finlly got the car dino'ed
My timeslip is as follows... I don't have a scanner so this will have to do:
R/T .518
60ft. 1.969
1/8th 9.18
1/4 14.52@92 MPH
This run was with a trans that was going bad and wouldn't shift into 3rd gear so I had to cross the finish line in 2nd at 6000 RPM. Not good with a TPI
I will have some new track times real soon. I am willing to bet that my L98 with no internal mods can run better times than that 383. No flame intended just a little friendly competition
p.s. Feel free to visit my site and see my short list of mods. I even put the stock EPROM back in and will run it like that all summer.
R/T .518
60ft. 1.969
1/8th 9.18
1/4 14.52@92 MPH
sorry trans am 12 sec about not answer you the 1st time i will post a pic....if you need any more info e mail me a xceleratemaro@yahoo.com
now no the 97 trans am is not the 2001 ram air i was speeking of so now that we have that stright i did not know that the 97 trans am was a lt1 since when...please correct me if im wrong..bc when i pick the hood up on the 97 trans am i looked to me to be a ls1??????????
now brodyscamaro if you would like to send 1000$ cash to me then cody will buy the nice fancy heads he would like to own..but for now since he works 2 jobs and goes to school money dose not grow on trees.....at least i havent seen any...so as the good friend i am i let him try my heads out....there is a big difference in the heads when you look at them side by side....as i originally posted i will report the diffrent results when he dyno's the car agin....for now he will be taking out the transmission bc the bellhousing bolts keep breaking so we need to redo them ....hopefully the car will be on the road and running good by thrus so he can drag it agin...
if you would like to figure out why his "dyno #s suck" please let me know, what you want to know to find out what the problem is...thank you
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
[QUOTE]you are a beginner, a 9.18 in the 1/8th mile is about normal for a L98 (it translates to about a 14.5). why is it so hard for you to believe that your bud's 383 just isnt making good power?[/QUOTE/
I'm a certified technician! YOU?? Beginner my ***. A 9.18 translates roughly to a 13.9. Iroc, I still don't buy it until I see a slip. What were the track conditions, temp, humidity, elevation????? The track cody and I run on sucks as far as prep and glue. But nonetheless I never said codys car was all that. I just said its quick.
Car: 1988 GTA
97 does not have an LS1, it is an LT1. No BS flags here or any flaming, and I'm sorry if I started all this doubt about your car!
I just wanted to post my time slips for my 1998 LS1 Z28. My mods are as follows - I ran 13.37 bone stock:
air lid
ported and descreened MAF
K&N
Cut out
And here is my time slip in Aug of last year ( I am on the right):
air lid
K&N
Cut out
Car: 1991 Camaro Z28
I'm all for this car outrunning LS1s and such, hell vipers too. And there might have been a win with one, the ls1 might have a had a traction problem or just a bad driver. But the majority of them, or the ones that know what they are doing will win. There's no doubt about it. On average you'll see 50 rwhp more being put down in the ls1.
Now on to the engine, it's fine if you put down 250. It's not horrible, but you realize your problems, the heads and small cam. No reason to try justify it as something special. It's a good platform that can be worked with, quit trying to defend it. And yes, L98s can run 9.1-9.2s stock. Although most are slightly higher.
Car: 1988 GTA
Originally posted by Ions91Z28
I'm all for this car outrunning LS1s and such, hell vipers too. And there might have been a win with one, the ls1 might have a had a traction problem or just a bad driver. But the majority of them, or the ones that know what they are doing will win. There's no doubt about it. On average you'll see 50 rwhp being put down in the ls1.
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
according to www.prestage.com and many other sources the closet formula is 1.5832. meaning to go from a 1/8 mile time to a 1/4 mile time you multiply the 1/8 mile time by 1.5832 to get the 1/4 mile time. check it it conensides (sp) with the other dudes slip
Car: 1988 GTA
Originally posted by wlsmoku
That means I am supposed to run a 13.53, but I actually ran a 13.1???
Here's some suggestions as to why you keep breaking bell bolts...
1) Motor to trans dowel pins are missing or improperly installed.
2) Torque converter is improperly seated in the pump.
3) Trans crossmember unsecure or bent.
4) Bent flywheel
Just a little insight in case you were unaware.
Just for the record I know what I ran and if you find it hard to believe then I think you need to get some more racetrack experience. There are plenty of stock 5.7 cars running what I run. My run was made in September of 2001 on a 60 degree day with a well prepped track (Ubly Dragway in Bad Axe, MI). I am an experienced racer and know what it takes to run good numbers.
4) Bent flywheel
Originally posted by Camarokid01
The 97 corvettes had the LS1 but the f-bodys didnt get it until 98. Lt1s have the flat looking aluminum intake manifolds and LS1s have the black plastic tube looking intakes manifolds.
how do you post a video taken on a didiatal camra????
iroc thanks for the tips you were right on #1 the dowles were not lined up so now the dowles are inbeaded in the transmission instead of the motor lol o well.....
wlsmoku did you not say the car was stock....i did not know that gm cars came new with k and n air filters???or ported and descrend maf???? i guss i learn something new everyday
now just for the recored the driver of the ls1 is a good driver ...i know bc i have ridin with him b4....but you will see in the video...
Originally posted by Xceleratemaro
i think you are wrong bc the intake on the motor is black in fact im for sure that it is an ls1 ...but enough of that crap///
Unless there was some type of motor swap.
Car: 1988 GTA
LT1(with direct port NOS)
LS1
Linson
Aug 21, 2015 02:12 PM
