how can i do this
Old Mar 25, 2003 | 03:14 PM
IROCafros's Avatar
how can i do this
Ok. I have been in alot of 4th gen Camaros.. I LOVE THE FEEL OF THEM. i dont know what it is.. its like there stuck to the ground, just solid and i love the way they feel on turns. i like my car but i want that feel. any ideas? i havnt noticed this feel in any other cars.
Old Mar 25, 2003 | 04:19 PM
IROCafros's Avatar
no one knows anything?
Old Mar 25, 2003 | 04:32 PM
hotrod87camaro's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
i don't know, but if anyone does, it will probably take more than an hour to answer, so just be patient.
Spdfrk1990's Avatar
I know that the wheel feels so tight because they have rack and pinion steering and third gens dont. You can get a new steering box for a third gen with a tighter ratio. I bet it would also take some slack out. I was wanting to get 1 but there kinda high i want to get some other things first but i bet 1 would help. You can get them from summit. Cause i replaced all my front end all the steering linkage and ball joints and struts the hole 9 yards but the steering box.
Old Mar 25, 2003 | 04:33 PM
Spdfrk1990's Avatar
Also a wonder bar would help.
Old Mar 25, 2003 | 04:37 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My car outhandles my brothers car.
His 96 T/A
My 86,
Old Mar 25, 2003 | 04:41 PM
Spdfrk1990's Avatar
he was prob just sayin the wheel is a lil sloppy cause i know mine handles awsome. But 4 gens just feel real responsive with the rack and pinion even if doesnt hadle as good as ur third gen.
Old Mar 26, 2003 | 10:04 AM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
LT1Guy wants to swap to a rack in his 3rd gen. As far as the rest of the feel. I have found my 2.8 feels better then the 4th gens I have ridden in...Most of why 4th gens feel better is they are newer....
Rebuild your suspension and you will be amazed. New shocks and struts... Go for energy suspension bushings...Hit a junk yard, get a wonder bar, and the TA or Iroc sway bars. I have a Herb Adams adj panhard rod and Granatelli (sp)Lower Control arms. The eibach springs helped a ton! But the Sub frame conectors made the most noticable change!
Then you will see just how good these cars can really feel. I think 3rd gens have a much more solid ride and feel!
