Polished SLP Runners
Old Feb 12, 2003 | 08:18 PM
87GTA Runner's Avatar
Car: 87 GTA
Finally got my SLP Runners finished, well almost. I need to do just a little more touch up work before I install them. No wonder they charge over a hundred dollars more for the polished version, what a PITA.
Old Feb 12, 2003 | 08:20 PM
Car: 87 GTA
...and
Old Feb 12, 2003 | 08:27 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Looks very good.
Did you hand polish those?
Old Feb 12, 2003 | 08:28 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Looks good. I noticed something about the large runners, on the top of the flange theres sometimes small harline crack going from one of the tubes thru to the flange. I've had to reject many sets at Street & performance due to that.
Old Feb 12, 2003 | 08:44 PM
Car: 87 GTA
I used a combination of hand polishing, block sanding, power sander, dremel, and buffing wheels on a drill to do it.Whew!!!
Old Feb 12, 2003 | 08:51 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Damn, you used a little of every technique
Turned out pretty sweet though.
Old Feb 12, 2003 | 10:15 PM
84s/e's Avatar
Car: 1984 Firebird S/E
Engine: 5.0 lg4
looks good.
Old Feb 13, 2003 | 10:09 PM
Thirdgen86TA's Avatar
WOW That looks awesome. What grits did you use and how long did you spend on it(each grit). I started doing mine, but I don't have any machines. The only way I could do it is by hand. Think I can get it that nice?
Old Feb 13, 2003 | 10:13 PM
Tom Keliher's Avatar
Nice job!
Old Feb 13, 2003 | 10:18 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Holy uhh man those look good. How much time do you think you spent on em?
Old Feb 14, 2003 | 01:59 AM
MdFormula350's Avatar
great job!
Old Feb 14, 2003 | 02:15 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
Where did you buy your runners and whats the price?
Old Feb 14, 2003 | 03:21 PM
Car: 87 GTA
To answer a few questions:
Thirdgen86TA- I started out with 80 grit on a power sander to get most of the grains off, you can do the same with a sanding block but it will take a little longer. Then 220 to start smoothing it out, this is where you can see the grains you missed with the 80. I follow that with 400 and then 600, wet sanding with both of them. Then the fine paper comes in, 1200 followed by 1500. when I use the 1500 I use an oil we have at work we call cutting oil, like the kind use for drilling, machining, etc,.. This leaves a real nice shine for the final step. Buffing with a spiral buff with Tripoli buffing compound and then white rouge on a loose buff. Both of these on a regular power drill. I get my supplies from Eastwood. Yes you can do it by hand, actually, most of the sanding is done by hand. The curves on the runners don't lend themselves to power tools. I wrapped sandpaper on a pencil to get in all the really tight spots. Just don't rush, I would keep going back over spots I just did when you see grains start to appear after the next sanding steps. The only thing you'll really need to get is the sandpaper and buffing supplies, and once you have them you can polish everything you get your hands on I get my sandpaper from the local auto part store, and my buffing stuff from www.eastwoodcompany.com . They have pretty good prices and the best supplies.
Trans Am 12 sec- I have approximately 24-28 actual working hours spent on them spread out over a 2-3 week period. I did most of it at work when I had spare time. Let me say this, now that they are done, I would definitely do it again. They look awesome and can't wait to put them on tomorrow.
Scania- I got them directly from SLP performance. I bought them before Christmas when they were on sale for something like $230. That is more than a $100 less than their polished ones.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
no green
Jan 9, 2016 09:22 PM
bigjay89gta
Oct 15, 2015 08:04 AM
Royal_Z
Sep 30, 2015 08:45 PM
