Polishin is fun....
Old Feb 21, 2003 | 06:13 PM
1982chevycamaroz28's Avatar
Polishin is fun....
I know this isnt thirdgen related but i want a opion on how i did with this polishin good i did for a friend. the master tech at work is havin his motor in his bronco2 rebuiult becuz of bad main bearings and since i polished the plentum on his subaru he wanted me to do his intake plentum for the bronco. so he brought it into me yesturday and it took me about 1 1/2 to 2 hours from start to finish and this is how it came out. i think it looks good what do u guys think?
Old Feb 21, 2003 | 06:14 PM
it used to be a dark grayish brown, with dirt, paint, dust and road grime on it becuz it had 150,000 on the motor and now look at it. this picture came out a bit blury but the polishin job is more reflective then that.
Old Feb 21, 2003 | 06:15 PM
last one for u guys, sorry mods this isnt thirdgen related but im a thirdgener and its apperence related. sorry
Old Feb 21, 2003 | 07:23 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
That looks very nice! I'm assuming you used a sanding block to keep from going into the black part between the letters? Looks great!
Old Feb 21, 2003 | 07:25 PM
nolanr0413's Avatar
Car: Trans am
looks good , i just have to say, bling bling $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Old Feb 21, 2003 | 07:38 PM
nope it all used to be a dirty gray color, i just took an air die grinder type thingy to remove the paint on the letters and whatnot and then wet sanded with 600 then 1500 and then polished with mothers.
after that i took a paint prep spray and cleaned it good and then put turtle wax over all the polished parts and then sprayed it with flat black engine paint (2 coats) and then after it dryed good i scraped off the black paint that was on the polished arear with the plastic end of a 40 amp maxi fuse.
then taped off the enitre area that was polished and painted black and then also taped off the throttle body too and that one thing on the side u see is all dirty ( the master tech didnt want that sprayed) and then sprayed it with a semi-gloss ford grey color and let it dry good and then polished the polished area again to get anything that stayed on it off.
edit: also the black area wasnt black, it was that dirty color that i pointed out before
Old Feb 21, 2003 | 07:40 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
ahh.. that was my second assumption.
thanks for the info man
Old Feb 21, 2003 | 07:44 PM
no problem, this is like the best polishin piece ive done. so far the only things ive polished were ya brother upper plentum on his 91 z28, my b&m shifter handle and my lava lamp (not finished yet). and my handle and lava lamp i used just mothers polish and my brother plentum he kinda started but i finished it to an almost mirror. i know my work isnt as good as some people stuf on here but its in my book good.
Old Feb 21, 2003 | 08:58 PM
devianb's Avatar
That polishing looks good. I don't have the patience to do some polishing. I started to do some polishing on some of my engine accessories, but I never finished. The parts I did finish looked good. I am all for polishing in the engine bay, really makes the engine bay stand out.
Old Feb 21, 2003 | 09:52 PM
yea it does, if it was easier to do id do it alot but so far i only polish by hand, but its a good little excerise
Old Feb 21, 2003 | 10:32 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
You should try using compounds, you'll be amazed at the difference.
Old Feb 21, 2003 | 10:44 PM
i was goin to use compounds on it today but i couldnt this polishin kit from craftsmen that my brother bought and it has 3 different polishin wheels and 3 different compounds. i was mad i couldnt find it.
Old Feb 21, 2003 | 11:01 PM
Idlehands's Avatar
Car: 1985 Trans Am
Transmission: 5 Speed
so after its polished, what is used to treat it against rust?
Old Feb 21, 2003 | 11:08 PM
alumn. doesnt rust it oxidizes, u just clean it up with some mothers polish or use wax to protect the polishin job
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Alluminum doesnt rust it oxidizes. The best way to keep polished alluminum great looking is to clean it regulary and put some alluminum polish on it too. LOL I like your avatar.
Project 3.4 Camaro
May 7, 2012 04:55 PM
MadCelt
South East Region
45
May 1, 2012 07:02 AM
lhuser
Aug 23, 2011 09:36 PM
SLP IROC-Z
May 21, 2003 03:39 PM
