Aero scoops too much?
I was looking at my hood options, and the classic cowl doesn't really appeal to me. I kinda like the SS type, but seems a few around my area have them. Do the low profile Aeroscoops look to corny for a street car? I say street meaning it's not an 8 second 1/4 car (yet
) In other words, if I had a clean, proffessional done Aero on my car, and you drove by a parking lot with my car there, would you "yuck" or "that's cool"? Honest please
Car: 89 Formula Firebird
Engine: 305 - Demon 525
I really woulnt know unless I saw it. Tell ya what.. post ya pic and see if someone will photoshop one on your car. If they dont.. I will.. but tomorrow. I hope
let's see if this works...
I didn't really think that the low profile Aeros were portraying to much. I thought it might be a refreshing change than everyone elses cowls and such. Going to carb and have hood clearance issues anyway, so I figured what the hell. Thanks for your opinions!
I'll see if I can get a pic of the Aero I'm talking about.
Here's the kind I'm taliking about, it's overall dimensions are
36" long and 9" high. They have one shorter that is only 7" and a mini even shorter that is 4 1/2" But that has to be custom made. The shop I'm getting them from if I do get one want roughly $250 a piece, customs are higher.
Originally posted by Jim85IROC
Your car isn't really an 88 1LE is it?
Car: Camaro
Engine: Carbed L98
Transmission: TH350
hey man whats up!!!!!!
Only problem I see with it is that the areo schoop wont fit flush on the Iroc hood. The vents will cause a probem.
If you can score a flat hood for cheap, you would be fine.
I say do it. dare to be different. just go with the shortest high scoop they have. There is one that bolts on, but the flange is inside were you dont see it.
As far as being able to back it up, didnt you get the head and cam swap done. Should be a strong motor.
Hell, I still have my stock 92 Z hood, which I plan on keeping, just because everyone else is changing theres.
That's a bit big G-91Z, I was looking at one quite a bit smaller. I think the dimensions were 36L, 28W, and maybe shelling out cash for the 4 1/2 " tall. I'm going to the shop later, he has a pic of that small Aero on a Mustang. If someone could fotochop that aero on mine I would appreciate it!!
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Originally posted by 88ROC1LE
I'm in the middle of the swap now, having some wiring issues. I've got a new Air Gap RPM I'm gonna trade for, and about a 150 shot with that. TH400 swap is also coming, just have to get the driveshaft.
Pm me if you have any questions on the swap. All I like is the heater and raidiator hoses. And clamping off a fuel line.
Badgta is about at the same stage too.
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
I wouldn't do it if I were you. Like 12 Sec GTA said, you need to have the HP to back it up or people will think you're a poser. My friend had a Malibu with plexiglass side windows, plastic bucket seats & Simpson harnesses. It ran 13's. People laughed. Eventually, he built it up til he ran 10's. I'd wait on the big scoop until you get into the 10's.
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Hey man do what you want. Its your car. Id go with one that sits almost right on top of the hood, something real low profile but i think if you do it right it will look sweet.
Also if your just looking for something interesting that not a lot of people are running check out this hood by Cervini.....
Its kinda cool looking. My ex-girlfriend had one on her 92 RS and it looked pretty sweet.
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i think they look bad ***. i was seriously considering one myself. i would stick to the smaller bolt on styles. there was a fox body around here that had one, it looked killer
Thanks for the chop job and ideas. The cowl and SS looks are popping up everywhere, I was looking for something different. I like the one you posted 88blk, think there is enough clearance for carb with 1" spacer and RPM Airgap? I looked at the Mustang and it was real nice. The opening came down flush with the hood, and there was no large bulge in the middle of the scoop, just nice slope. Thanks again guys!
*EDIT* You have a website for that Cervini?
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
www.cervinis.com I dunno how much space it provides for a carb and whatnot. Id assume about as much clearance as a 2" cowl would give you from the looks of it. Maybe the company can give you more info.
Car: 91 firebird now
Transmission: 5 speed
I think it looks silly on a car that is purely street driven. If you drag raced your car on a regular basis then I think it would be ok. If you are getting it for looks, I have to say no, unless you can back up the looks of that scoop. When I see scoops like that on cars at the track, they usually run lower than 12's. Most people who have them get them for thier function and not looks.
The Mustang that had the mini Aero looked like the bottom "riser" of the scoop was trimmed and molded. The opening sloped same as the hood, it was nice. Could see the air filter assembly through the front. I'm looking for function, as well as look. I said it will see very little street, but when I do drive through town or to the track, I don't want to look like a jackass. Fresh air intake, clearance for the carb, lighter weight, and great looks. That's why I'm going through all the trouble of this, otherwise I would just get a bolt on and live with it.
I'll check that website for the Cervini. Hope it meets my needs, cause the look is sharp!
I've found a winner! Thanks for showing me this hood! It's $399 fiberglass, and has a cooling effect. It's the same as a 3" scoop in clearance. Thanks again for the help and opinions!
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Here's a pic of one on a Camaro, but I don't think one this big would be good on a street car, like the others said as long as you can back up the looks.....
p.s. i talked to the pelech bros at the last nmca race (in commerce GA) and they seemed a little disturbed that their car was all over a big website that they have never heard of.
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
From: "No one cares if you're in before the lock!" - Best quote ever.
I don't see how it performs affects the looks either ay - it's either nice looking, or it's not. Sure, it could be functional, but toilet paper isn't nice looking when it is or isn't functional...hoods shouldn't be different. A car may NEED a parachute to stop because it's so fast, but that still looks dumb. Personally, I think it's a bit obtrusive looking for your car, but meh...
dustint209
Nov 26, 2015 12:28 AM
sreZ28
Oct 22, 2015 08:21 AM
