Just install new ones. There is a point where you are so cheap you drive your car into the ground by saving money and not doing it right, where do you draw the line?
Car: 89 Irocz
Axle/Gears: 342
you know a while back someone from here put a reservoir from a ford(yes I know evil
) but it looked really good. The reason why is that it's smaller and compacted looking. If I remember correctly it also had the wiper bottle with it too. Kinda of like a combo of the two. But it did look really sharp.
) but it looked really good. The reason why is that it's smaller and compacted looking. If I remember correctly it also had the wiper bottle with it too. Kinda of like a combo of the two. But it did look really sharp. Member
Car: 88 GTA, 94 BMW 840, SVX, Prelude
Engine: 383 w/ Super Ram
Transmission: built 700R4 auto
I bought a new reservoir for my T/A a couple years ago at the dealer cause the little spout on the bottom of my old one broke off, plus the top didn't seal well. Mine's the smaller, sort of "triangular" shaped one (for lack of a better word). I only mention this cause I know some 3rd gens came with a much larger cubic shaped one. Mine only cost $13 plus change, and that was dealership prices. Just get a new one, your old one's probably getting a little brittle by now anyways.
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Get some simple green or windex, and a toothbrush, and you can actually clean them up pretty nice. Mine are 20 years old and they cleaned up great
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
yeah, i may actually be putting in one from a ford. its a washer and coolant tank. about the size of a car battery. empties out the engine bay a bit. snagged it from work (worked at a towing/mechanic/used car) for free. who knows, maybe it'll go in this spring
Car: 1989 White Trans-AM
Engine: 305 TPI hopefully Upgraded Soon.
Transmission: Crappy Needs Improvment.
sorry i'm thinkin bleach but maybe i'm wrong i don't know if it would just discolor it more or not but CLR would work too.
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Originally posted by Kandied91z
18 for both.............
A toothbrush and some tough cleaning agent should do the trick....
They can clean them up quite a bit, but.......the cloudy yellow will stick around......
BUT they will never look as good new.....
$10 says Kandied91Z went out of his way to get red washer fluid to match his car.......
.......j/k
.......j/k Senior Member
Car: 1984 Z28
i tried bleach, CLR, wd40, almost anything i could find and it only cleaned it up a bit. i let mine even soak for a week in PURE bleach and it didnt do anything.. i would just buy new ones or look in a junk yard for some half decent ones.
Car: 1994 Jeep Wrangler
Originally posted by 92GTA
Dude they are only like $35 for the 2 at the dealership. I change my collant overflow every summer and my washer fluid bottle I've only had to change once...
buying one after 17 years however is understandable. btw... does anybody know the part number? i bet they r even cheaper from GM Parts direct.
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
I removed my washer fluid reservoir. I never drive it in crappy weather anyway. Now I only have one ugly tank to look at.
What about a black plastic or aluminum overflow tank from Summit or anyone else? Those look cool and won't need constant replacing
Originally posted by SMURFN' Z28
man.... where do you drive that thing to mess up a coolant overflow tank enough to justify buying a new one every year? jeeze, sounds like over kill to me.
I replace it every year because they are dirt cheap and the plastic does tend to go to an off white from the heat and it doesn't match the whiteness of the washer fluid bottle after about 8K miles. It just looks bad to me unless both of them match perfect... Supreme Member
Car: 89 Black GTA
Engine: 5.7 TPI
Brian
i was just going to say that.....harmless dye.....although black would look sick i think. and not in a good way.
so far the only colors i've seen to date are the normal green, orange, blue, red, yellow, purple.
Car: 1984 Z28
you cant.
when i soaked mine i could only scrub the outside, and the inside of the coolant one was a disgusting brown color.. i couldnt get it off.
Car: 89 Irocz
Axle/Gears: 342
hey heres the guy's engine bay who put the Ford overflow/window bottle in his car hes a memeber of the board
http://www.fbody.com/members/MNFormu...mulaengine.jpg
Car: 83 Camaro
Transmission: th350
hmmmmm......only 20 bucks.....ima have to goto Berger Chevy this week....i just got my car painted and por-15ed the engine bay...its the only thing that makes it look nasty still
Car: 89 Camaro I-Roc z
Transmission: Th700r4
Originally posted by 84Z28_5.7ltr_V8
you cant.
you cant.
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
$17 locally, PN 14070997 for an '86 Trans Am coolant overflow tank. GM Parts Direct $7.73!!!!!! List price was something like $13.xx... Can you say, local parts store is a rip off?
codeysabatini
Nov 10, 2015 04:07 PM
but now i'm too far away from the car and don't have a job
