Firebird 6" thick parts book
Old Dec 1, 2003 | 01:40 PM
  #201
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I somehow need a diagram of the V6 MFI fuel rail so I can find the part number I need.
Old Dec 1, 2003 | 02:50 PM
  #202
joshp14's Avatar
11sORbust ,
Shifter boot...
If you have the auto it's 10125297
I you have the 5-spd it's 10125256
Which trim pieces are you looking for? If it's for the door stuff then the pic is below. If you need more let me know exactly what you need.
Do you have power seats? Or manual?
Gain switch is 10035312.
Diagram
List pg 1
List pg 2
Maverick H1L ,
The part numbers you need start at section 3.300
Diagram
List pg 1
List pg 2
List pg 3
This was the hardest look-up yet...phew.
Old Dec 1, 2003 | 09:37 PM
  #203
11sORbust's Avatar
Mine are the number 9 panel w/o #33 pockets. You did a great job scanning the diagram and list. Can you do the same for the drivers side? I need the numbers for the drivers side side mirror thingie. It'll be on the drv side diagram. I wonder what those door panels are called. Cause I don't see too many of them.Also the arm rest are different than the standard door panels. I didn't see a mention of that in the scanned pages?
I have manual...
THANKS! :hail: :hail: :hail:
Old Dec 1, 2003 | 10:49 PM
  #204
joshp14's Avatar
It only shows one side...in this case being the passenger. All of the part #'s you need for either side should be listed.
What 'mirror thingy' are you talking about that's not in that pic? Also, could you possibly have the 91-92 arm rests?
The covers for the seat tracks are 20206219 for driver side and 20206218 for passenger side.
Old Dec 1, 2003 | 11:06 PM
  #205
Engine: 2.7L V6
Axle/Gears: 4.41
Thx a bunch. I needed the # 55 in that diagram, the fuel block. I just hope it doesn't cost me a limb or two, I need them!
Edit: I just looked it up, and it's going to cost me an arm ($51.50) to stop my fuel leak at that return fitting! AARGH!
I also thing he's looking for the remote mirror control stick assembly or trim. Mine works, but it doesn't becuase the hardware I got for the stick doesn't match that which came original from GM, but as long as it stays in one place I could care less. There's a clip that holds the stick assembly to the door panel bracket which I need the part number for and the bracket P/N would help too.
Old Dec 1, 2003 | 11:19 PM
  #206
11sORbust's Avatar
I'm talking about the thing that controls the side mirror,manual one that moves drivers side mirror.
The door panels are stock. The arm rest matches the DP. They are just some special option or something. The panel is in the diagram. But I guess the armrest might be on the list...
Old Dec 1, 2003 | 11:25 PM
  #207
Engine: 2.7L V6
Axle/Gears: 4.41
In case you need to know, I have the door panel that is #9 in that diagram with the #8 trim.
Oh, and bust, I don't think that our arm rests were in that diagram, but I know Classic Industries has them listed as the 88-90 arm rest pads on page 64 of the 2003 catalog.
Old Dec 1, 2003 | 11:36 PM
  #208
joshp14's Avatar
I think I found what you are looking for....they are called a escutcheon and the #'s are 20545322 & 20545321. I'm not sure which side is which cuz it doesn't tell me.....Keep in mind that this isn't the bezel that goes around it.
Old Dec 2, 2003 | 12:08 AM
  #209
Engine: 2.7L V6
Axle/Gears: 4.41
bust, if you are actually talking about the actual controls for the remote mirror, you either have to buy a new remote mirror or go to a junkyard and get an assembly for the controls or the entire mirror itself. If you buy just the controls, the are a PITA to install because there are three individual cables that each have their own channel in the base for the stick, and that base has a very stiff spring in it, almost as stiff as the ones I've seen used on B&S engine valves. The controls are not fun to play with, they hurt like heck!
Old Dec 2, 2003 | 09:42 AM
  #210
11sORbust's Avatar
That is the name of my door panels? Where did you get that info??
Trust me, I know about compressed springs and things. I had the spring for the door tension punch me in the face before. It actually blacked my eye . But I just need the housing and clip that holds the mirror control it in. My door panels have a different setup than other f-bodies. The "housing" is plastic and prone to break when it's cold and you need to adjust the side mirror. The panels are somewhat rare so there is no good used stock to pull from.
I do have an inside bead to a couple of dealerships. So I might get lucky and find some stuff they ordered and never installed.
Old Dec 2, 2003 | 12:45 PM
  #211
joshp14's Avatar
No, that's not the name of your ddor panels...that's the name of the lever that controls your side mirror and those #'s above are the #'s I think that you need.
Old Dec 2, 2003 | 02:03 PM
  #212
Engine: 2.7L V6
Axle/Gears: 4.41
A diagram containing those numbers would help.
Old Dec 7, 2003 | 08:11 PM
  #213
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Washer pump cover
Hi. I need the part number for the black plastic cover that goes over the wiper motor assembly and holds the washer pump in place. I have intermittent wipers. I broke mine changing the pump today. THANKS!!!
Old Dec 8, 2003 | 01:29 PM
  #214
joshp14's Avatar
Re: Washer pump cover
Yuo have me confused....the washer pump and the wiper motor are different pieces mounted in different locations. Which pieces do you need? Do you have any pics?
Old Dec 8, 2003 | 09:50 PM
  #215
Engine: 2.7L V6
Axle/Gears: 4.41
Not exactly. I have the same wiper motor, the later thirdgen style with the washer pump mounted inside the housing for the wiper motor. I just don't have that part number to give if there actually is one...
Old Dec 9, 2003 | 12:13 AM
  #216
Car: 86 Trans AM
joshp14
Hey. I wish I had a pic. My camera isnt working. The black plastic cover I'm referring to is the outer most part in the area of the wiper motor. The cover houses the washer pump. The pump sits vertically in the cover and is held in by a small metal clip. I believe the cover actually protects the intermittent wiper circuit board. Today, after contacting the dealership, I learned that that cover actually comes with a new intermittent circuit board. It ranges from $70 - $90. SO...unless you can find me a separate part number for the cover...Im stuck going to the junk yard. No biggie...I have a whole list of stuff I need. Just thought Ide look at all my options. Thanks for helping!
Justin
Old Dec 14, 2003 | 01:33 AM
  #217
Engine: 2.7L V6
Axle/Gears: 4.41
This is going to be tough to describe, but I need the fifth piece of the Firebird air dam. I have P/N's 10118485, 10118488, and 10118489 and the other lower one (I don't know the P/N offhand), but I need the P/N for the one in the center that is shaped something like a Z and goes from the top front of the rad support to the bottom center of the front bumper cover.
Old Dec 14, 2003 | 07:00 PM
  #218
joshp14's Avatar
It's kind of tough to understand too....can you find it in this pic?
Old Dec 14, 2003 | 10:17 PM
  #219
Engine: 2.7L V6
Axle/Gears: 4.41
Number 50, please.
Old Dec 14, 2003 | 10:41 PM
  #220
joshp14's Avatar
Originally posted by Maverick H1L
Number 50, please.
BAFFLE, (W/WS4) - 14107496
BAFFLE, (W/W66) - 14107497
Old Dec 14, 2003 | 10:49 PM
  #221
Engine: 2.7L V6
Axle/Gears: 4.41
Ooh, that's just great. Those numbers would help, except I don't have an RPO sticker. I'm looking to get that, the tire loading sticker, and the manual ASAP, but can you define those RPO codes for me?
Old Dec 14, 2003 | 10:51 PM
  #222
joshp14's Avatar
Not a prob...
WS4 - Trans Am
W66 - Formula
Hopefully you can distinguish the difference.
Old Dec 14, 2003 | 10:56 PM
  #223
Engine: 2.7L V6
Axle/Gears: 4.41
I hope I get this right... TransAm has GFX, right? I don't have that, meaning I have the W66 option.
I just checked both numbers on GMPartsDirect, and neither are in their database. I'll have to get the numbers crossmatched at the dealer.
Old Dec 14, 2003 | 11:01 PM
  #224
joshp14's Avatar
Let me double check one more thing....your car is 87 right? I'm not getting this cuz it only lists those baffles for formulas and trans ams. If your car is a stock v6, then its not a formula or a ta. By this I assume that your car doesnt have it or need it. You may have to call the dealer on this one. If you want one, then I'd go with the formula one.
Old Dec 14, 2003 | 11:24 PM
  #225
Engine: 2.7L V6
Axle/Gears: 4.41
I am not quite sure as to whether I need one or not because my car appears to have had the front bumper cover replaced along with the bumper itself, and both say they are from a TransAm. I also had to replace the air dam because I did not have one when I bought the car and I had problems with engine heat. Some said I needed it, some didn't. Maybe you can help with this dilemma?
Old Dec 14, 2003 | 11:27 PM
  #226
joshp14's Avatar
Well, that piece is supposedly what directs the most of the air into the radiator. I say get it if you are having problems with engine overheating. If not, I say dont get it.
Old Dec 15, 2003 | 01:42 PM
  #227
Engine: 2.7L V6
Axle/Gears: 4.41
Well, I haven't gone anywhere since I last drove it in Sept, before I got the air dam I have now. But I do know that there are some Christmas tree clips on the rad support that appear like they are in the shape of that deflector... I'll wait until the next time I drive the car in the Spring to see how the heat does and whether I really need it or not.
Old Dec 22, 2003 | 03:29 PM
  #228
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
would that book list a part number for an ecm wiring harness for an 85 trans am with an L69 (VIN code G), 5 speed tranny, and a/c?
Old Jan 8, 2004 | 09:27 AM
  #229
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
TTT
Upper strut mounts, 1991 model Need left and right.
Old Jan 12, 2004 | 12:47 AM
  #230
chevy91z's Avatar
Its cool to see someone helpful with the Manuals. All I know is thank *** for the SI2000 system, those books get real annoying real quick. That and you print out the page you want and you dont have to worry bout keeping it clean
Old Jan 12, 2004 | 01:34 AM
  #231
Diabolical's Avatar
Engine: 305HO L69
where would one get this SI2000 system? or is that something that only gm shops have?
Old Jan 12, 2004 | 08:28 PM
  #232
joshp14's Avatar
If he is talking about the service.gm.com site, then yes, only people with passwords can get into the site. All it has is 97+ cars as far is service info is concerned. All it has for cars older than 97 is bulletins and other info.
I have access to it if you need sumthing for newer cars, but anything concerning our cars...prolly not.
Dale, sorry about the wait, I'll try to get back to you tonight.
-Josh
Old Jan 21, 2004 | 01:55 PM
  #233
FatJ's Avatar
Car: 88 GTA
I have an '88 gta. it's missing the front air deflector, looking around i think ive found the right one, i just need to make sure before i order it because theres no picture of it on the site.
The part # is 10118485. Will this fit my car properly?
Thnx
Old Jan 21, 2004 | 03:15 PM
  #234
Engine: 2.7L V6
Axle/Gears: 4.41
Fat, you also need P/N's 10118488 and 10118489 to complete the air deflector if it is missing. The 10118485 is the lowest center piece of the four.
Old Feb 4, 2004 | 12:56 PM
  #235
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
What are the part numbers to all 4 black plastic bumper inserts on an 1989 formula. I know its a different number on all 4, 2 for the front and 2 for the rear.
Old Feb 13, 2004 | 01:25 PM
  #236
joshp14's Avatar
RF-10030562
LF-10030563
RR-10030541
LR-10030542
Sorry about the delayed response, I was in Hawaii from the 4th til yesturday.
Old Feb 15, 2004 | 03:34 PM
  #237
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
No Problem thanks for the numbers. Unfortantlly the one I really need is the one GM doesn't have, the RR isn't coming up on gmpartsdirect.com
Old Feb 17, 2004 | 01:16 AM
  #238
Engine: 2.7L V6
Axle/Gears: 4.41
Okay, the V6 finally crapped out on me (honestly, I did NOT know about the leaking evap can!) and I need to know the P/N's for V8 frame mounts, preferably within the next week please.
Old Feb 17, 2004 | 02:45 PM
  #239
joshp14's Avatar
When you say frame mounts do you mean engine mounts? If not please elaborate. Do you want the mounts for an 87 then?
Old Feb 17, 2004 | 09:06 PM
  #240
Engine: 2.7L V6
Axle/Gears: 4.41
The non rubber engine mount parts, that are bolted to the frame and not the engine block.
Old Feb 17, 2004 | 10:08 PM
  #241
joshp14's Avatar
14039405 same # for both sides and it looks like it bolts to the cradle.
Old Feb 20, 2004 | 02:22 PM
  #242
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Can you find the part number for the window felts of an 87? There was also a window guide, kinda looked like a roller, that I need a PN for if you can find it.
Old Feb 22, 2004 | 06:01 PM
  #243
joshp14's Avatar
felts or guides are 20192983
i'm not sure on what roller part you are talking about.
Old Mar 1, 2004 | 06:50 PM
  #244
Savannah Dan's Avatar
Hey Josh, I'm gonna thank you in advance as I jump on this part # band wagon.
1991 Firebird, 305 TBI, Auto, T-Top
Trunk Weatherstrip (on body, not on hatch)
Driver's Door Electric Lock Switch
Driver's Door Drink/Map holder
Screw that holds sun visor to retainer bar
Old Mar 1, 2004 | 09:32 PM
  #245
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
How about the light assembly that is under the hood to illuminate the engine bay? I don't have the option on my T/A and saw it under a few Camaros.
Old Mar 2, 2004 | 10:47 AM
  #246
Car: 1987 IROC Z
I don't suppose you could scan a pic of the door assembly to the 87 IROC? I need this guide in order to have my window sit properly.
Old Mar 5, 2004 | 10:13 AM
  #247
86BirdSE's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: LG4 TPI Conversion
Axle/Gears: 3.42 SLP Posi 10 Bolt
Need ECM #'s
Do you have the numbers for the AUJP memcal for the '730 ecm?
Old Mar 31, 2004 | 06:32 PM
  #248
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
ugh...i hate to dump a crap load of stuff on top of whats already posted josh, but i desperately need these part numbers for my car:
in the transmission, in the shifter assembly: i need the little spring and the ball bearing that go underneath the shifter block (they work together to create the shift gates)
thanks a lot.
Old Mar 31, 2004 | 09:02 PM
  #249
joshp14's Avatar
wow i need to pay more attention to this thread....
Savannah Dan
1. 10156321
2. When you say switch I assume you mean the button on the door - 20344293
3. Black – 10125159
Med. Beachwood – 10125161
Med. Dk Grey – 10125163
Med. Beige – 10181885
4. Well it shows me the visor and all the hardware…and even the screws that hold the bracket to the roof, but not the screw that holds the visor to the bar support. :scratchhead:
OUTATIME GTA
No luck on the lamp, couldn’t find it anywhere. L
Omnipotentgoku
Keep in mind this is a firebird book, not camaro, but here is the door drawing for the 87 bird.
Illustration
List #1
List #2
86BirdSE
The only AUJP I found was under the 1991 model year….
Production ecm # - 16125181
Service controller ecm # - 1227730
service calibrator # - 16151348
production calibrator prom code # - 1350AUJP
Trans_AM_88
I assume you mean the ball and spring for the detents…if so the spring is 14050769 and the ball (3/8”) is 7826284.
Old Apr 1, 2004 | 04:31 PM
  #250
86BirdSE's Avatar
AUJP memcal
you might want to pencil this into your book:
Memcal is 16151348. It fits TPI motors with 700r4 transmissions. It is still availible from GM through gmpartsdirect.com at about 50$ shipped.
