Firebird 6" thick parts book
Re: AUJP memcal
Originally posted by 86BirdSE
you might want to pencil this into your book:
Memcal is 16151348. It fits TPI motors with 700r4 transmissions. It is still availible from GM through gmpartsdirect.com at about 50$ shipped.
Car: 1986 Pontiac Firebird S/E
Engine: LG4 TPI Conversion
Axle/Gears: 3.42 SLP Posi 10 Bolt
tis very very true. I'm pretty sure I speak on behalf of the board, when I say Thanks a ton for your service!!:hail:
You know you guys can have your own copy of that book on CDROM by going to fbodycd.com. The CD contains all the info that are in the "green" pages of his manual. Most people will find what they need in those pages and the diagrams are great to have.
(I know, a shameless plug, but it's true) LOL
Car: 1985 Trans Am
Engine: upgrading...
Transmission: upgrading...
hey josh
could you check to see if you can find the part number for the egr sensor on an 87 trans am tpi motor. it might be called the EGR Diagnostic Switch or EGR Feedback Switch too. I'm not completely sure.
Thanks!
Thanks!
Originally posted by theSteve
hey josh
Thanks!
hey josh
Thanks!
Car: 1985 Trans Am
Originally posted by joshp14
Where is it located at and for what motor?
i dunn broke mine when trying to remove it from that rusty lookin hole there.
From the diagrams I'm looking at, it looks as if it's part of the wiring harness and can't be purchased separately.....
You may have to take this one to the dealership and point it out to them and see what they have to say.
Sorry I couldn't help.
Car: 1985 Trans Am
thanks for checkin. i hit up my local parts store, the guy said he was bringing it in for me and would have it tomorrow... so we'll see if its the right thing.
Car: '84 Trans Am; '88 GTA
Engine: Vortec 355ci TPI
Transmission: TH-700R4
If ANYONE has the part number for the pontiac 82-84 door lock buttons, LEFT AND RIGHT, let me know. Thanks.
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Hey Josh, if it's not too much trouble, could you look up the part number for the "Harness Connector to ECM"? It's the harness that connects to the coolant temperature sensor on the thermostat housing.
This is from an '85 LG4 with an automatic.
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
What about the left and right E-brakes cables for an 85 I think it was TA?
I got the 9 bolt of of an 85-86 TA and no one can find me the right size cables for me.
Car: 88 Camaro
Engine: L98 350
Josh, you still watching this? If so and you have time could you look up the lower outer window weatherstrips, both sides for an 88 year? Local dealer has a bunch of this older stuff in the corner, a PN might get me some factory pieces. Thanks!
Car: 88 Camaro
Engine: L98 350
Wow I never have time to reply to this thread anymore with work and running a business too....
Anyway, here is what I have found for you guys...
tom3
I am giving you the #'s for the seals that sit on the top of the door, and push against the window (to wipe dew or water off)
It looks like there are 2 pieces to each side, the support and the seal strip. I will give you all 4 numbers...
L Support - 12394511
L Seal - 10124265
R Support - 12394510
R Seal - 10124264
92RS shearn
here is what i found on this...there is a slew of them listed...but here is what i sifted out...
if you have rear disc brakes, the #'s are:
LH - 10200443
RH - 10080832
if you have rear drum, the #'s are:
LH - 10080833
RH - 10080834
comatose 88 WS6
Where is it located?
Mr.84TransAmer
RH - 20344292
LH - 20344293
Gumby
tom3
L Seal - 10124265
R Seal - 10124264
92RS shearn
LH - 10200443
RH - 10080832
LH - 10080833
RH - 10080834
comatose 88 WS6
Mr.84TransAmer
RH - 20344292
LH - 20344293
Gumby
Car: 1990 firebird
Engine: 3.1 v6
hey sorry to bring this back up, but im in need of a part number, i bought a CTS but im not sure if its the right one,, maybe they gave me the wrong one??.....
Request:... P/N for coolant temperature sensor, 1990 pontiac firebird 3.1 v6
Car: 1990 Formula
Transmission: WC T5
Josh,
Do you have any good diagrams of the lower air diflector for the 88TA, I picked up a gfx package/bumpers and I want to find what air deflectors I am missing.
Also,
behind the rocker GFX there is a support piece made of metal that keep it from sagging.(I need both sides of car)
Tom
Also,
Tom
Originally posted by steves86TA
i need the part# for an altenatro bracket for a 86 TPI v-belt car, and also the part # for a 86 LG4 altenator brakcet
I assume you mean the bracket that has the elongated curved hole for the alternator adjustment...if so then....
86 TPI bracket is 14082306
86 LG4 bracket is the same as above
Coolant Fan Switch Part Number
Josh:- Could you possibly check the part number for a coolant fan switch for a 1989 Pontiac TransAm 350 L98 TPI. It's the one located on the passenger side cylinder head between #6 and #8.
It's the one used on cars with dual fans, to control the secondary cooling fan.
Many thanks for any help with this!
Anyway, here is a link to a thread which anyone with the same query as I posted above can find their answer:-
Coolant Fan Switch Part Number for 1989 TPI
https://www.thirdgen.org/techbb2/sho...35#post2022335
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
Could i get the part number to the plastic trim that hangs underneath the car door on both sides...i dunno its purpose but i need one bc i only have it on one side
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Are you referring to the black air deflectors?
10027611 DEFLECTOR, ROCKER PNL LWR-RH
10027612 DEFLECTOR, ROCKER PNL LWR-LH
Both 35.75 at New GM Parts last I checked.
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
I need a part number too. It should be pretty easy - the headlight module for the later birds/trans ams (87+).
Car: 1990 Formula
Transmission: WC T5
--Tom
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Congrats on getting this book!!!
Glad to see it went to a "good home" and you're planning to carry on the tradition....
Car: 1990 Formula
Transmission: WC T5
I figured that this could be my contribution to this great web site. I try to help others out when I can, because others helped me.
I'm not sure how much personally I'll need all of the specific info, because, most of my conversions are done (Aero Graphics in the works, just have to be painted and attached). But, the last thing I wanted to happen is have a great resource possibly dissapear.
So, Yes it has found a new "good" home!
Car: 1990 Formula
Transmission: WC T5
Also Mods if any of you read this could you please change the title back and get rid of the FOR SALE at the front of the title.
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
90-92 16514174
Listed for $137 in the day.
Of course, now for the bad part. It looks as if they may be discontinued. Not listed in NewGMParts nor GMPartsDirect.
novass
novass
Originally posted by Goumba T
That, and also if you're like me, it helps build a handy listing. If someone asks for something I think I may need in the future, I write it down rather than going and looking it up again later. [/B]
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Phew... long time since anyone posted in this topic...
Anyways, I need to see a diagram of how the side windows are assembled. Is seems my PS window is missing a few pieces, especially the ones that regulate the final height of the window. Had to clean some crap out of the motor last week and noticed somewhere along the line the parts that regulate the final height of the window are gone. I have the window adjusted properly except for the final height, and I know it's too high because the line that was where the bottom of the old tint was is above the weatherstripping.
I would use the diagrams that are linked to on gmpartsdirect.com's alternate parts catalog, but none of their diagrams work for me
That door is driving me nuts with all its rattles and crap because of the missing parts...
Engine: 2.7L V6
Axle/Gears: 4.41
I guess a whole lot of missing parts is what one gets for being the fourth owner of a car with over 200K on the clock...
Car: 1988 Firebird
Engine: 305 TBI
91 3.1L radiator fan switch
Could you please list the radiator fan switch for a 91 3.1L? Also, if it's not too much trouble could you put the diagram of its location on passenger side head for the v6?
For some reason the dealer couldn't locate the fan switch for the 91 v6 on their listing and I can't seem to locate it on the passenger head/near firewall as other posts have stated. Thanks.
Car: 1990 Formula
Transmission: WC T5
Highwind,
I looked and could not find a listing for the switch. Do you have dual fans or just 1? If you have just one the fan would be computer controled if if rember correctly.
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
EGR Valve and EGR Solenoid for a 1987 Trans Am with TPI. I don't believe there is a difference, but if numbers are different for 305 and 350, please let me have both.
Thanks! It's great to have a source to look up p/n's.
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Do you have a diagram of the wiring harness around the steering column? I am having a problem where my headlights engage my starter as soon as I turn them on. (its an 87 IROC, but I am hoping they will be similar).
https://www.thirdgen.org/techbb2/sho...13#post2466913
Really, I am needing to know where the ignition could cross the headlight assembly.
