Firebird 6" thick parts book
Old Aug 17, 2005 | 05:22 AM
  #301
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Ok, how about the fuse panel? Any wiring diagrams on that in the book ?
Old Aug 17, 2005 | 07:39 AM
  #302
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
No electrical except the exploded view of a starter. Wiring diagrams would be found in a service manual.
Old Aug 17, 2005 | 03:30 PM
  #303
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Originally posted by omnipotentgoku
Do you have a diagram of the wiring harness around the steering column? I am having a problem where my headlights engage my starter as soon as I turn them on. (its an 87 IROC, but I am hoping they will be similar).
https://www.thirdgen.org/techbb2/sho...13#post2466913
Really, I am needing to know where the ignition could cross the headlight assembly.
Even the service manual's wiring diagram wouldn't give you detail like this. It would give a line diagram, showing the connections with no exact locations. I'm afraid you're going to have to do it the hard way, unless someone else chimes in.
Old May 15, 2006 | 01:52 PM
  #304
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Looking for a speedo driven (that's right.. the driven gear is the only P/N I can't find on GM PartsDirect.com) gear for a T-5. Needs to have 19 teeth, and be the 85+ style with the nylon gear on the metal shaft...
Old May 18, 2006 | 06:00 PM
  #305
Engine: 2.7L V6
Axle/Gears: 4.41
Still waiting on that part number. I don't think the guys at the dealer will mind cross-referencing an older number. I really don't like having my speedo read over 70 MPH when I know I'm only barely doing 60...
The worst part about this is that I've seen tons of the older one-piece cable speedo driven gears on eBay, all in new GM packaging, so I know that the gears SHOULD still be available, it's just that the numbers aren't in the right places.
Old May 18, 2006 | 06:43 PM
  #306
Vaneat-91RS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
14090592 19 teeth, color is white. Code is "R". Hmmm, further investigation is needed I think, this is for an AT it appears--gears are located in charts which are somewhat misleading, so I'll look a little deeper and post back asap.
Further investigation looks like it doesn't really matter. No differentiation is shown. they listed one additional note saying the gear w/sleeve, shaft and seal is part#14090580.
Old May 18, 2006 | 09:14 PM
  #307
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I was not able to find any reference in my book.
I know for a fact that the 5 speed and at gears are different. I did a 700r4 to t5 swap a few years ago and the are definately different. I know I posted on the topic back then just have to find it.
Old May 21, 2006 | 12:51 PM
  #308
Engine: 2.7L V6
Axle/Gears: 4.41
Ok, let me ask a different question: for a standard 3.42 rearend, which of the drive gears would I use with the white gear? IIRC, I have the white gear, but I can pull the VSS and verify. I have no problem going out and getting a DRIVE gear, just the other one...
BTW, there is no way in he11 that you can use a 700R4 gear in the T-5. The gear is just about a half inch too big around to fit in the dang hole in the tail housing.
Old May 22, 2006 | 07:09 PM
  #309
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
That's what I thought. You just have to love GM's documentation.
I'm not at work today, but I'll try to look again tomorrow, see what happens.
Old May 23, 2006 | 04:06 PM
  #310
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
I double checked today, and the part# I looked up was the correct one for T-5 ONLY. It does not fit the AT. Thus it is the correct part as I originally looked up. The charts were just confusing.
Old May 24, 2006 | 08:14 PM
  #311
Engine: 2.7L V6
Axle/Gears: 4.41
The question still remains:
If I have the right driven gear, then why does my speedo still register at 70 when I KNOW I'm doing 60? Could I have the wrong drive gear? Or is it the cheapo VSS I bought?
BTW, everything was working correctly before I swapped in the T-5...
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Jae992
Aug 27, 2015 09:07 AM
NinjaNife
Aug 23, 2015 11:49 AM
GVMV
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
