under hood mirror
Old Mar 18, 2003 | 07:13 PM
tpi iroc's Avatar
Car: 86 iroc
Engine: 355 400hp
Transmission: 700r4 race built
Axle/Gears: 4.10 posi
under hood mirror
where would i find the mirror that you can put under the hood to reflect the motor and other stuff like that?
Old Mar 18, 2003 | 07:22 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
Honesly man, ive been trying to find something like that for mine also......the only thing that i can come up with at all is jcwhitney sells a product that is insulation but it has a shiny side on one and sticky on the other. I was thinking of buying a new hood insulation piece and then taking and making something custom. Might want to try that. Hope this helps.
Old Mar 18, 2003 | 07:27 PM
Adam62083's Avatar
It would have to be detachable...if you left it under the hood it would probably crack from the heat.
Old Mar 18, 2003 | 08:41 PM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
Unless you used polished aluminum! lol
Quick6's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 V8 TPI
Something like this..?
Old Mar 18, 2003 | 10:56 PM
Kandied91z's Avatar
you can go that route by basically bolting it down but it isn't daily driver friendly.
go to a major hardware store or any place that caries plexiglass and look for a the mirrored version
cut out templates of how you want it to lay using some sort of paper, cardboard, or anything to get the impression and then cut away.
this is how it's usually done, you can use double sided tape or most like to use magnets. just remove them after the show.
good luck.
Old Mar 18, 2003 | 11:37 PM
sbrice18fan's Avatar
Car: 1990 Chevrolet Camaro RS
I have thought about the same thing except using polished stainless steel.
Old Mar 18, 2003 | 11:44 PM
Kandied91z's Avatar
you can do that, not nearly as reflective though.
materials might cost more too........i'm not sure what a sheet of it goes for?
Old Mar 19, 2003 | 07:58 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
car Audio Shops. We carried it all the time for installs.
Mirror Plexi as Kandied91z Said.
Old Mar 19, 2003 | 08:44 AM
transam305's Avatar
Car: 1989 White Trans-AM
Engine: 305 TPI hopefully Upgraded Soon.
Transmission: Crappy Needs Improvment.
wouldn't a mirror get broken under the hood? i'd go with the polished alumminum it reflects if polished well and kept up it reflects just as well as a mirror would...wouldn't it?
Old Mar 19, 2003 | 08:47 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
yes it probably would but with the other suggestions like the mirrored plexiglass it shouldnt.
Old Mar 19, 2003 | 08:50 AM
transam305's Avatar
i see... where do you get this stuff?
Old Mar 19, 2003 | 10:36 AM
LT1guy's Avatar
Car: 1987 Trans Am
Most major cities have industrial plastics and polycarbonate dealers; check the yellow pages. Standard mirrored polycarbonate is fairly common; the colored stuff is usually special order. It should be removed when driving, since it won't hold up to the heat.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
